Folding mirrors wont unfold after about a minute.
martijnoss
- Drives: polo 6r
Helo guys
I place folding mirrors in my polo 6r 1.2 bleumotion 4doors with the guide from ciclo.
The motors i used is with softwarerversion s9210 the coding i used is
0200A3(13 pin motor)
1000AB(7 pin motor)
When i fold the mirrors and put the key in the contact they unfold but only till about 1 minute.
After i stay away for more then about a minute the mirrors wont unfold with the key in contact, the only solution then is to do it with my switch.
Do i need an other code or something?or do something else in vcds?
thanks in advanche
1000AB(7 pin motor)
thanks in advanche
martijnoss
- Drives: polo 6r
Re: Folding mirrors wont unfold after about a minute.
hi
Sorry you're right.
so i have it here.i hope it can be fixed because this retrofitting is great upgrade in my opinion.
Sorry you're right.
Tuesday,15,May,2018,14:23:33:04550
VCDS Version: 15.7.0.2
Data version: 20150820
www.Ross-Tech.com
VIN: WVWZZZ6RZCY018898 License Plate: LOG FOR UK POLOS
Mileage: 209980km-130475mi Repair Order:
Chassis Type: 6R (6R0)
Scan: 01 03 08 09 15 17 19 25 2E 37 44 56 61 77
VIN: WVWZZZ6RZCY018898 Mileage: 209980km-130475miles
37-Navigation -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine (J000-CFWA) Labels: 03P-906-021-CFW.clb
Part No SW: 03P 906 021 B HW: 03P 907 425
Component: R3 1.2l TDI H06 9979
Revision: 12005001 Serial number:
Coding: 00114014032401080000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ECM12TDI03103P906021B 001042
ROD: EV_ECM12TDI03103P906021AA.rod
VCID: 27B82C1356E28C2AA4B4E6-8072
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 210224E3416E00BA842D24EB82D900521300
Shop #: WSC 00788 648 00255
VCID: 07F84C93B622A02A847406-8052
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 389AFF6F8B5C1BD23D0E3D-806C
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 088 F HW: 6R0 937 088
Component: BCM PQ25 Re4 H50 0351
Revision: BU050001 Serial number: 0456 157110196
Coding: 3AB02BBF08F32400B3300FF06CEB0ED0FF8067FF7E862481200000000000
Shop #: WSC 124697 483 00190
VCID: 416C928BD8865A1A8AB098-8014
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 030611 05 54 0403
Coding: 02302D
Subsystem 2 - Part No SW: 6R0 959 801 CE HW: 6R0 959 801 CE Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 9610
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 CJ HW: 6R0 959 802 CJ Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 9610
Coding: 1000AB
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 7 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 007 1611
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Coding: 48BC32
Component: VW10Airbag01M H09 0020
Revision: -------- Serial number: 003GX00NYMLN
Coding: 00314D
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 4A7EB5A7E5B091425BDA67-801E
Crash sensor for side airbag; driver side:
Serial number: 3575HRB405R0ILP0CPGD
Crash sensor for side airbag; front passenger side:
Serial number: 3585HRB40510ILP068LD
Crash sensor for side airbag; rear; driver side:
Serial number: 3515RRB404P0K4DOE8S8
Crash sensor for side airbag; rear; passenger side:
Serial number: 3525RRB40510JNPM88S8
Part No SW: 6R0 920 861 H HW: 6R0 920 861 H
Component: KOMBI H03 0505
Coding: 140801
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 3A9EE567B55001C2CB7AD7-806E
Coding: 140801
Address 19: CAN Gateway (J533) Labels: 6R0-907-530-V2.clb
Part No SW: 6R0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H38 0034
Revision: H38 Serial number: 310511F1000209
Coding: 2500C2
VCID: 3482CB5F9734FFB2113669-8060
Component: IMMO H03 0505
Serial number:
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6A3E1527857071427B1AC7-803E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660151535
Coding: 020000
VCID: 29BC2A2B40F6B25AB2A090-807C
Address 37: Navigation (J794) Labels: 3C0-035-270.clb
Part No SW: 3C0 035 270 B HW: 3C0 035 270
Component: RNS310 H19 0357
Revision: 11000000 Serial number: VWZ1Z2L7243310
Coding: 040004010400000000000000
ASAM Dataset: VW_RNS310 A02007
ROD: EV_VWRNS310UDS.rod
VCID: 19DC1AEB10962ADA22C040-804C
8 Faults Found:
1048593 - Front Left Bass Speaker
B105F 13 [009] - Open Circuit
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 209980 km
Date: 2018.05.15
Time: 23:15:01
1048594 - Front Right Bass Speaker
B1062 13 [009] - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 209980 km
Date: 2018.05.15
Time: 23:15:01
1048595 - Rear Left Bass Speaker
B1065 13 [009] - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 209980 km
Date: 2018.05.15
Time: 23:15:01
1048596 - Rear Right Bass Speaker
