Suran 1.6 MSI HL '15
EdgardoRodriguez
Drives: other
Post by EdgardoRodriguez »
Hello all, my name is Edgardo and I live in Argentina, South America.
First of all, I hope that is not offensive to open a thread of a car that it is not actually a Polo :?: , I´ve reached this forum because of several similarities between Polos and my Suran, which I sweetly call it Suricata :P
Some of these similarities I can recall are BCM PQ25 and ABS ESP 9.0i modules.
Below I will show an VCDS autoscan output:
Friday,23,March,2018,07:55:20:00001
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN:    License Plate:
Mileage: 40094   Repair Order:
Chassis Type: 5Z-VW21 (6N0)
Scan: 01 02 03 04 09 10 15 17 19 25 44 56 0B
VIN:
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CWSA)       Labels: None
   Part No SW: 04E 906 032 G    HW: 04E 907 425 A
   Component: 1.6l R4 MPI   H07 2706
   Revision: --H07---
   Coding: 00140012022400000000
   Shop #: WSC 07456 790 50316
   ASAM Dataset: EV_ECM16MPI02104E906032G 001007
   ROD: EV_ECM16MPI02104E906032G.rod
   VCID: 2446D40C2FDBFE66CE-8070
Readiness: 0000 0000
Address 02: Auto Trans        Labels: None
   Part No SW: 0C3 927 735 G    HW:
   Component: MARELLI C348V SQ200 1504
   Revision: --H02---    Serial number: BPLNF8S6P
   Coding: 0000025
   Shop #: WSC 00000 000 00000
   VCID: 2E523624B917443628-807A
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 5Z0 907 379 K    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0001
   Serial number: --------------
   Coding: F1DC948D212313C68F1B29698458C8400900
   VCID: 4D9051A81CD11F2E31-8018
Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
   Part No SW: 7H0 937 090 D    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H78 0725
   Revision: B9078001    Serial number: 0671 338141906
   Coding: 3BA98B384C3BC600113A06C06CC89A81B180629D608C2059240580020000
   Shop #: WSC 79157 025 435844
   VCID: 2F6C2B207E1D4D3E23-807A
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 150914 05  54  0403
   Coding: 0530AD
   Subsystem 2 - Part No SW: 5Z0 959 800 A    HW: 5Z0 959 800 A
   Component: ZFH_4T  H08 0015
   Serial number: 3982FL00001410090213
   Coding: 006B54
   Subsystem 3 - Part No SW: 5Z0 959 800 A    HW: 5Z0 959 800 A
   Coding: 006B54
   Subsystem 4 - Part No: 5Z0 947 105 F
   Component: DWA-Sensor 00  003 0008
   Subsystem 5 - Part No SW: 2H0 959 442     HW: 2H0 959 442
   Component: E221__MFL-DC1  H01 0103
   Serial number: 27140002040360104334
   Coding: A5FFFF
   Subsystem 6 - Part No SW: 5Z0 959 800 A    HW: 5Z0 959 800 A
   Coding: 006B54
   Subsystem 7 - Part No SW: 5Z0 959 800 A    HW: 5Z0 959 800 A
   Coding: 006B54
Address 10: Park/Steer Assist (J446)       Labels:* None
   Part No SW: 5Z0 919 475 A    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0002
   Revision: --------    Serial number: 67781426000519
   Coding: 100003
   Shop #: WSC 00001 001 00001
   ASAM Dataset: EV_EPHVA18VW23X0000 001002
   ROD: EV_EPHVA18VW23X0000_VW21.rod
   VCID: 43847790CA95D95ED7-8016
Address 15: Airbags (J234)       Labels:* None
   Part No SW: 5Z0 959 655 A    HW: 5Z0 959 655
   Component: VW10AirbagZZX H02 0216
   Revision: --------    Serial number: 003NC305ZGS$
   Coding: 000000000000000000000000000000005A58
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 479C6380FEADF57E0B-8012
Address 17: Instruments (J285)       Labels:* 5Zx-920-xxx-17.lbl
   Part No SW: 5Z0 920 865 A    HW: 5Z0 920 865 A
   Component: KOMBI         H07 0010
   Coding: 860A22
