Posts: 7851 Joined: Sun Feb 24, 2013 10:20 am
Post
by ciclo » Mon Jan 15, 2018 6:17 pm
govindsharma wrote: ↑ Mon Jan 15, 2018 1:39 pm
Dear Good Evening
Here is the final result in my car of TPMS.I had installed all parts of TPMS today with Antenna and tire sensors.I had given power to Antenna from fuse 17 which is vacant. CAN high and low from PDC unit.
As expected after my instructions for your 6R. Great.
But please tell me if air is low in any of the tire then where it indicate either in IC with low pressure indicator or in four wheel figure which is in MFD.
It will do it this way:
https://www.youtube.com/watch?v=1TnpHOz ... tu.be&t=39
Post
by ciclo » Mon Jan 15, 2018 6:19 pm
iichel wrote: ↑ Mon Jan 15, 2018 1:44 pm
i'm not sure about SB17, it's listed as the fuse for the windscreen washer pump.
it it can be OK. i think it should be a +30 (constant power) for the TPMS high.
You are uninformed, as usual ...always making mistakes.
Posts: 6420 Joined: Fri Nov 14, 2014 2:14 pm
Post
by iichel » Mon Jan 15, 2018 7:15 pm
very good, there is a new retrofitted +30 wire in place for this mod. all clear.
govindsharma
Posts: 109 Joined: Thu Mar 03, 2016 3:17 pm
Drives: polo 1.2 petrol HighLine
Post
by govindsharma » Tue Jan 16, 2018 3:10 am
Dear ciclo Sir Good Morning
Yes as per your instruction i had done all mods done with good results.Thanks a lot for your kind support and useful instructions..
Dear iichel Sir this fuse is vacant in my car and ciclo sir made this fuse extension for +30 in my car see this image.
Thankyou.
govindsharma
Post
by govindsharma » Tue Jan 16, 2018 3:27 am
Saturday,13,January,2018,17:59:54:49450
VCDS Version: 16.8.0.3
Data version: 20161010 DS255
www.Ross-Tech.com
VIN: MEXD16603GTGOVIND License Plate:
Mileage: 6340km-3939mi Repair Order:
Chassis Type: 60 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 44 56 65 0B
VIN: MEXD16603GT082427 Mileage: 6340km-3939miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CJLA) Labels: None
Part No SW: 03E 906 019 AQ HW: 03E 906 019 AQ
Component: SIMOS11.2 H04 1968
Revision: --H04--- Serial number:
Coding: 00110016032400000000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM12MPI02103E906019AQ 001001
ROD: N/A
VCID: 73E5B5AADA7402DAAD-8026
No ASAM data for: "EV_ECM12MPI02103E906019AQ" (VW25)
Readiness: 0000 0100
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 6R0 907 379 BP HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0003
Serial number: --------------
Coding: 60DD2763212B18C20618E46B845818000000
Shop #: WSC 00000 000 08192
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH_VW25.rod
VCID: 0D11C352DC90742ADB-8058
Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb
Component: LENKW.SENSOR H06 0060
Serial number: 090465LEA0003X
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF3949EE1365FB2D2-802A
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 41892F62D848E04AEF-8014
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 352161207
Coding: 3AB02BBF48A3000001380FB07E8B9E905FC0616F60AC20C0200000030800
Shop #: WSC 12345 123 12345
VCID: 2A5B68CE453E0312DE-807E
Subsystem 1 - Part No: 5K7 955 559 B
Component: RLS 311215 03 37 0059
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 020 2551
Serial number: 13202848160111221608
Coding: 350000
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 020 2551
Serial number: 13202849160107223746
Coding: 040000
Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Serial number: 0111607164000748AB2B
Coding: 240000
Subsystem 5 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 019 1552
Serial number: 13102728160108150857
Subsystem 6 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 019 1552
Serial number: 13202729160111111032
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 K HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0106
Revision: -------- Serial number: 35821404004439
Coding: 308001
ASAM Dataset: EV_VW75XParkAssis4K 001004
ROD: EV_VW75XParkAssis4K.rod
VCID: 3A7B588EBD9EB392AE-806E
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW013KE03
Coding: 003036
VCID: 49993742E878280A37-801C
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H03 0805
Coding: 140A01
Shop #: WSC 17218 938 12345
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 479D317AFE6CDE7A21-8012
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 002300
VCID: 68DFD2C69BB2F10208-803C
Address 20: High Beam Assist. (J844) Labels: 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 040401E200000000000000
VCID: 2E5364DE71D66F3202-807A
Component: IMMO H03 0805
VCID: 6ADBA8CE8DBEC3121E-803E
Address 44: Steering Assist (J500) Labels: 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000001000000
ROD: EV_SteerAssisNSK_VW12.rod
VCID: 41892F62D048E04AEF-8014
Address 56: Radio (J503) Labels: User\6RD-035-187.lbl
Part No SW: 6RD 035 187 A HW: 6RD 035 187 A
Component: MIB2-S-R-CN 025 0210
Revision: -----001 Serial number: 12765GD0082357
Coding: 00000440000000
Shop #: WSC 00081 790 00184
VCID: 45813B72CC60CC6AD3-8010
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 30000000060895
ROD: EV_RDKBERU30_VW36.rod
VCID: 377D41BA8E8CAEFA51-8062
End-------------------------(Elapsed Time: 03:02)--------------------------
Post
by ciclo » Tue Jan 16, 2018 6:17 am
Stunning!
