[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Removing lock barrel from door handles. - UK-POLOS.NET - THE VW Polo Forum
I need to replace the door handle and and the lock on my car after a job gone wrong. Any ideas how the Barrel from my old lock comes out so I don't have to get a new key?
madmatt wrote:just get door handles from the rear of a 4 door golf and get central locking kit from ebay there only 20quid and comes with key fob to opperate um
i wouldnt be able to tell you how to do it, but when i got the crap door from the scrap dealer, he took no more than about 30 seconds to undo a couple screws and remove first the lock barrel and then the entire handle. easy-as.
Deadcat, just search for 'locking' and then click "Show results from: Motoring - Accessories" or whatever the section's called.. quite a lot of kits going in there, might be tempted at some stage..
deadcat wrote:where on ebay bee them?
I wanna de-lock the boot.
if your deelocking the boot u dont need central locking kit u need a solinoid kit from big boys toys i bet u be able to get them of ebay too
basical when u press the button it pops open
i'll add my bit of advice! if you are taking out the barrel, put the key in the lock, then all the pins will be in the correct position and it will slide easily back into your new lock!
