DJ's Polo 6R
claudio-dj
Drives: Polo 6R - 1,6 TDI - Highline
Re: DJ's Polo 6R
Post by claudio-dj »
oh hello firegrafik ... I honestly do not know why the message did not reach you. anyway I would be looking for a bcm max B or C. could you help me?
Inviato dal mio SM-G950F utilizzando Tapatalk
claudio-dj
Re: DJ's Polo 6R
first of all thank you. unfortunately I can not answer you in private and I do not understand why !!! However I said, how do I contact the seller to buy something?
Re: DJ's Polo 6R
claudio-dj wrote: Tue Mar 27, 2018 9:52 am then, anticipating that firegrafik does not respond, meanwhile I would like to start organizing the wiring ... do you have any scheme to refer to? I already have the wiring for the headlights, but the ones for the car selector no. where can I find patterns and materials for the realization?
Autoscan. (fresh/recent)
viewtopic.php?f=56&t=71076#p531681
We need pics from: light switch connector both sides (wires colors), dimmer conector, relays carrier, fusebox.
The following guide is an example so you can see the images we need from your 6R.
https://drive.google.com/file/d/1cXw67i ... sp=sharing
It's approximately what you'll have to do. Your 6R is not the same as this 6R.
Re: DJ's Polo 6R
claudio-dj wrote: Tue Mar 27, 2018 6:27 pm first of all thank you. unfortunately I can not answer you in private and I do not understand why !!! However I said, how do I contact the seller to buy something?
You can contact firegrafik privately as of this moment, 10 posts are needed in the forum to be able to do it.
:wink:
claudio-dj
Re: DJ's Polo 6R
Ah..okok thanks ciclo [emoji16]
claudio-dj
Re: DJ's Polo 6R
[emoji24]Image
Re: DJ's Polo 6R
try again? :wink:
alexperkins
Site Admin
Re: DJ's Polo 6R
Post by alexperkins »
Your PMs will work now
claudio-dj
Re: DJ's Polo 6R
Thank you [emoji4]
Hi ciclo these are the data you asked me:
Tuesday,27,March,2018,20:22:19:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ6RZAYCLAUDIO   License Plate:
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 10 15 17 19 25 2E 37 44 56 77
VIN: WVWZZZ6RZAY091951
37-Navigation -- Status: Malfunction 0010
Address 01: Engine (J623-CAYB)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 D    HW: 03L 906 023 D
   Component: R4 1.6l TDI   H13 9978
   Revision: --H13---    Serial number:
   Coding: 00114016002400080000
   Shop #: WSC 12469 483 00190
   ASAM Dataset: EV_ECM16TDI02103L 003013
   ROD: N/A
   VCID: 2757E3DC5E13D526F59-8072
No ASAM data for: "EV_ECM16TDI02103L" (VW36 *)
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 R    HW: 6R0 907 379 R
   Component: ESP8.2i front H04 0002
   Revision: --------
   Coding: 210228E3417600B3842E14E782D200421300
   Shop #: WSC 02069 000 00000
   VCID: 4D9B7174102FDF762F5-8018
   Part No SW: 6R0 907 044 F    HW: 6R0 907 044 F
   Component: Climatronic   H11 0610
   Revision: V0000000
   VCID: 36693E9881B9BCAE7EF-8063
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 087 B    HW: 6R0 937 087 B
   Component: PQ25 BCM      H09 0025
   Revision: BF009001    Serial number: 9955A274092318
   Coding: 3CB02BBF48F32F00933806C07DAB0ED1B08841FF608400402000
   Shop #: WSC 00528 264 87338
   VCID: 3C7D2CB0BF9566FE88B-8069
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 220512 05  54  0403
   Coding: 0730AD
   Subsystem 2 - Part No SW: 6R0 959 801 H    HW: 6R0 959 801 H  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  005 0803
   Coding: 08BC30
   Subsystem 3 - Part No SW: 6R0 959 802 K    HW: 6R0 959 802 K
   Component: J387__TSG_BT  005 0803
   Coding: 08BC30
   Subsystem 7 - Part No SW: 5K0 959 542     HW: 5K0 959 542
   Component: E221__MFL-TAS  H05 0010
   Coding: 820000
   Subsystem 8 - Part No SW: 6R0 959 811 B    HW: 6R0 959 811 B
   Component: J388__TSG_HL  005 0803
   Coding: 08BC32
   Subsystem 9 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  005 0803