govindsharma
Post
by govindsharma » Wed Jan 24, 2018 1:56 pm
Dear all Indian Members GOOD NEWS how have polo with electric fold side mirrors they may make them auto fold with remote without cutting any wire or void warranty(
OEM ) Ciclo sir made this possible in my polo i will be very thankful to him for giving me such a kind support.I am sharing video of it and will post autoscan soon in one more day. Ciclo sir explain rest of it.
Thank you .
Post
by ciclo » Wed Jan 24, 2018 2:29 pm
Thanks to you , in reality you, and only you were who be able to find the correct encodings with some basic instructions that I gave you.
The secrets of all this is in the reference number of the WRMs and their codings, therefore we'll have to wait for you to post the autoscan.
The important thing is that it has been achieved in a 6R
RHD IND. OEM.
I start to have a special affection for your 6R.
Thanks for sharing the video.
benzinkopf
Posts: 859 Joined: Wed Apr 02, 2014 4:01 pm
Drives: 1.2TSI 105HP DSG7
Post
by benzinkopf » Wed Jan 24, 2018 5:51 pm
Congratulations!!!! what a nice mod!
btw, if i understand correctly, the side mirror will fold automatically by locking the car. and it will then unfold automatically by ignition on? Can the unfold process enable when unlocking the door?
as i’m looking forward for the foldable side mirror installation, i will want to install side mirror doorpuddle leds. if the unfold process is not during the unlocking process, it would be awkward to see the doorpuddle lights switch on while the side mirror is folded. [emoji848] any idea?
Post
by ciclo » Wed Jan 24, 2018 6:14 pm
benzinkopf wrote: ↑ Wed Jan 24, 2018 5:51 pm
Yes, only. That's already an achievement in a 6R RHD IND.
Puddle lights unfolding with remote.
VK70
Posts: 9 Joined: Mon May 22, 2017 5:43 am
Drives: VW Vento 1.2 TSI Highline
Post
by VK70 » Thu Jan 25, 2018 10:08 am
govindsharma wrote: Dear all Indian Members GOOD NEWS how have polo with electric fold side mirrors they may make them auto fold with remote without cutting any wire or void warranty(
Thank you .
Nice.I have been trying to enable this on my Vento TSI.Can you please explain how you managed to do this?Was it through coding alone?
Sent from my ONEPLUS A5000 using Tapatalk
Post
by ciclo » Thu Jan 25, 2018 2:19 pm
6R0 959 802 BH HW: 6R0 959 802 BH Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003
8 612
Serial number: KU0KU021021440523980
Coding:
1400B3
6R0 959 801 BC HW: 6R0 959 801 BC Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003
8 611
Serial number: KU0KU004101300011381
Coding:
0400B3
and all the functions will work like a charm!...
auto folding mirror function too.
govindsharma
Post
by govindsharma » Thu Jan 25, 2018 2:36 pm
Dear sir autoscan of car
VIN: MEXD16603GOVIND
ROD: N/A
Coding: 01
Revision: V0000000
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 802 BH HW: 6R0 959 802 BH Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 8612
Coding: [b][color=#FF0000]1400B1[/color][/b]
Subsystem 3 - Part No SW: 6R0 959 801 BC HW: 6R0 959 801 BC Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 8611
Coding:[b][color=#FF0000] 0400B3[/color][/b]
Coding: 240000
Coding: 308001
Coding: 003036
Coding: 140801
Revision: B9081001
Coding: 002300
Revision: AA001001
End-------------------------(Elapsed Time: 03:06)--------------------------
Coding:
1400B1
Coding:
0400B3
