Polo 6R ABS CODING
4evermetalhead
Drives: A normal Polo!!!
Re: Polo 6R ABS CODING
Post by 4evermetalhead »
4evermetalhead wrote: Wed Mar 28, 2018 12:20 pm Morning lads,
Food for thought here. (i think) :D
First of all, for 8.2, i noticed that these two bits did not add up to my brain, which i could sure be wrong, but
"10 Byte, binary inverted value of the 2 Byte: (24/14/22/12)"
does not add up to
2 Byte, define the brake types:
24 – if the front 256mm disk and rear 200mm drum
28 – if the front 256mm disk and rear 232mm disk
44 – if the front 288mm disk and rear 200mm drum
48 – if the front 288mm disk and rear 232mm disk
correctly.
I could be wrong.
Also this:
40 – BXW/CGGB/CBZB/CGPA/CBZA/CHFA/CFNA left-side steering wheel
I think could be turned to "80" for RHD vehicles.
Right??????
Any input on this would be nice to discuss further.
THESE sort of things just intricate my curiosity.
According to my calculations
24 = 100100 -> inv.bin. = 011011 -> final inverted = 1b
28 = 101000 -> inv.bin. = 010111 -> final inverted = 17
44 = 1000100 -> inv.bin. = 0111011 -> final inverted = 3b
48 = 1001000 -> inv.bin. = 0110111 -> final inverted = 37
Isn't this correct?
Or is it the long sleepless hours i had, messing with my brain power?? :lol: :lol:
24 = 00100100 -> inverted = 00100100 -> final inverted = 24
28 = 00101000 -> inverted = 00010100 -> final inverted = 14
etc
EdgardoRodriguez
Drives: other
Post by EdgardoRodriguez »
Hi there!
Perhaps some expert here can help me. Done a mistake (cluster swap - different VIN) and ABS recoded itself to zeros :shock:
Well, I was just testing so I have my original IC and everything is fine, except G85 which I can not calibrate :|
Actual coding of ABS module is EXACTLY the same as factory, cause I have several backups I can confirm it.
ESP and "steering wheel" indicators are on while ignition on, and also a "ESC malfunction" error pops up in IC.
This is the autoscan:
Saturday,14,April,2018,20:38:20:00001
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: License Plate:
Mileage: 40337   Repair Order:
Chassis Type: 5Z-VW21 (6N0)
Scan: 01 02 03 04 09 10 15 17 19 25 44 56 0B
VIN:
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CWSA)       Labels: None
   Part No SW: 04E 906 032 G    HW: 04E 907 425 A
   Component: 1.6l R4 MPI   H07 2706
   Revision: --H07---
   Coding: 00140012022400000000
   Shop #: WSC 07456 790 50316
   ASAM Dataset: EV_ECM16MPI02104E906032G 001007
   ROD: EV_ECM16MPI02104E906032G.rod
   VCID: 2446D40C2FDBFE66CE-8070
Readiness: 1010 0001
Address 02: Auto Trans        Labels: None
   Part No SW: 0C3 927 735 G    HW:
   Component: MARELLI C348V SQ200 1504
   Revision: --H02---    Serial number: BPLNF8S6P
   Coding: 0000025
   Shop #: WSC 00000 000 00000
   VCID: 2E523624B917443628-807A
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 5Z0 907 379 K    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0001
   Serial number: --------------
   Coding: F1DC948D212313C68F1B29698458C8401500
   VCID: 4D9051A81CD11F2E31-8018
1 Fault Found:
0993 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 160
                    Mileage: 40337 km
                    Date: 2035.14.17
                    Time: 04:15:26
Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
   Part No SW: 7H0 937 090 D    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H78 0725
   Revision: B9078001    Serial number: 0671 338141906
   Coding: 3BA98B384C3BC600113A06C06CC89A81B188629D608C2059240580020000
   Shop #: WSC 79157 025 435844
   VCID: 2F6C2B207E1D4D3E23-807A
