Windscreen Washer Polo GTI 65
j0rd4n500
Drives: 1.2 match edition, polo 6c gti
Post by j0rd4n500 »
So I have a POLO GTI on a 65 plate.
a few weeks back my light came on for no windscreen washer fluid and I was going on a long drive so didn't want that annoying beep/flash that happens. So I just added a litre of water as had no washer fluid. Come the cold weather and its froze and silly me kept trying to use it. I have since topped up with unconcentrated -27 degree washer fluid and a bit of warm water. So hopefully there is good amount of fluid in there and its now 7c so ice will have melted. No fluid is coming out of the back front or headlight washers. Will this be a fuse or moter blown ?
Re: Windscreen Washer Polo GTI 65
could very well be a broken fuse or worst case scenario a broken motor... hard to say.
j0rd4n500
Post by j0rd4n500 »
iichel wrote: Mon Mar 05, 2018 10:11 am could very well be a broken fuse or worst case scenario a broken motor... hard to say.
Any idea what fuse itis? I had a look on this site:
http://fusesdiagram.com/volkswagen/fuse ... lo-6r.html
The fuse it says for the washers it say's is also the Rear window wiper motor but the wiper is moving fine. So not sure if it will be that one.
no for the GTI you need the fuse layout for a polo 6C
https://drive.google.com/open?id=0BxYPV ... m1uR256Ums
j0rd4n500
Post by j0rd4n500 »
iichel wrote: Mon Mar 05, 2018 10:48 am no for the GTI you need the fuse layout for a polo 6C
Cheers, was gonna say it didn't seem to match up before. Looked pulled the 7.5 fuse like it said and like I thought it has blown. So hopefully the motor is fine. Will pop to get one on lunch at lunch thanks again mate.
Dan34
Drives: GTI+
Post by Dan34 »
j0rd4n500 wrote: Mon Mar 05, 2018 11:14 am
Same happened with my 6C R-Line today, replaced the fuse and all is good!
whitty_77
Drives: Polo 17
Post by whitty_77 »
Think im in same boat
Picked one up today and will try tonight
