Retrofitting LED headlights & BCM Max Adaptation+Auto Headlight with CH/LH on 2013 6R
Re: Retrofitting LED headlights & BCM Max Adaptation+Auto Headlight with CH/LH on 2013 6R
So with
3A904BBF48A10000013807006CCB96900080604F60CD31E1210000030020
The fogs are not working and only one static cornering light works (left)
With this coding:
3A904BBF48E10200013807916CCB96905A88676F608D30C1200000030000
Front fogs are working? And both static cornering lights?
vento2013
Drives: 6R Polo(Vento)1.6TDi, Skoda Fabia 1.2MPi
Post by vento2013 »
Yes.
vento2013 wrote: Thu May 17, 2018 12:44 pm
ciclo wrote: Wed May 16, 2018 4:40 pm BCM
New coding
After this coding observation as below
Pass light(using left stalk) = working fine only High beam
Switch position to parking = Parking is ON
Fog lights = working (when fog is on parking off)
SCL = Only Left cornering is working. Right side not working
Auto scan did No errors in installation list but in address line 04(Attached new scan report)
1 Fault Found:
1140738 - Steering angle sensor
B1168 54 [009] - Missing Calibration / Basic Setting
it was not there earlier
1
The fault of the steering angle G85 is not visible in the previous autoscan with/due to VCDS 12.12, even the address 04 (G85) does not appear in the reading (check it), but the fault is present since then.
With the VCDS 17.1 the fault and the reading of this address 04 are present.
SCLs depend of steering angle G85 (address 04), so...
Are you absolutely sure that the locking mechanism of the T41 connector is firmly tightened?
It is a very common failure in these processes. The tab must go to the end. PUSH IT firmly.
2
Your BCM coding copied from Shardul's Vento is totally wrong for your Vento and LED headlights. Don't use it again.
3
Use only my new BCM coding (perfect coding for your LED headlights), it is the starting point to make your "LED headlights" work properly when you install the right parts, BCM, ...
Wait for me to correct the new BCM coding for your "current electrical installation".
Will be corrected again depending of the results.
Note: What is clear in the autoscan is that all wiring that I sent you work perfectly, another very different thing is the compatibility of the parts, lights, wires, G85, etc ... that you decide to install in your Vento. :lol:
3A904BBF48A10000013807006CCB96900080606F60CD39E1210000030020
Tell us the result. Light by light, please.
vento2013
Post by vento2013 »
ciclo wrote: Thu May 17, 2018 5:39 pm 3A904BBF48A10000013807006CCB96900080606F60CD39E1210000030020
DRL = OK
Pass Light = OK (Only High beam)
Parking light = OK (When Headlight is on parking is OFF) Need Specific BCM.
Low Beam = OK
High Beam = OK
Fog Lights = OK (Parking goes OFF)
Static Cornering = Not working
CH/LH = OK
Thursday,17,May,2018,23:07:53:39744
VCDS Version: 17.1.3.0
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: WVWJ13601ET024078   License Plate: KA47M3663
Mileage: 62340km-38736mi   Repair Order: Ciclo code2
Chassis Type: 60 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 56 0B
VIN: WVWJ13601ET024078   Mileage: 62340km-38736miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CLNA)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 NT    HW: 03L 907 425 B
   Component: 1,6l R4 CR td H33 9971
   Revision: --H33---    Serial number: 00000000000000
   Coding: 00110016032500080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM16TDI02103L906023NT 003012
   ROD: EV_ECM16TDI02103L906023MJ.rod
   VCID: 05064A5684BA6669DA-8050
Readiness: 0000 1000
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 6R0 907 379 BF    HW: 6R0 907 379 AQ
   Component: ABS9.0 front  H01 0001
   Serial number: --------------
   Coding: 60DD2F63212504C40614F470845920020000
   Shop #: WSC 57830 002 1048576
   ASAM Dataset: EV_Brake1ABS90BOSCH 003017
   ROD: EV_Brake1ABS90BOSCH_VW25.rod
   VCID: 0302544E8A8E5859F4-8056
