Non starter
Non starter
VW Polo 1998 1.4 petrol, tries to start then cuts out after a few seconds, appears to have no engine light, it loses fuel pump electric feed and sparks together at the same time, have checked all the obvious fuses etc, it occurred after being left for a while battery went very flat can’t get obd to read, any help would be appreciated
Re: Non starter
Sounds like an immobiliser issue. That’ll cause it to start then stop
Check all the fuses including the battery ones
Re: Non starter
Have checked all fuses including the ones by the batteryalexperkins wrote: Sat Mar 10, 2018 11:05 am Sounds like an immobiliser issue. That’ll cause it to start then stop
How can I check the immobilser
