Polo match locking
stephend92
- Drives: 1.2 Match
Polo match locking
just joined as I have bought a 2008 polo match.
This has probably been posted 100 times but the key I got with the car isn't the original nor is it a fob for remote Central locking. I was just wondering if the match came with the central locking and the key fob?
Re: Polo match locking
My match had remote central locking. Yours probably does but no longer has the correct key
Alex, remember the OP is talking about a 9N3 Polo, so maybe they did not get remote central locking as standard.
Sorry, I linked the wrong brochure there. The 9N3 match had it an option but I think the runout 2008 models had it as standard. Its possible yours hasnt got the right key. It used to be one remote key one normal key.
stephend92
- Drives: 1.2 Match
Brilliant thanks for the help!. Also, when i push the lock button on the drivers door when inside the passenger door locks then unlocks straight away. any reason why this is?
Are you sure that it is not doing that when you use the key in the driver's side door as well?
Thats quite common when the lock has a faulty microswitch so its not in a state it believes it can lock. The fix is to replace the lock ultimately. The microswitches arent readily available for the 9N locks
stephend92
- Drives: 1.2 Match
Yeah it locks fine with the key. Just when you push the door button it pops back up
I asked the question but I can't give you an answer as to why that should be happening, I'd guess that pressing the "lock" button inside the car gives out a short duration pulse to the locks, whereas you turning the driver's door key lock applies a longer duration voltage change, or a stream of pulses?
stephend92
- Drives: 1.2 Match
Yeah it seems that way. Can't figure it out.
Hello, were any of you guys able to do the remote locking.