Address 04: Steering Angle (G085)       Labels: 6R0-959-654.clb
   Serial number: 23101713470492
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF425BAE16C35B19B-802A
1 Fault Found:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 7
                    Mileage: 62345 km
                    Date: 2016.01.30
                    Time: 22:59:31
                    Voltage terminal 15: 12.00 V
                    Voltage terminal 30: 12.30 V
                    Terminal 15 status: On
   Part No SW: 6R0 907 044 L    HW: 6R0 907 044 L
   Component: Climatronic   H12 0612
   Revision: V0000000
   VCID: 3C70EFB2BFF0E7A1F5-8068
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 320170423
   Coding: 3A904BBF48A10000013807006CCB96900080606F60CD39E1210000030020
   VCID: 2B52DCEE4A9E70196C-807E
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 230118 04  47  0106
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 802 AL    HW: 6R0 959 802 AL  Labels: 6R0-959-802.CLB
   Component: -------------  006 5520
   Serial number: 13202576130625091059
   Coding: 010000
   Subsystem 3 - Part No SW: 6R0 959 801 AH    HW: 6R0 959 801 AH  Labels: 6R0-959-801.CLB
   Serial number: 13102579130618031221
   Coding: 010000
   Subsystem 4 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Component: E221__MFL-TAT  H04 0019
   Serial number: 2671409414901055AB1B
   Coding: 240000
   Subsystem 5 - Part No SW: 6R0 959 811 L    HW: 6R0 959 811 L
   Serial number: 13102580130620031450
   Coding: 020000
   Subsystem 6 - Part No SW: 6R0 959 812 L    HW: 6R0 959 812 L
   Serial number: 13102581130620063454
   Coding: 020000
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361317300143
   Coding: 108002
   Shop #: WSC 00793 648 00255
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E74E5BAA1ECF5B1DB-806A
   Revision: --------    Serial number: 003GW00M0RR+
   Coding: 003036
   Shop #: WSC 01383 785 00200
   VCID: 499E8666E82242097E-801C
   Part No SW: 6RF 920 862     HW: 6RF 920 862
   Component: KOMBI         H01 0214
   Coding: 140A000000
   Shop #: WSC 13202 938 00000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
   VCID: 091E4666A8A20209BE-805C
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 002300
   VCID: 68D863E29BE89B0141-803C
   Component: IMMO          H01 0214
   Serial number:
   VCID: 6ADC19EA8DE4A91157-803E
Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V1.clb
   Part No SW: 6RF 909 144 K    HW: 6RF 909 144 J
   Component: EPS_ECU       H44 0401
   Coding: 0000
   ASAM Dataset: EV_SteerAssisUDSNSK 005005
   ROD: EV_SteerAssisUDSNSK_SK26.rod
   VCID: 54A0A7123F600FE11D-8000
Address 56: Radio (J503)       Labels: None
   Component: Radio         534 5314
   Revision: --------    Serial number: VWZZZ4H6267388
   Coding: 16000440040005
   Shop #: WSC 127395 840 08317
   VCID: 46848D5AF13CAD7193-8012
End-------------------------(Elapsed Time: 02:44)--------------------------
I have made small change in code
3A904BBF48A10000013807006CCB96900080676F60CD39E1210000030020
DRL = OK
Low Beam = OK
High Beam = OK
Static Cornering = OK Working perfectly
CH/LH = OK
Thursday,17,May,2018,23:30:50:39744
www.Ross-Tech.com
Mileage: 62340km-38736mi   Repair Order: Ciclo 2+Edit
Readiness: 1000 1000
   Coding: 01
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 7
                    Mileage: 62345 km
                    Date: 2016.01.30
                    Time: 23:27:35
                    Voltage terminal 15: 11.70 V
                    Voltage terminal 30: 12.05 V
   Revision: V0000000
   Coding: 3A904BBF48A10000013807006CCB96900080676F60CD39E1210000030020
   Coding: 0728DD
   Coding: 010000
   Coding: 010000
   Coding: 240000
   Coding: 020000
   Coding: 020000
   Coding: 108002
   Coding: 003036
   Coding: 140A000000
   Revision: B9082001
   Coding: 002300
   Serial number:
   Coding: 0000
Any test missing please let me know.