B1067 13 [009] - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 209980 km
Date: 2018.05.15
Time: 23:15:01
1048597 - Front Left Treble Speaker
B1061 13 [009] - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 209980 km
Date: 2018.05.15
Time: 23:15:01
1048598 - Front Right Treble Speaker
B1064 13 [009] - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 209980 km
Date: 2018.05.15
Time: 23:15:01
1048599 - Rear Left Treble Speaker
B1066 13 [009] - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 209980 km
Date: 2018.05.15
Time: 23:15:01
1048600 - Rear Right Treble Speaker
B1068 13 [009] - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 209980 km
Date: 2018.05.15
Time: 23:15:01
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11260
Shop #: WSC 00788
VCID: 2F88C4337E12486A6CE45E-807A
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H38 0034
Coding: 030B1A5A
VCID: 74020B5FD7B4BFB2D1B6A9-8020
Subsystem 1 - Part No SW: 6R0 915 181 D HW: 6R0 915 181
Component: J367-BDM H07 0180
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 G HW: 7P6 035 730 G
Component: TELEFON H09 2730
Revision: 1B001001 Serial number: 00007660128307
Coding: 0800000000000210
ASAM Dataset: EV_UHVNA A01015
ROD: EV_UHVNA.rod
VCID: 3686F1578148E5A22F2203-8062
End-------------------------(Elapsed Time: 02:52)--------------------------
It's weird, it should work correctly.
Hmm... enter this coding in both rear WRMs.
18BC32
I don't think it's related, but it's about trying something new. I have this coding in my rear WRMs from factory. (they are the same as yours.)
BCM, Bluemotion, I don't know what to think.
Tell us if you appreciate any change.
18BC32
martijnoss
- Drives: polo 6r
Hi ciclo
Thanks for you're help but it make no difference.
I have googled for 1 evening but I can't find it.
I thought of was a minuten but after 20 seconds or so of won't work anymore.
Test these codings for front WRMs
Coding: 0400A3
Coding: 1400A3
Coding: 0400A3
Coding: 1400A3
martijnoss
- Drives: polo 6r
First of al thanks for the reply.
I have tried the last code but it make unfortunately no difference, I have tried them with my original coding in the back and the one you give.
I was thinking the mirrors are Chinese, does make that the problem.
It is working(between the short tine) so I don't think so.
ps
i am looking already for originals for the case that is the problem, i wil solve it because it must work.
does the 6C mirrors fit like number
6C1857507C9B9
ps
6C1857507C9B9
It's the way to do it, well done.martijnoss wrote: Thu May 17, 2018 8:57 pm I have tried them with my original coding in the back and the one you give.
If they're VW OEM there is no problem.martijnoss wrote: Thu May 17, 2018 8:57 pm I was thinking the mirrors are Chinese, does make that the problem.
If they work, they're fine.
Yes.
martijnoss
- Drives: polo 6r
Hello again.
Now i got a little bit of a headache from the mirrors.
Yesterday i was at the scrapyard and take 2 original mirrors 6C1857507C9B9, 6C1857508C9B9.
But still dont work.
I tried every coding you give me, also in combination.
I dont want to give up but i dont know where to search/look now.
The wiring was the same as the chinese.The pictures are from the oem mirrors.
The problem is not in the wiring because the mirrors worked. Not in the correct way, according your explanation, but they did it.
I don't have other solutions.
martijnoss
- Drives: polo 6r
oke, thanks for youre help anyway.
I dont give up, is it possible that the motors with software 9610 are fault beceuse then i look for the same motors u have.
S8612 u have right?
Is it safe to reset the bcm to factory defaults?
S8612 u have right?
My WRMs
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Coding: 1000A3
Who did your current BCM coding?
Coding: 0200A3
Coding: 1000A3
What do you mean by "Reset"? Do you have this option in your VCDS?
martijnoss
- Drives: polo 6r
Hi
I thought it was factory default, but proberly there is factory mode.
now i have bought an genuine cable and wednesday the delivery guy is gonne bring him.
My bcm is a 88 they should do the trick right.
Looking for the wrm with you're or iichell S numbers.
Edit:Today i bought 2 wrm 6R0959801BD 6R0959802BF 8612, tommorow i install them.
Edit2: yeah ik have install the other wrm with the S8612 and now it worked flawlessly with coding 0200A3 and 1000AB, with the china cable but tommorrow i have a real one because i needed that anyway.
I would thanks everyone and special thanks to Fernando.
Up to a new project.
I think a steering wheel.
Thanks to you for sharing your experience with us.
