Polo 6R 1600 TDI Team
Re: Polo 6R 1600 TDI Team
more scans is always better :)
don't forget the headlight washer reservoir level sensor, it's one wire to the instrument cluster. it's a nice addition and you'll have it anyway if you buy the SRA reservoir + pump
i think the step-by-step approach makes sense to some extend, but maybe it's good to transfer all the cables from the cabin to the engine bay in one go.
in your case:
6 wires for LED headlight: 2x (T14/10, /12 and /14)
8 wires for ALWR: 2x (T14/1 /2 /3 and /4)
1 wire for SRA
1 wire for level sensor
16 wires
maybe make it a bit more if you ever plan to install heated windscreen, heated washer jets etc etc.
Turbodruk
Drives: Polo 6R 1600 TDI Team
Post by Turbodruk »
Thanks iichel,
The installment of the all the wiring looms in one go makes sense, yes.
We will talk soon ^^
Hmm. If I'm ever going to do a heated windscreen I'm going for HBA aswell. :lol:
This is not on my list currently, but when I have to replace the windshield, this becomes interesting.
A man can dream. 8)
Turbodruk
Post by Turbodruk »
Good afternoon ladies and gentlemen.
I've manged to put the cable from T6/3 to 10/10 into the auto light switch. The Polo is now error free.
Saturday,02,December,2017,12:46:13:51415
VCDS Version: 17.8.1.0 (x64)  HEX-V2 CB: 0.4407.4
Data version: 20171130 DS276.6
www.Ross-Tech.com
VIN: WVWZZZ6RZBY015008   License Plate: 7E0 0FAULTS
Mileage: 154520km-96014mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 2E 44 56 61 77 0B
VIN: WVWZZZ6RZBY015008   Mileage: 154520km-96014miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAYB)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 EP    HW: 03L 906 023 D
   Component: 1,6l R4 CR td H13 9970
   Revision: --H13---    Serial number:
   Coding: 00114034002401080000
   Shop #: WSC 124697 483 00190
   ASAM Dataset: EV_ECM16TDI02103L906023EP 003007
   ROD: EV_ECM16TDI02103L906023EP_003.rod
   VCID: 78A818B3A25FC6B7621-802C
Readiness: 1110 1000
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AJ    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3416E00B7842514E282D900521100
   Shop #: WSC 02069 000 00000
   VCID: 0654664BD86BA04760D-8052
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
   Part No SW: 6R0 820 045 J    HW: 6R0 820 045 J
   Component: Climatic       25 0660
   Revision: 00 11 25
   VCID: 3536D187F54DFBDFB97-8060
   Revision: B9080001    Serial number: 0771 116170197
   Coding: 3CB029BF48A10000012807906CAB1ED15B80612F60842049200000030000
   Shop #: WSC 54321 321 54321
   VCID: 688848F3F27F5637F21-803C
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 180510 05  54  0403
   Coding: 07302D
   Subsystem 2 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0912
   Serial number: KU0-KU020.05.1010960
   Coding: 48BC30
   Subsystem 3 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 0912
   Serial number: KU0-KU018.05.1011444
   Coding: 48BC30
   Subsystem 4 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Component: E221__MFL-TAS  H31 0033
   Serial number: 0361915
   Coding: 020000
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475     HW: 6R0 919 475
   Component: PARKHILFE 4K  H07 0008
   Revision: --------    Serial number: 71391012733298
   Coding: 100001
   ASAM Dataset: EV_VW250ParkiAssis2 S01006
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 7BA207BF9369EDAF0F3-802E
   Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
   Component: VW10Airbag00L H09 0018
   Revision: --------    Serial number: 003DW00G103P
   Coding: 00304C
   VCID: 42DCBA5BB4035C670C5-8016
   Serial number: 3572SRB40000B8408ACB
   Serial number: 3582SRB40000B8185282
   Serial number: 3516GRB401R9OICD64ET
   Serial number: 3526GRB401T9OICCSB69
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
   Component: KOMBI         H04 0709
   Coding: 540800
   Shop #: WSC 00788 648 00255
   VCID: 3332EF9FFBB9E5EF973-8066
   Revision: B9080001
   Coding: 002200
   Component: IMMO          H04 0709
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6A8C32FBECF36427E45-803E
Address 2E: Media Player 3
Cannot be reached
