Help - Headlight unit electrical problems
AndyM
Drives: 2011 6R
Post by AndyM »
I have a 2011 6R. Passenger side main headlight bulb stopped working (all other bulbs, lights and indicators working). Changed the bulb, still not working. Checked all of the fuses are OK under the steering column and still not working .... I'm stumped now. Does anyone have any ideas what might be causing this or how to fix this?
benzinkopf
Drives: 1.2TSI 105HP DSG7
Re: Help - Headlight unit electrical problems
Post by benzinkopf »
AndyM wrote:I have a 2011 6R. Passenger side main headlight bulb stopped working (all other bulbs, lights and indicators working). Changed the bulb, still not working. Checked all of the fuses are OK under the steering column and still not working .... I'm stumped now. Does anyone have any ideas what might be causing this or how to fix this?
make sure its the right bulb
H7 12V55W.
AndyM
Drives: 2011 6R
Post by AndyM »
Yep - its the right bulb.
benzinkopf
any warning light?
AndyM
Drives: 2011 6R
Post by AndyM »
No warning light. I thought it may be something to to with the DRL's , but I can't see what if anything that would cause.
joe6
Drives: Golf Mk6 GTI (Scirocco gone) Polo 6c GTI
Post by joe6 »
Not an earthing problem if other bulbs working. Check if there is power to the socket. Possibly corroded wiring connectors?
AndyM
Drives: 2011 6R
Post by AndyM »
Is there are connectors that could be the usual subjects I should check first, or is it going to a loooong check of everything I can find or even worse... going to a garage and letting them fault find?
You really need a multi meter to check which side of the connection - +12V or earth is missing.
'main headlight bulb'... H4?
low beam (passenger side) = SB59 fuse