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 150914 05  54  0403
   Coding: 0530AD
   Subsystem 2 - Part No SW: 5Z0 959 800 A    HW: 5Z0 959 800 A
   Component: ZFH_4T  H08 0015
   Serial number: 3982FL00001410090213
   Coding: 006B54
   Subsystem 3 - Part No SW: 5Z0 959 800 A    HW: 5Z0 959 800 A
   Coding: 006B54
   Subsystem 4 - Part No: 5Z0 947 105 F
   Component: DWA-Sensor 00  003 0008
   Subsystem 5 - Part No SW: 2H0 959 442     HW: 2H0 959 442
   Component: E221__MFL-DC1  H01 0103
   Serial number: 27140002040360104334
   Coding: A5FFFF
   Subsystem 6 - Part No SW: 5Z0 959 800 A    HW: 5Z0 959 800 A
   Coding: 006B54
   Subsystem 7 - Part No SW: 5Z0 959 800 A    HW: 5Z0 959 800 A
   Coding: 006B54
Address 10: Park/Steer Assist (J446)       Labels:* None
   Part No SW: 5Z0 919 475 A    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0002
   Revision: --------    Serial number: 67781426000519
   Coding: 100003
   Shop #: WSC 00001 001 00001
   ASAM Dataset: EV_EPHVA18VW23X0000 001002
   ROD: EV_EPHVA18VW23X0000_VW21.rod
   VCID: 43847790CA95D95ED7-8016
Address 15: Airbags (J234)       Labels:* None
   Part No SW: 5Z0 959 655 A    HW: 5Z0 959 655
   Component: VW10AirbagZZX H02 0216
   Revision: --------    Serial number: 003NC305ZGS$
   Coding: 000000000000000000000000000000005A58
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 479C6380FEADF57E0B-8012
Address 17: Instruments (J285)       Labels:* 5Zx-920-xxx-17.lbl
   Part No SW: 5Z0 920 865 A    HW: 5Z0 920 865 A
   Component: KOMBI         H07 0010
   Coding: 860A22
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04726
   ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
   VCID: 3E720664A177B4B6B8-806A
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H78 0725
   Revision: B9078001
   Coding: 002200
   VCID: 70EEE85CA3A312C67A-8024
Address 25: Immobilizer (J334)       Labels:* None
   Component: IMMO          H07 0010
   Serial number:
Address 44: Steering Assist (J500)       Labels:* None
   Part No SW: 5Z1 909 144 D    HW: 5Z1 909 144
   Component: EPS_ECU       401 4040
   Coding: 004F
   ASAM Dataset: EV_SteerAssisNSKGen2 005107
   ROD: EV_SteerAssisNSKGen2_005.rod
   VCID: 3F8C7B60A67DBDBEB3-806A
2 Faults Found:
0054 - Steering angle sensor
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 40337 km
                    Date: 2035.14.17
                    Time: 04:15:26
                    Single Additional Freeze Frame:
0047 - Steering End Stops Not Learned
          C10AC F0 [137] - Unknown Error Elaboration
                    Fault Priority: 4
                    Fault Frequency: 1
                    Mileage: 40337 km
                    Date: 2035.14.17
                    Time: 04:15:26
Address 56: Radio (J503)       Labels: None
   Part No SW: 5Z0 035 160 A    HW: 5Z0 035 160 A
   Component: MIBGLAM       H11 0039
   Revision: RB101000    Serial number: VWZ7Z2R3032201
   Coding: 00000400020000
End-------------------------(Elapsed Time: 03:08)--------------------------
Tried so many procedures here that I am lost :(
What´s more concerning to me is the following:
Please consider that VCDS isn´t "recommending" in a popup any security code, so I am using the wide spread 40168 one, which is actually accepted
This is done in ABS 03 module - Security access - then Basic Settings
If I do not enter the code, this basic setting shows "ERROR: Security access required".
Tried while driving and still and the same.
Can some one help?
are you holding the steering wheel straight?
