Poor quality audio from TPK Bluetooth system
- Drives: POLO R-Line 1.2 TSI
Re: Poor quality audio from TPK Bluetooth system
This is the cable I have https://i.imgur.com/dRgBL2q.jpg (Would be helpful if the forum let you directly upload photos)
Ok, those wires go into that little black plug you have there which plugs into the quadlock on the back of the radio
The reason they dont pin it is you may already have a black plug in place, and need to add the wires to this plug instead
Can you check whats fitted and well go from there?
As for direct upload of photos, weve looked into that, but its more complicated than it sounds to get it working (plus it eats up soooo much of our server space)
That cable is the direct aux feed into the radio by the way - what radio model have you got?
Rcd310 with dab, I kindof gathered that but where do I wire it to?
You’ll need to pull the radio out and post a pic of the quad lock connector on the car loom side that plugs into the back of the radio. Then we can determine what’s already in place
okay here's the pics https://i.imgur.com/0pqiD7c.jpg[img]
Not sure if both photos can be seen as when I click the link they don't show but in the imgur app there both there?
i only see this one ![Image](https://i.imgur.com/0pqiD7c.jpg)
It looks like its already pinned, so youll need a different cable as the aux is already going off to the TPK
Is there a way I can have it as the only aux output is from the tpk using the cable i have?
Can someone help a new polo owner please TPK Bluetooth system
Hi would someone know how to change the tpk back to english written language, i done a factory settings on it and pressed english uk but instead it went to the obove selection which i think is german. Now its all written in a foreign language that i cant understand and i dont know how to go back to the options of language.
Please help someone
Please help someone
Language in German is Sprache or Sprachen depending on its use
Thank you alexperkins but do you know how to get the tpk back in english language please
Einstellungen> Gerät> Sprache
Settings > Device > Language
Hi m8 took radio out but couldn't find where to plug cable in have got a photo of this
