Hi, I’m a new entry and I’m writing from Italy. I am a Polo 6R R-line owner. I’m fitting a bixenon OEM set with kufatec adapters but I haven’t got installing guide to connect the five additional wires and six wires from pins 10-12-14 coming from headlights.
My BCM part number is: 087K.
Can sameone give me an installing guide? If not, is there someone giving an help?
Thanks in advance
Retrofit bi-xenon oem
Re: Retrofit bi-xenon oem
you'll need to upgrade your BCM as well, since your current BCM doesn't support OEM bi-xenon with LED DRL.
ciclo can help you, if you'd like to upgrade your BCM to BCM max 7E0.
Post a VCDS autoscan
Post pictures from fuse box, light switch wires (both sides), relay carrier, dimmer connector
firegrafik can maybe source a 7E0 BCM
NicolòRigamonti
thank you for your answear. now i can post my old scan:
Chassis Type: 6N0
Scan: 01 02 03 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZDY158389
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAYB) Labels: None
Part No SW: 03L 906 023 MG HW: 03L 907 425 B
Component: 1,6l R4 CR td H33 9601
Revision: --H33--- Serial number:
Coding: 00254016000400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM16TDI02103L906023MG 003006
ROD: EV_ECM16TDI02103L906023MG.rod
VCID: 77F79A787F56
Readiness: 0000 0000
Address 02: Auto Trans Labels: None
Part No SW: 0AM 300 060 F HW: 0AM 927 769 D
Component: GSG DSG AG7 431 3650
Revision: 00043014 Serial number: CU501211296246
Coding: 0000020
VCID: 2D5B7810CD8A
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H02 0002
Serial number: --------------
Coding: 21DD2885412800C884171471825A00420905
Shop #: WSC 01383 785 00200
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
ROD: N/A
VCID: 8F274298E7C6
No ASAM data for: "EV_Brake1ESP90iBOSCH" (VW25)
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 3875594432C8
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 M HW: 6R0 937 087
Component: BCM PQ25 H+4 H32 0407
Revision: BF032001 Serial number: 0540 341121461
Coding: 7CB0293F08B3000000200C006D6B9CD00000412F60860040200000000000
Shop #: WSC 12469 483 00190
VCID: 47972AB84F36
Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB
Component: J386__TSG_FT 008 1621
Coding: 18BC30
Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD
Component: J387__TSG_BT 008 1621
Coding: 18BC30
Component: VW10Airbag01S H10 0020
Revision: -------- Serial number: 003GX01HCW3V
Coding: 003153
VCID: 4A91138C5C24
Driver's Airbag Crash Sensor:
Serial number: 3575HRB40104UOB6F097
Passenger Side Airbag Crash Sensor:
Serial number: 3585HRB40144UOB6COUB
Driver's Rear Airbag Crash Sensor:
Serial number: 3515RRB40651O70UJ9BN
Passenger's Rear Airbag Crash Sensor:
Serial number: 3525RRB405H1NOT4F872
Part No SW: 6R0 920 861 K HW: 6R0 920 861 K
Component: KOMBI H03 0306
Serial number: 00000014191221
Coding: 540A01
ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01720
ROD: EV_DashBoardUDSJCIPQ25_VW25.rod
VCID: 3D7B48501DEA
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H32 0407
Revision: BF032001
Coding: 002000
VCID: F0E521649A38
Address 25: Immobilizer (J285) Labels: 5K0-920-xxx-25.clb
Component: IMMO H03 0015
Serial number:
ASAM Dataset: EV_ImmobUDSJCIPQ25 A01003
ROD: EV_ImmobUDSJCIPQ25_VW25.rod
VCID: 3D7B48501DEA
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11210
Shop #: WSC 00788
VCID: 30656164DAB8
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5M0 035 156 D HW: 5M0 035 156 D
Component: Radio 553 0555
Revision: R0553007 Serial number: VWZ5Z1M0792233
Coding: 0000020002
VCID: 2A51730CFC64
End ---------------------------------------------------------------------
Chassis Type: 6N0
VCID: 77F79A787F56
Coding: 0000020
VCID: 2D5B7810CD8A
ROD: N/A
VCID: 8F274298E7C6
Revision: V0000000
VCID: 3875594432C8
VCID: 47972AB84F36
Coding: 18BC30
Coding: 18BC30
Coding: 003153
VCID: 4A91138C5C24
Coding: 540A01
VCID: 3D7B48501DEA
Revision: BF032001
Coding: 002000
VCID: F0E521649A38
Serial number:
VCID: 3D7B48501DEA
Coding: 11210
Shop #: WSC 00788
VCID: 30656164DAB8
Coding: 0000020002
VCID: 2A51730CFC64
Read all this topic, all links in the guide, etc...
viewtopic.php?f=56&t=69826&hilit=pave#p520855
NicolòRigamonti
Do I need to upgrade my bcm and make some extra wires ? Ciclo, do you do those wires ?
But I found this diagrams on this forum. Is it wrong?
Thank you for the answers
Yes"."NicolòRigamonti wrote: Tue Feb 13, 2018 11:40 am Do I need to upgrade my bcm and make some extra wires ?
Yes.
NicolòRigamonti
Ok, and what is the complete code of BCM that I must buy ?