EdgardoRodriguez
Drives: other
iichel wrote: Tue Apr 17, 2018 8:57 pm are you holding the steering wheel straight?
For sure. also drove for more or less 100 meters and then done the same no success (at 15km/h aprox, no higher than 20). Tried 30 deg left, then right, then center and the same
Also removed the battery for a while with steer straight, then connect again, tried the same with full left and full right.
Jay-Jay
Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
Post by Jay-Jay »
Did you check if your steering angle sensor can see the rotation of your steering wheel (in Meas. Blocks)?
Even if you didn't set the zero in Basic Settings, a properly working sensor should read something and show it to you.
EdgardoRodriguez
Drives: other
Jay-Jay wrote:Did you check if your angle steering wheel sensor can see the rotation of your steering wheel (in Meas. Blocks)?
It does
The sensor can't possibly be faulty. These errors are present since automatic abs recoding. I have never seen any fault in esp / abs module
Enviado desde mi iPhone utilizando Tapatalk
Jay-Jay
Post by Jay-Jay »
It's strange the sensor has become faulty after the ABS Unit lost its coding.
Can you try with another VCDS version (18.1.0 or older than yours)?
EdgardoRodriguez
Drives: other
Jay-Jay wrote:It's strange the sensor has become faulty after the ABS Unit lost its coding.
May be I can
Mine is 17.8
I will give it a try later.
I am sure the sensor ain't physically faulty, it's just impossible cause I haven't made any physical thing. I just need to bypass this test aborted due to safety reasons
EdgardoRodriguez
Drives: other
Tried 17.1 and the same exact problem. Aborted safety reasons..
Also tried again several times calibration procedure of performing short test drives and no luck.
Any leads??
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
My friend had same fault. His issue was because he changed steering wheel and slip-ring accidentally had been rotated half turn from zero position.
EdgardoRodriguez
Drives: other
firegrafik wrote:My friend had same fault. His issue was because he changed steering wheel and slip-ring accidentally had been rotated half turn from zero position.
Hi !
I swear that I haven't even disassembled the steering wheel.
But when the unit recoded itself wheels where pointing straight ahead. So now measures while in the same position throws some thing like -720
Perhaps I need to turn all the way left and trigger another self zeroing to the sensor begin reading something nearer to 0?
Then run adaptation again ?
EdgardoRodriguez
Drives: other
I totally confirmed by g85 sensor Is integrated in esp sensor. Do you known any security access code to test ? Tried several without success.
Benetnash
Drives: 2010 Polo 6r CGPB
Post by Benetnash »
Hello,
I'd like to get help with my Polo, problem is ABS Long Coding is all zeros,
Some time ago, there was a problem with an ECU, and as result there was swap of ECU, Instrument Cluster and Immo, everything runing smooth, but
there is no coding in ABS, and when I try to input a code, VCDS says something like this "Coding Rejected. Error 22: Conditions not correct or request sequence error".