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47301108002392
   Coding: 308001
   Shop #: WSC 00788 648 00255
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E7926B8A18974EEA6F-806B
   Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
   Component: VW10Airbag005 H09 0018
   Revision: --------    Serial number: 003DW0072UYZ
   Coding: 003035
   Shop #: WSC 124697 483 00190
   ROD: EV_AirbaVW10BPAVW250_VW24.rod
   VCID: 42815248D571100EC27-8017
   Crash sensor for side airbag; driver side:
   Serial number: 3572SRB400009C58AA2E
   Crash sensor for side airbag; passenger side:
   Serial number: 3582SRB400009C04F335
   Crash sensor for side airbag; rear driver side:
   Serial number: 3516GRB402L9GRDKTBEK
   Crash sensor for side airbag; rear passenger side:
   Serial number: 3526GRB40259VDE6S4P$
   Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
   Component: KOMBI         H03 0505
   Coding: 140A01
   Shop #: WSC 00985 264 92603
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 336F078C9ACBA986591-8066
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 6R0 937 087 B
   Component: GW-K-CAN TP20 0025
   Coding: 002200
   VCID: F0E54880235D529EE43-80A5
   Component: IMMO          H03 0505
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
   VCID: EAD15AE80D81A84EAA7-80BF
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Component: SG EXT.PLAYER H13 0090
   Revision: A1001003    Serial number: 7667587623
   Coding: 020000
   VCID: 2649EED85119CC2ECEF-8073
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 Q    HW: 1T0 035 680 Q
   Component: RNS-MID       H08 5238
   Revision: AB001001    Serial number: VWZ6Z7N5140821
   Coding: 0C000440040000A10001
   Shop #: WSC 05314 123 12345
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V15  8515
2 Faults Found:
00877 - Treble Speaker Rear Right (R16)
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 211
                    Mileage: 178400 km
                    Time Indication: 0
00876 - Treble Speaker Rear Left (R14)
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 211
                    Mileage: 178400 km
                    Time Indication: 0
   Part No: 6R0 423 156 A
   Component: LenkhilfeTRW        V275
   Coding: 10130
   Shop #: WSC 00000
   VCID: 2E5916F8EDE9846E36F-807B
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
2 Faults Found:
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 211
                    Mileage: 178400 km
                    Time Indication: 0
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 211
                    Mileage: 178400 km
                    Time Indication: 0
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00AAAA63112800
   Coding: 0400000100010110
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3B7F2FACB29B61C6811-806E
End
Re: DJ's Polo 6R
ciclo wrote: Tue Mar 27, 2018 6:51 pm
claudio-dj
Re: DJ's Polo 6R
I can not open your post from Tapatalk ... what is not clear to you precisely?
Re: DJ's Polo 6R
I think he wants to see the bottom side of the light switch connector as well. Just rotate it around, so he can see the other side.
1 --> https://uploads.tapatalk-cdn.com/201803 ... 2fd063.jpg
2 --> flip
3 --> photo
4 --> post photo
8)
claudio-dj
Re: DJ's Polo 6R
Ah..okok!!
claudio-dj
Re: DJ's Polo 6R
Ciclo,you did not let me know if the data you requested me are complete !!!
Re: DJ's Polo 6R
Yes, all the information is complete. Many thanks Claudio.
My recommendation as a good friend is that you buy the B wiring that I have for sale in the forum, you will save money and time. Especially for the technical support that you will need.
But even at this time I couldn't manufacture your wiring looms because of the large amount of work I have. Maybe the next week or the next.
What the hell happened to your current light switch? :)