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 00788
   VCID: 2F3AE3EF1E51C10FF3B-807A
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190 B    HW: 5K0 035 190 B
   Component: Radio RCD510  005 0236
   Revision: 00000001    Serial number: VWZ1Z3P0376022
   Coding: 01000401020001
   Shop #: WSC 00020 790 12345
   VCID: 24101CC34ED772571E9-8070
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0736
   Coding: 030B1A5A
   Shop #: WSC 12345 123 12345
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790237207
Address 77: Telephone (J412)       Labels:| 5N0-035-729.clb
   Part No SW: 5N0 035 729 A    HW: 5N0 035 729 A
   Component: TELEFON       H05 0315
   Revision: 1B001001    Serial number: 00007665485869
   Coding: 0810030080010110
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_UHVUMI 001007
   ROD: EV_UHVUMI.rod
   VCID: 2E04FEEB109BC807F8D-807A
End----(Elapsed Time: 01:30, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
A teaser for what's next:
6C Full headlights, with automatic height adjustment. With help from iichel ofcourse.
Also a OEM alarm will be fitted. If those two things are finished, I'll be looking into fitting R-Line bumpers and maybe headlight washer units, not sure about the latter.
Have a great (remaining) weekend!
Turbodruk
Post by Turbodruk »
Hello!
I managed to get a R-Line bumper for my beloved red Polo, which I fitted last week. Here are some pictures.
I installed the LED headlights and cabling with help from iichel, many thanks to him. I've run into some issues though. The DRL's are not working and high beams only work when pulling the stalk on the left side. Included is an autoscan. I've been told it has to do with the auto light switch iichel has fitted. I haven't had the time to retrofit the AFS module, I will be doing this, don't worry.
[Sunday,24,December,2017,17:15:32:51415
www.Ross-Tech.com
VIN: WVWZZZ6RZBY015008   License Plate: TURBODRUK6CLED
Mileage: 156680km-97356mi   Repair Order:
Gateway Installation List:  7E0 909 901
Sunday,24,December,2017,17:41:37:51415
www.Ross-Tech.com
VIN: WVWZZZ6RZBY015008   Mileage: 156680km-97356miles
   Revision: --------
   Revision: 00 11 25
   Coding: 3CB02FF808090000012806E2FFEB1ED180A273EFE08958D0000000030000
   Coding: 07302D
   Coding: 48BC30
   Coding: 48BC30
   Coding: 020000
5 Faults Found:
03303 - Response Closing Status of Rear Left Door
            008 - Implausible Signal
                    Fault Status: 01101000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 52
                    Mileage: 156682 km
                    Time Indication: 0
                    Date: 2017.12.24
                    Time: 17:37:50
03304 - Response Closing Status of Rear Right Door
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 52
                    Mileage: 156682 km
                    Time Indication: 0
                    Date: 2017.12.24
                    Time: 17:37:50
00978 - Lamp for Low Beam; Left (M29)
            010 - Open or Short to Plus - Intermittent
                    Fault Status: 00101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 92
                    Mileage: 156682 km
                    Time Indication: 0
                    Date: 2017.12.24
                    Time: 17:20:18
00979 - Lamp for Low Beam; Right (M31)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 92
                    Mileage: 156682 km
                    Time Indication: 0
                    Date: 2017.12.24
                    Time: 17:20:18
02898 - Control Circuit for LED Module for DRL and Parking Light; Right
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 52
                    Mileage: 156682 km
                    Time Indication: 0
                    Date: 2017.12.24
                    Time: 17:13:38
   Coding: 100001
   Coding: 00304C
   Coding: 540800
   Revision: B9080001
   Coding: 002200
   Serial number:
Cannot be reached
   Coding: 11230
   Shop #: WSC 00788
   Coding: 030B1A5A
   ROD: EV_UHVUMI.rod
End----------(Elapsed Time: 01:31, VBatt start/end: 12.5V/12.4V)-----------
If someone has any idea what I did wrong I'd be forever greatfull to hear!