3A904BBF48A10000013807006CCB96900080676F60CF39E1210000030020
maybe this makes your parking lights work, but at full brightness instead of 100%
just use it as temporary solution until the correct BCM arrives of course
vento2013 wrote: Thu May 17, 2018 7:26 pm
DRL = OK
Low Beam = OK
High Beam = OK
CH/LH = OK
www.Ross-Tech.com
   Coding: 01
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 7
                    Mileage: 62345 km
                    Date: 2016.01.30
                    Time: 23:27:35
   Revision: V0000000
   Coding: 0728DD
   Coding: 010000
   Coding: 010000
   Coding: 240000
   Coding: 020000
   Coding: 020000
   Coding: 108002
   Coding: 003036
   Coding: 140A000000
   Revision: B9082001
   Coding: 002300
   Serial number:
   Coding: 0000
No small change, it's a big change. (changes are made in several parameters)
If at the moment you are happy with this lights operation, me too. :)
This BCM coding is for Vento LED Headlights, in the same way like factory coding. (except Byte18)
We'll wait for your new BCM 8IT for LED headlights.
vento2013 wrote: Thu May 17, 2018 7:26 pm Any test missing please let me know.
Well, just for curiosity ...
Try the following Hexadecimals and with the following order in the Byte18 of your current BCM 8IG for Bixenon headlights.
61
62
63
64
65
66
and tell us in which of them the SCLs start to work. (64?)
vento2013
Post by vento2013 »
Sorry was bit busy. So now replying.
Just now checked Hexadecimals and with the following order in the Byte 18, 61 to 66 result are
Byte 18 changed value to 61, 62, 63
DRL = OK
Low Beam = OK
High Beam = OK
Byte 18 changed value to 64
DRL = OK
Pass Light = Not OK (High beam+Low Beam)
Low Beam = OK
High Beam = OK
Static Cornering = Ok
Byte 18 changed value to 65, 66
DRL = OK
Low Beam = OK
High Beam = OK
now in Byte 18 value is 66
scan report
Saturday,19,May,2018,19:13:01:39744
www.Ross-Tech.com
Mileage: 62340km-38736mi   Repair Order: coding66
   Coding: 01
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 7
                    Mileage: 62345 km
                    Date: 2016.01.30
                    Time: 23:27:35
   Revision: V0000000
   Coding: 3A904BBF48A10000013807006CCB96900080666F60CD39E1210000030020
   Coding: 0728DD
   Coding: 010000
   Coding: 010000
   Coding: 240000
   Coding: 020000
   Coding: 020000
   Coding: 108002
   Coding: 003036
   Coding: 140A000000
   Revision: B9082001
   Coding: 002300
   Serial number:
   Coding: 0000
End-------------------------(Elapsed Time: 02:41)--------------------------
One more weird thing noticed with this coding
or
Reverse camera used to flicker a lot(attached image) I do not use reverse camera much, I prefer parking sensor with acoustic sound so I never bothered about camera.
But with this new coding
camera is not flickering I am not sure how it is related to this. What I noticed just sharing it here.
Wow! good report! 8) ... it's what I supposed.
Many thanks.
As I told you, it was not a small change. The BCM Byte18 modifies the way it feeds the BCM pins for the lights. Also the diagnosis.
You must bear in mind that this 7E0... C BCM is parameterized for Bixenon headlights, while the headlights you have installed are LED.
