I believe so... I was under the impression that the coding that ciclo gave me set everything up in advance.
I have checked through the coding the Light sensor function is active.
I will post an auto-scan when I get home from work
If the 'Leaving Home function' is working it means that the wiring installation is correct.graylscott wrote: ↑Thu Jan 18, 2018 12:11 pm Okay, so here it goes!
First of all, I want to say what feels like my 1000th thank you to you Fernando! I received my gift earlier on this week!
This morning, I finally got enough time away from work to play!
So, all is working with the headlight switch as I would expect. All lighting is now controlled via the BCM.
However....
I still have no auto-lights.
But the plot thickens......
When I set the switch to Auto, the lights do not come on whether it is dark or light outside.
But....
When the switch is set to auto, the 'Leaving-Home' works as expected. i.e. only when it is dark, and only when the headlight switch is set to auto.
Which surely means that both the light sensing feature of the RLS is working correctly, and the 'Auto' setting on the headlight switch is working correctly.
I ran some output tests on each of the individual lights, and sure enough they are all controlled via the BCM.
Any ideas?
Gray
This was my thinking, which is why I found it so strange.
I ordered a new light switch thinking that this may be the problem. Mine came with one of those auto-headlight retrofit kits from China. It has a VW part number on it, but i suspect it is not genuine.
I'm sure this isn't the problem, but I should tell you that I have not wired in the auto-dimming mirror. I have no rear window!
Don't apologise! I have been off the radar all week (very busy with work), when I should have been on here metaphorically kissing your feet! So I am sorry!
...graylscott wrote: ↑Tue Jan 23, 2018 9:00 am I have now ordered 2 x 4G0907697G and will hopefully be posting pictures of my fully functional LEDs shortly!