Thanks to all people here on the forum and have a very merry Christmas!
if you try with....
3CB02DBF48A10000012807906CEB1ED15A80732F608D38F1200000030000
Good luck and merry Christmas too!
ah yes you probably copied my coding for a 4-door with high beam assist :mrgreen:
iichel wrote: Sun Dec 24, 2017 7:22 pm ah yes you probably copied my coding for a 4-door with high beam assist :mrgreen:
What? I dont understand.
Merry Christmas Michel.
I meant the coding that Turbodruk now has in his BCM. it's based on a 4-door model with high beam assist/return-to-center stalks. ;)
Happy christmas Fernando, enjoy the holidays!
Turbodruk
Post by Turbodruk »
Guilty!
I've used the coding ciclo gave me, and the high beam and low beam work without hiccups! Truly amazing!
The DRL's are not working yet, not sure why, because there's zero faults in the autoscan.
Sunday,24,December,2017,21:50:24:51415
www.Ross-Tech.com
   Revision: --------
   Revision: 00 11 25
   Coding: 3CB02DB848210000012807906CEB1ED15A80732F608D38F1200000030000
   Coding: 07302D
   Coding: 48BC30
   Coding: 48BC30
   Coding: 020000
   Coding: 100001
   Coding: 00304C
   Coding: 540800
   Revision: B9080001
   Coding: 002000
   Serial number:
Cannot be reached
   Coding: 11230
   Shop #: WSC 00788
   Coding: 030B1A5A
   ROD: EV_UHVUMI.rod
End----------(Elapsed Time: 01:30, VBatt start/end: 14.7V/14.9V)-----------
Next up is the AFS! Wohoo! :D
Are you sure your BCM 7E0 is for T6 with LED headlights?
However, you should check the DRLs with the hand brake DOWN... :?: ...your BCM is coded so that the DRLs OFF when the handbrake is UP.
He bought a bcm with the same reference as mine, 090 Z4Y, should be ok
iichel wrote: Mon Dec 25, 2017 9:38 am He bought a bcm with the same reference as mine, 090 Z4Y, should be ok
I also have the solution to the DRLs problem, but I am waiting for the reply to my suggestion regarding the handbrake.
Turbodruk
Post by Turbodruk »
Hey Ciclo!
I was busy eating myself to death, and now I awakend from my slumber. Unfortunately the DRL’s are not working with handbrake off.
Thanks for your quick replies!
... :lol:
It may be necessary to add a 0.5mm2 wire from the auto lights wiring -made by iichel for you- to the BCM, from the coupling linking the new automatic light switch (T10/9) to the BCM T73b/29.
By the way iichel, please post here your diagram for auto lights wiring you sell.
I explain you:
This is your original connector, without wire (3) for the DRLs signal, this is because the Bluemotion with BCMs 6R0/7H0 use another signal due to the Start/Stop system.
(sorry... turbodruk ... without 'c') :)
Example diagram
The new BCMs 7E0 are parameterized in a different way, and this signal can be one of the parameters that were changed. Unknown to me and to most mortals. :lol:
I am convinced that adding this wire your DRLs will work, taking into account that the rest of the electrical installation for the DRLs is correct (from the BCM to the LED headlights) and that your BCM supports LED headlights. :wink:
Hi Fernando, I take the exact diagram as in your PDF for the auto light installation. I can confirm T17/3 is not wired in Turbodruks car.
I'm not sure whether the position lights are working in his car (DRL led in lower brightness).
In my Polo Bluemotion, the T17/3 wire is also not present but the LED DRL always worked well, both with bi-xenon and LED headlights.