We are preparing a good coding for your new 7E0 BCM for LED headlights and rest of devices.
vento2013 wrote: Sat May 19, 2018 3:23 pm now in Byte 18 value is 66
Logically. Image
vento2013
Post by vento2013 »
Hi, Ciclo Finally BCM for LED headlights arrived.
just now swapped BCM n result is...
DRL = OK
Pass Light(Flashing) = OK
Parking light = OK
Low Beam = OK
High Beam = OK
Fog Lights = OK
Static Cornering = Partially working(only Left side working)
VCDS scan report
Monday,04,June,2018,12:26:49:39744
www.Ross-Tech.com
Mileage:    Repair Order: 04062018 8ITBCM
   ASAM Dataset: EV_ECM1T6DI02103L906023NT 003012
   ROD: N/A
No ASAM data for: "EV_ECM1T6DI02103L906023NT" (VW36 *)
   ASAM Dataset: EV_Brake1AB9S0BOSCH 003017
   ROD: N/A
No ASAM data for: "EV_Brake1AB9S0BOSCH" (VW25)
   Coding: 01
   ASAM Dataset: EV_LWSKLOVW52X 005001
   ROD: N/A
No ASAM data for: "EV_LWSKLOVW52X" (VW25)
1 Fault Found:
1140738 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 12
                    Mileage: 62403 km
                    Date: 2016.02.17
                    Time: 00:38:22
   Revision: V0000000
   Revision: B9082001    Serial number: 4000 173170900
   Shop #: WSC 12345 123 12345
   Coding: 0728DD
   Coding: 010000
   Coding: 010000
   Coding: 240000
   Coding: 020000
   Coding: 020000
2 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 224
                    Reset counter: 12
                    Mileage: 62403 km
                    Time Indication: 0
                    Date: 2016.02.17
                    Time: 00:39:37
00979 - Lamp for Low Beam; Right (M31)
                    Fault Priority: 3
                    Reset counter: 12
                    Mileage: 62403 km
                    Time Indication: 0
                    Date: 2016.02.17
                    Time: 00:39:37
   Coding: 108002
   Coding: 003036
   ASAM Dataset: EV_AibraVW10BPAVW250 A01001
   ROD: N/A
No ASAM data for: "EV_AibraVW10BPAVW250" (VW25)
   Coding: 140A000000
   ASAM Dataset: EV_Kobmi_UDS_VDD_RM09 A05729
   ROD: N/A
No ASAM data for: "EV_Kobmi_UDS_VDD_RM09" (VW36 *)
   Revision: B9082001
   Coding: 102300
   Serial number:
   ASAM Dataset: EV_Mimo_UDS_VDD_RM09 A03710
   ROD: N/A
No ASAM data for: "EV_Mimo_UDS_VDD_RM09" (VW36 *)
   Coding: 0000
   ASAM Dataset: EV_SteerAsissUDSNSK 005005
   ROD: N/A
No ASAM data for: "EV_SteerAsissUDSNSK" (VW25)
I'm afraid the low beam errors will only go away if you have the correct BCM; coding it will not work.
I think the value ciclo wrote for byte 18 (HEX 66) is indeed the correct one for your configuration but you could try 60 and 73. But I don't think it will make a difference.
vento2013 wrote: Mon Jun 04, 2018 8:27 am Hi, Ciclo Finally BCM for LED headlights arrived.