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04726
   ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
   VCID: 3E720664A177B4B6B8-806A
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H78 0725
   Revision: B9078001
   Coding: 002200
   VCID: 70EEE85CA3A312C67A-8024
Address 25: Immobilizer (J334)       Labels:* None
   Component: IMMO          H07 0010
   Serial number:
Address 44: Steering Assist (J500)       Labels:* None
   Part No SW: 5Z1 909 144 D    HW: 5Z1 909 144
   Component: EPS_ECU       401 4040
   Coding: 004F
   ASAM Dataset: EV_SteerAssisNSKGen2 005107
   ROD: EV_SteerAssisNSKGen2_005.rod
   VCID: 3F8C7B60A67DBDBEB3-806A
Address 56: Radio (J503)       Labels: None
   Part No SW: 5Z0 035 160 A    HW: 5Z0 035 160 A
   Component: MIBGLAM       H11 0039
   Revision: RB101000    Serial number: VWZ7Z2R3032201
   Coding: 00000400020000
End-------------------------(Elapsed Time: 03:02)--------------------------
Exterior:
Interior:
IC:
I´ve done a few moddifications through VCDS, later with a bit more time free, I will continue and post it here. :arrow: :arrow:
Saludos!! Regards!! :D :!: :!:
Re: Suran 1.6 MSI HL '15
Hi EdgardoRodriguez, welcome.
It's good luck to have you here with us.
Nice Suricata 8)
The PQ25 is a very widespread platform all over the world, and many of us here are eager to know all the possibilities of this platform to apply them to our 6Rs.
Please keep us informed of your projects or modifications, I subscribe to your topic to be notified. :wink:
aadriver
Drives: Skoda Fabia MK2
Gearbox
Post by aadriver »
EdgardoRodriguez nice to see you!
What is the type of gearbox - SQ?
Not AQ, MQ, DQ
single clutch automatic gearbox
EdgardoRodriguez
Drives: other
ciclo wrote: Thu Apr 05, 2018 1:59 pm Hi EdgardoRodriguez, welcome.
Nice Suricata
Hi!! thanks Ciclo!!
I will later maybe have some time to describe them here!
But I am pretty sure you already know them all!! As they are a few, and also mainly related to the PQ25. Haven´t done any retrofitting yet :(
aadriver wrote: Fri Apr 06, 2018 5:19 am EdgardoRodriguez nice to see you!
Not AQ, MQ, DQ
iichel wrote: Fri Apr 06, 2018 8:12 am single clutch automatic gearbox
It´s in between a manual transmission and a automatic one...
It´s a robotized gearbox based on the widely used MQ-200 (south america at least) which has 5 gears. It consists on a robot for the clutch and another for the gear selector. It´s very confortable. When I bought it I was kind of sceptical but I´ve got very surprised. Nowadays I feel very happy with it, I also have the possibility to use it like a manual one, deciding my self when to go up or down a gear..
PS: Don´t know why I wasn´t receiving notifications from my own post :shock: Now I self-subscribed to it! hehe :lol:
hehe technically the DSG gearbox is also a manual gearbox, but with a robot to select your gears and operate the two clutches instead of you doing it yourself. ;)
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
hey can you post an image of whole dash (with steering controls) when lights are turned on?
EdgardoRodriguez
Drives: other
Done some ic EEPROM edits
Enabled so far:
Volume to be replenished
Staging
Real coolant temperature on gauge
Thanks to many info provided at Russian forums
Enviado desde mi iPhone utilizando Tapatalk
EdgardoRodriguez
Drives: other
EdgardoRodriguez
Drives: other
ag69 wrote:hey can you post an image of whole dash (with steering controls) when lights are turned on?
Sorry for the delay, here you are!!
ag69
Post by ag69 »
Thanks.
Looks cool.
