Preview
Check your inbox.
hey!
This installation of wires from T73b/9 and /10 and feed to the BCM from SB57 will also apply to bi-xenon headlights for the static cornering in the headlight, no?ciclo wrote: Sun Apr 08, 2018 9:11 am LED headlights don't have additional lamps:
- the electric installation of the fog lamps must be controlled by the BCM, in this case the Static cornering lights function is carried out by the fog lamps, so that the fog lamps have two functions, foglights and Static Cornering Lights. BCM coding.
(light switch--->signal wire to BCM---BCM fed--->a supply wire to each foglight)
In your case it would be necessary to make a new electrical installation for the fog lamps if you install LED headlights. Link that I posted here in your topic (ebay.de).
Yes, and?...iichel wrote: Sun Apr 08, 2018 9:15 am in terms of light production, LED and bi-xenon are not very different.
What will be your choice?...
From factory (currently):iichel wrote: Sun Apr 08, 2018 9:55 am remember, there is no wrong answer to the question, so think about it.
Just some tips for the consideration:
- Will your current BCM 7E0 937 090 C support LED headlights? Not all do.
- How is the availability of the RHD LED headlights where you live in India?
ciclo wrote: Sun Apr 08, 2018 10:03 am
- Russia --- Polo Sedan --- Bixenon headlights.
- India --- Vento --- LED headlights. with 7E0937089A BCM and RLS is present in Vento but no Auto Light
Polo Sedan = Vento
TRUE will keep in mind.iichel wrote: Sun Apr 08, 2018 9:55 am remember, there is no wrong answer to the question, so think about it.
Monday,15,May,2018,20:46:17:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Workshop Code: 648 00788 000255
VIN: WVWJ13601ET024078 License Plate:KA47 M****
Chassis Type: 60 (7E0)
Scan: 01 03 08 09 10 15 17 19 25 44 56
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CLNA) Labels: None
Part No SW: 03L 906 023 NT HW: 03L 907 425 B
Component: 1,6l R4 CR td H33 9971
Revision: --H33--- Serial number: 00000000000000
Coding: 00110016032500080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM16TDI02103L906023NT 003012
ROD: N/A
VCID: 8501F79F04D47D36275-80D0
No ASAM data for: "EV_ECM16TDI02103L906023NT" (VN75)
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 BF HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0001
Serial number: --------------
Coding: 60DD2F63212504C40614F470845920020000
Shop #: WSC 57830 002 1048576
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH_VW25.rod
VCID: 8305E9870AE04306091-80D6
Address Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb
Part No SW: 6R0 907 044 L HW: 6R0 907 044 L
Component: Climatronic H12 0612
Revision: V0000000
VCID: 3C76B954BFBF43A696-8068
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 320170423
Coding: 3A904BBF48E10200013807916CCB96905A88676F608D30C1200000030000
VCID: 2B55E1274AF0EB46111-807E
Subsystem 1 - Part No: 5K7 955 559 C
Component: RLS 230118 04 47 0106
Coding: 008F77
Subsystem 2 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB
Component: ------------- 006 5520
Coding: 010000
Subsystem 3 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH
Coding: 010000
Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Component: E221__MFL-TAT H04 0019
Coding: 240000
Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Coding: 020000
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361317300143
Coding: 108002
Shop #: WSC 00793 648 00255
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E73D873A1826EEEA6F-806B
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW00M0RR+
Coding: 003036
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250_VW24.rod
VCID: 4999BBAFE84CD95603D-801C
Part No SW: 6RF 920 862 HW: 6RF 920 862
Component: KOMBI H01 0214
Coding: 140A00
Shop #: WSC 13202 938 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 09197BAFA8CC9956C3D-805C
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 102300
VCID: E8DFDE2B1B86805EBC3-80BD
Component: IMMO H01 0214
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
VCID: EADBA4230D8AB24EAA7-80BF
Address 44: Steering Assist (J792) Labels: 6Rx-909-144-44.clb
Part No SW: 6RF 909 144 K HW: 6RF 909 144 J
Component: EPS_ECU H44 0401
Coding: 0000
ASAM Dataset: EV_SteerAssisUDSNSK 005005
ROD: EV_SteerAssisUDSNSK.rod
VCID: 54A79ADB3F0E94BE60B-8001
Address 56: Radio (J503) Labels: None
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 534 5314
Revision: -------- Serial number: VWZZZ4H6267388
Coding: 16000440040005
Shop #: WSC 127395 840 08317
VCID: 4683B093F152362EEEF-8013
End ---------------------------------------------------------------------