DRL = OK
Parking light = OK
Low Beam = OK
High Beam = OK
Fog Lights = OK
VCDS scan report
www.Ross-Tech.com
   ROD: N/A
   ROD: N/A
   Coding: 01
   ROD: N/A
1 Fault Found:
          - 00 [009]
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 12
                    Mileage: 62403 km
                    Date: 2016.02.17
                    Time: 00:38:22
   Revision: V0000000
   Coding: 0728DD
   Coding: 010000
   Coding: 010000
   Coding: 240000
   Coding: 020000
   Coding: 020000
2 Faults Found:
                    Fault Priority: 3
                    Reset counter: 12
                    Mileage: 62403 km
                    Time Indication: 0
                    Date: 2016.02.17
                    Time: 00:39:37
                    Fault Priority: 3
                    Reset counter: 12
                    Mileage: 62403 km
                    Time Indication: 0
                    Date: 2016.02.17
                    Time: 00:39:37
   Coding: 108002
   Coding: 003036
   ROD: N/A
   Coding: 140A000000
   ROD: N/A
   Revision: B9082001
   Coding: 102300
   Serial number:
   ROD: N/A
   Coding: 0000
   ROD: N/A
In this last autoscan the Byte18 is 60 HEX, change it to 66 HEX.
Tell us the result.
vento2013
Post by vento2013 »
ciclo wrote: Mon Jun 04, 2018 12:50 pm
Tell us the result.
Tried 66 in byte 18
DRL = OK
Parking light = OK
Low Beam = OK
High Beam = OK
Fog Lights = OK
But new issue, when high beam is on right low beam flickers once in a while.
So now in byte 18 value is 60
and I turned off SCL.
this is my present coding
Coding: 3A904BBF48A10000013807002CCB96900080604F60C939E1210000030020
except SCL everything else perfect
have two fault codes
Try 64 and 65 HEX in Byte18.
64
3A904BBF48A10000013807006CCB96900080646F60CD39E1210000030020
65
3A904BBF48A10000013807006CCB96900080656F60CD39E1210000030020
Apart:
Keep in mind that you still have a fault in the "new" :?: G85 steering angle you installed.
The basic setting can be made in the ABS unit or in Address 44: Steering Assist (J792) depends on the model and units installed.
Notice (warning):
I don't know how to do the basic setting at address 44, everything you do at address 44 is at your own risk/responsibility.
vento2013 wrote: Mon Jun 04, 2018 7:33 pm Tried 66 in byte 18
DRL = OK
Parking light = OK
Low Beam = OK
High Beam = OK
Fog Lights = OK
have two fault codes :?:
vento2013
Post by vento2013 »
Hello Ciclo,
Sorry for very late reply, was stuck in some work.
Initially SCL was not working later everything stopped working. VCDS scan threw 2 faults Terminal 30 Left N Right 011-Open Circuit. So checked all wiring once again the culprit was loosely inserted ELECTRIC BRIDGE. Reinserted properly. now everything working perfectly.
DRL = OK
Parking light = OK
Low Beam = OK
High Beam = OK
Fog Lights = OK
Auto headlight = OK
Rain Sensing wiper = OK
04 Steering angle sensor still showing fault code, but SCL working perfectly. Tried doing Basic setting using ODIS, it shown no communication!!
Other than steering angle sensor
There are 2 Faults Found:
But Low beam working perfectly. Pls let me know, what might be the issue.
Below is the scan report.
www.Ross-Tech.com
   ROD: N/A
   ROD: N/A
   Coding: 01
   ROD: N/A
1 Fault Found:
          - 00 [009]
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 12
                    Mileage: 62403 km
                    Date: 2016.02.17
                    Time: 00:38:22
   Revision: V0000000
   Coding: 0728DD
   Coding: 010000
   Coding: 010000
   Coding: 240000
   Coding: 020000
   Coding: 020000
2 Faults Found:
                    Fault Priority: 3
                    Reset counter: 12
                    Mileage: 62403 km
                    Time Indication: 0
                    Date: 2016.02.17
                    Time: 00:39:37
                    Fault Priority: 3
                    Reset counter: 12
                    Mileage: 62403 km
                    Time Indication: 0
                    Date: 2016.02.17
                    Time: 00:39:37
   Coding: 108002
   Coding: 003036
   ROD: N/A
   Coding: 140A000000
   ROD: N/A
   Revision: B9082001
   Coding: 102300
   Serial number:
   ROD: N/A
   Coding: 0000
   ROD: N/A
