Retrofitting LED headlights & BCM Max Adaptation+Auto Headlight with CH/LH on 2013 6R
vento2013
Drives: 6R Polo(Vento)1.6TDi, Skoda Fabia 1.2MPi
Re: Retrofitting Bi-Xenon & BCM Max Adaption+Auto Headlight with CH/LH on 2013 6R
Post by vento2013 »
iichel wrote: Mon Apr 02, 2018 9:35 am I would recommend the 6Q0941334. dimmer without headlight regulator.
Here in India this switch never came in any car. So not possible to get from local VW dealer. In eBay too not available. so bought 6R0941333.
iichel any particular reason to get only that switch?
yes because the headlight range regulator won't work and here in europe that's a failure for MOT
vento2013
Post by vento2013 »
iichel wrote: Mon Apr 02, 2018 10:33 am yes because the headlight range regulator won't work and here in europe that's a failure for MOT
Ok. but now I already bought 6R0941333 for just 10 Euro. And I am not able to find 6Q0941334.
For a time being will use 6R0941333. Later will buy correct part.
vento2013
Post by vento2013 »
Hi, Fernando,
I have this wiring for Dimming mirror and RLS
from Ali express.
when I compared it with your Dimming mirror and RLS wire. Mine is different. So I don't want any confusion while installation.
So please I request you to make Dimming mirror and RLS wire too. Sorry for making changes in my request.
Thank you
Ok, I'll do the wiring for RLS and auto dimming mirror (25€ paypal fees inc), along with the other wiring looms requested (BCM adaptation + auto lights) .. I have to order the RLS connector from my VW dealer (takes two days to arrive) I beg you a little patience.
If you install LED headlights you need this wiring for the fog lights: (foglights with BCM control)
https://www.ebay.de/itm/VW-Polo-6R-6C-K ... 2c5ff0c895
I'll provide you the diagrams for you to install it correctly.
50% made.
vento2013
Post by vento2013 »
ciclo wrote: Mon Apr 02, 2018 6:57 pm Ok, I'll do the wiring for RLS and auto dimming mirror (25€ paypal fees inc),
OK
Cool down Ciclo, did I ever said I am in hurry, make wire urgently! in my entire topic? No :|
in my previous post i just requested you to make dimming mirror+RLS wires thats it. I am waiting patiently.
Ok. I will buy this wire.
Thank you.
Made 90%
The RLS connector hasn't arrived yet. It is expected to arrive tomorrow.
Please take a picture from the T5 Left taillight connector.
T5/1 wire should be blue/black, belongs to Reversing Light.
Because your Vento is with manual transmission the original T5/1 wire must be isolated. to be able to install a new wire from T73b/12 to T5/1.
vento2013
Post by vento2013 »
ciclo wrote: Wed Apr 04, 2018 11:58 am Made 90%
:D Nice
Yes its blue/black
That red taped wire is for reverse camera.
:wink: Many thanks.
Made 100%. (nice electrical installation)
I still have to do the installation guide, your Vento has extra wires compared to other installation guides that I did for Vento IND.
It's not necessary that you download the images, they will be included in the installation guide so you can view them correctly.
When I post the installation guide here I will send you my email by private message. :wink:
vento2013
Post by vento2013 »
Thank you Ciclo. :D
one question, now T5/1 wire blue/black, belongs to Reversing Light and i used this wire to power reverse camera. After new installation, wire from T73b/12 to T5/1 can be used to power camera?
and
I have one request, here in India it is difficult to get VW parts, that too terminal pins impossible.
I have T14 connector with pins, but I need terminal pins of DRL and SCL which connects to BCM. I would be grateful to you if you could give those terminal pins.
vento2013 wrote: Thu Apr 05, 2018 6:51 pm Thank you Ciclo. :D
I'm going to add a red Butt terminal to the new wire for reversing light to connect the red wire that sends the signal to the RVC. :wink:
vento2013 wrote: Thu Apr 05, 2018 6:51 pm and
I have T14 connector with pins, but I need terminal pins of DRL and SCL, "and front Parking/side lights", which connects to BCM. I would be grateful to you if you could give those terminal pins.
Three each side, to connect in this way :arrow: https://drive.google.com/file/d/0B2nv91 ... sp=sharing
Yes, no problem, I will send you 8 terminals of these ones :arrow: https://www.a4-freunde.com/attachment.p ... 1415951045
:lol:
vento2013
Post by vento2013 »
ciclo wrote: Thu Apr 05, 2018 8:49 pm Yes, no problem, I will send you 8 terminals of these ones
Thank you very much.. :D