here is my AutoScan, I hope some one can help
Tuesday,01,May,2018,12:40:55:00006
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
Dealer/Shop Name: FIX
VIN: WVWZZZ6RZAY019004   License Plate:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZAY019004   Mileage: 79350km-49305miles
04-Steering Angle -- Status: Not registered 0001
Address 01: Engine (CGP)       Labels: 03E-906-033-AZQ.lbl
   Part No SW: 03E 906 023 L    HW: 03E 906 023 L
   Component: SIMOS91 1.2l 4V     4489
   Revision: --H04---    Serial number:
   Coding: 0000071
   Shop #: WSC 00000 000 163936
   VCID: 285F4EA298F31D0470-515A
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 R    HW: 6R0 907 379 R
   Component: ESP8.2i front H04 0002
   Revision: --------
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 02069 000 00000
   VCID: 4D91DF3610D1182CA3-8018
2 Faults Found:
03306 - Coding Not Valid
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 6
                    Reset counter: 78
                    Mileage: 79356 km
                    Time Indication: 0
                    Date: 2012.09.21
                    Time: 12:18:10
                    Hex Value: 0x0003
                    Hex Value: 0x0002
                    Hex Value: 0x32E7
                    Hex Value: 0x2598
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Hex Value: 0x0000
01042 - Control Module; Not Coded
            000 -  -
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 78
                    Mileage: 79356 km
                    Time Indication: 0
                    Date: 2012.09.21
                    Time: 12:23:26
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x3211
                    Hex Value: 0x1498
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Hex Value: 0x0000
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
   Part No SW: 6R0 820 045     HW: 6R0 820 045
   Component: Climatic       23 0500
   Revision: 00 09 23
   VCID: 6BD571AE8A85F61CDD-803E
1 Fault Found:
16372 - Control Module; Unspecified Internal Error
            014 - Defective
                    Fault Status: 01101110
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 15444 km
                    Time Indication: 0
                    Date: 2011.01.02
                    Time: 16:42:59
   Part No SW: 6R0 937 087 D    HW: 6R0 937 087 D
   Component: BCM PQ25 H+4  H46 0207
   Revision: BF046001    Serial number: 0147 045100658
   Coding: 3CB82DBF08A10000002000C03F6B0CD8B0C841DF60060000200000000000
   Shop #: WSC 12345 123 61029
   VCID: 3E7388FAA977B3B42A-806A
   Subsystem 1 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0912
   Serial number: KU0-KU020.01.1011432
   Coding: 08BC30
   Subsystem 2 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 0912
   Serial number: KU0-KU002.02.1014646
   Coding: 08BC30
   Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
   Component: VW10Airbag00L H09 0018
   Revision: --------    Serial number: 003DW00CD63$
   Coding: 00304C
   Shop #: WSC 124697 483 00190
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 428BFC0AD58FD7544E-8016
   Serial number: 3572SRB40000AB110A2-
   Serial number: 3582SRB40000AB114A95
   Serial number: 3516GRB402N9LLFMQ3HH
   Serial number: 3526GRB402V9LLFMKJS4
   Part No SW: 6R0 920 860 A    HW: 6R0 920 860 A
   Component: KOMBI         H23 0110
   Coding: 140A00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
   VCID: 326BACCA652F67D4DE-8066
   Part No SW: 6N0 909 901     HW: 6R0 937 087 D
   Component: GW-K-CAN TP20 0207
   Coding: 000100
   VCID: 70EF66C2A3A315C4E8-8024
1 Fault Found:
            000 -  -
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 79356 km
                    Time Indication: 0
                    Date: 2012.09.20
                    Time: 23:54:45
Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H23 0110
   Serial number:
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
   ROD: EV_Immo_UDS_VDD_RM09.rod
   Part No: 6R0 423 156 A
   Component: LenkhilfeTRW        V275
   Coding: 11241
   Shop #: WSC 06402
   VCID: 2E53B8BAED174334BA-807A
   Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
   Component: Radio RCD310  013 0036
   Revision: 01000000    Serial number: VWZ1Z2I6253963
   Coding: 0500040004
4 Faults Found:
00876 - Treble Speaker Rear Left (R14)
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 60
                    Mileage: 78828 km
                    Time Indication: 0
                    Date: 2012.09.14
                    Time: 13:33:19
00877 - Treble Speaker Rear Right (R16)
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 60
                    Mileage: 78828 km
                    Time Indication: 0
                    Date: 2012.09.14
                    Time: 13:33:19
00821 - Antenna 2 for Radio (R93)
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 60
                    Mileage: 78828 km
                    Time Indication: 0
                    Date: 2012.09.14
                    Time: 13:33:25
03138 - Input AUX IN
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 68
                    Mileage: 79192 km
                    Time Indication: 0
                    Date: 2012.09.16
                    Time: 13:53:48
End-------------------------(Elapsed Time: 02:04)--------------------------
There is also wrong coding in CAN Gateway, any sugestions?
Gateway:
4 Doors: 002200
2 Doors: 002000
