Restoring lost abs long code with new vcds hex v2 pro
- Drives: Vw polo 6r 1600tdi
Re: Restoring lost abs long code with new vcds hex v2 pro
Are you able to generate a new abs long code for the esp component code M60EC1 from the vin number and all the other information your required for polo 6r? I will be so glad if you can.
I'll give it a few gos. I'll need a full autoscan and the brake diameter sizes etc et. But I can't guarantee I'll find one that works since it's a difficult and time consuming job.
Thank you , I will really appreciate that . Here's the vin aavzzz1kz9u009184, front discs-312, rear discs- 282. Right hand drive, hatch back, engine code bwa- 2litre fsi, 2009 mark 5 golf gti. I am going to try and figure out how to upload the autoscan.
I could not figure out how to upload the autoscan on the forum, so I emailed it to info@uk-polos.net and asked them to email it to you. If you can solve this problem, I will be more than willing to compensate you for your efforts and time.
You can just copy and paste the text into the post.
I am going to dial up my laptop to the internet and try
Unbelievable when logging in with the lap top it's rejecting the log in info. Won't the administrators be able to email it to you.
I hope so... ![Smile :-)](./images/smilies/icon_smile.gif)
Or you can mail it directly to me:
![Image](https://i.imgur.com/cOaVoVv.png)
Thanks, I will do it right away.
OK, let's do this.
Autoscan:
VIN aavzzz1kz9u009184
2.0 TFSI Golf 5 GTI BWA engine
DSG
FWD
front discs-312 mm
rear discs- 282.
Right hand drive
00 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 byte numbers
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Empty code
16 3B 60 0D 09 22 00 03 68 12 06 E8 90 1C 00 81 30 00 reference by TS VIN AAVZZZ1KZ9U009743
13 4B 00 0C 09 22 00 03 C8 0C 00 EC 90 1D 00 00 00 00 00 base coding 1st guess
Refinements, try these:
134B600D09220003C80C06EC901D0081300000
164B600D09220003680C06EC901D0081300000
133B600D09220003C80C06EC901D0081300000
163B600D09220003680C06EC901D0081300000
Autoscan:
Wednesday,25,October,2017,14:53:56:54965
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4407.4
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: AAVZZZ1KZ9U009184 License Plate:
Mileage: 102830km-63895mi Repair Order: 2
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: AAVZZZ1KZ9U009184 Mileage: 102830km-63895miles
16-Steering wheel -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine
Cannot be reached
Unable to communicate with address 01,
and "Force K on engine" is activated.
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 051 C HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1817
Revision: 04843012 Serial number: 00000806211686
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 13724F0AE778E3CFF68-8046
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 00000000000000000000000000000000000000
Shop #: WSC 01357 011 00200
VCID: 76B4169ED8CA56E7716-8022
1 Fault Found:
01042 - Control Module; Not Coded
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 121
Time Indication: 0
Count: 3
Count: 12
Count: 20992
Count: 195
Count: 42752
Count: 0
Count: 0
Count: 0
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 DE HW: 1K0 907 044 DE
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 6D8639F2A19C953F80C-8038
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000008400494
Coding: E78F8F2700041500471400001400000000097F075C000100000000000000
Shop #: WSC 00046 412 00000
VCID: 71BE2582BDA471DFA44-8024
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 021008 020 0501
Coding: 00049109
Shop #: WSC 00046
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 150708 046 0204
Coding: 00208933
Shop #: WSC 00046
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 3A AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD24CWY4
Coding: 0013121
VCID: 3D26C9B2B17CC5BF70C-8068
Subsystem 1 - Serial number: 6332MSME3D446272C
Subsystem 2 - Serial number: 6342MSME3743267AE
Subsystem 3 - Serial number: 6352QSME72327675G
Subsystem 4 - Serial number: 6362QSME726C187BW
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 752 0101
Coding: 0012122
VCID: 78A818A6DEDE209763A-802C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K6 920 874 HW: 1K6 920 874
