Hi guys, in the next week or so I’m looking to do the modification of adding a light in the glovebox of the wifes 2016 Blue GT.
Just a quick question or two. Firstly I have the light already (from eBay) but need to source the correct VW wiring connector, does anyone know the part number of this please .
Secondly, where do you tap the 12v from to ensure it only works with ignition on please ?
Thanks.
Glovebox light retrofit
Re: Glovebox light retrofit
1x 1J0972702
i'd take the ignition live from the fuse box.
Norbreck21a
Thanks iichel
- CNK
- Drives: 6R
Norbreck21a
Thanks both. One final question please. If I have to remove the discover media unit from inside the glovebox before I can remove the box itself, does this cause any issues when plugging it back in. I know in the old days, stereo units used to ask you for a Pin code to get them working again. Can I assume that the unit is already "registered" with the CAN Gateway, therefore when plugging it back in again should automatically re-activate it ?
that is correct. don't worry.
Norbreck21a
Thanks guys