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0002000 Serial number: VWX7Z0H63NV7RS
Coding: 0004103
VCID: 70B82086B6AE78D7ABA-8024
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 210608F1001813
Coding: ED817F060002020003
Shop #: WSC 54270 002 1048576
VCID: 3536D192894C1DFFB8C-8060
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 2416
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1210
Coding: 0000692
VCID: 3828D8A69E5EE097A3A-806C
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
Shop #: WSC 01296 996 84123
VCID: 3634D69E944A16E7B16-8062
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 199002005103087F2D040F0F70085FC690FC00
VCID: 03527F4A9718734F468-8056
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Subsystem 3 - Part No: 1K0 951 178 A
Component: Innenraumueberw.003 0203
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000692
VCID: 392EDDA2A554F99F5C4-806C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74B02C96C2B644F74F2-8020
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 3C0 035 195 C HW: 3C0 035 195 C
Component: Radio PM6 012 0021
Revision: 00012000 Serial number: VWZ5Z7H1167070
Coding: 0040400
VCID: 201810C626CE88577BA-8074
8 Faults Found:
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 121
Mileage: 102835 km
Time Indication: 0
Date: 2000.00.00
Time: 14:24:48
00871 - Bass Speaker Front Right (R23)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 121
Mileage: 102835 km
Time Indication: 0
Date: 2000.00.00
Time: 14:24:48
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 121
Mileage: 102835 km
Time Indication: 0
Date: 2000.00.00
Time: 14:24:48
00873 - Bass Speaker Rear Right (R17)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 121
Mileage: 102835 km
Time Indication: 0
Date: 2000.00.00
Time: 14:24:48
00874 - Treble Speaker Front Left (R20)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 121
Mileage: 102835 km
Time Indication: 0
Date: 2000.00.00
Time: 14:24:48
00875 - Treble Speaker Front Right (R22)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 121
Mileage: 102835 km
Time Indication: 0
Date: 2000.00.00
Time: 14:24:48
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 121
Mileage: 102835 km
Time Indication: 0
Date: 2000.00.00
Time: 14:24:48
00877 - Treble Speaker Rear Right (R16)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 121
Mileage: 102835 km
Time Indication: 0
Date: 2000.00.00
Time: 14:24:48
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1301
Coding: 0000144
Shop #: WSC 00046 412 1012544
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
End----------(Elapsed Time: 01:30, VBatt start/end: 12.2V/12.1V)-----------
DSG
FWD
front discs-312 mm
rear discs- 282.
Right hand drive
Thanks a million, i will go and try first thing tomorrow morning and give you feed back. It's 21.40pm in Johannesburg, South Africa and the car is not with me. What is the time there by you? So that I can know what time to go on the forum without inconveniecing you.
Same time zone
don't worry about the times. The forum is open 24/7. I might not always read it directly or answer directly, but you can post any time you like.
![Wink ;)](./images/smilies/icon_wink.gif)
Hi Iichel, once again thank you very much for all.your help, I really appreciate it. The last abs long code on your list beginning with the numbers 163 was accepted. I tried the first and then the second , which were rejected ,so i jumped to the last one on the list which was accepted. After the code was accepted, I left the guy to perform the basic settings with his official vw tool, but he tells me the abs and traction control lights on the instrument cluster won't switch off. He says he is having trouble with the fault code 01486 ( esp system function test), which he cant get rid of.
if you have someone with an official VW tool they can retreive the correct code using SVM
also you could try to play around with byte 6, change it to i.e. 08 and byte 14 to 10
additionally you could try byte 16 bit 4.
and if that doesn't work out... then we see again.
163B600D09220003680C06EC901D0081300000 <-- accepted but ESP error
163B600D09220803680C06EC901D1081300000 <-- byte 6/14
163B600D09220803680C06EC901D1081200000 <-- byte 6/14 + 16 bit 4
163B600D09220003680C06EC901D0081200000 <-- byte 16 bit 4
