9n Sony Headunit Help
Discuss In Car Entertainment
GaryUK
Post by GaryUK »
I was wondering if you anyone could help,
I've recently installed a Sony CD player in the dash. At first when I turned off the ignition and took the key out it reset the unit and lost the radio stations etc. so I rewired it up so that it always had power, now you have to manually switch off the headunit or take off the front face when you take the key out which is a slight inconvenience. Is there a way to set it up so that when you take out the key it turns off the headunit but keeps the radio stations?
Any help would be greatly appreciated!
SiDaBa
Sponsor
Post by SiDaBa »
DId you ever try the adapter you can get from halfords? Think this is a similar problem i had in my gf's lupo she has minidisc player in hers and everytime she took the key out you lost the time and the stations. Used the adapter and there hasn't been a problem since :)
GaryUK
Post by GaryUK »
Yeah I bought it from Halfords and they told me to use this adaptor but it's got the wrong connection for my headunit! :roll:
They must have given me the wrong one!
SiDaBa
Sponsor
Post by SiDaBa »
must have done if it doesn't fit. Where doesn't it fit exactly?
GaryUK
Post by GaryUK »
All sorted now with the correct adapter! 8)
SiDaBa
Sponsor
Post by SiDaBa »
Cool, did you find out what adapter they'd given you?
carmadaaron
Post by carmadaaron »
how much are the adapters? im thinking of getting a new aftermarket head unit.
GaryUK
Post by GaryUK »
The one for mine cost £12.99.
What headunit are you thinking of getting?
carmadaaron
im on a low budget , suthing like £100. i like sony.
What do u reckon? :roll:
GaryUK
Post by GaryUK »
I got mine for £75.00 from Halfords, it was a bank holiday offer half price.
dunno if they are still doing them that cheap though.
carmadaaron
did u fit it urself? i cant get the unit out :!:
GaryUK
Post by GaryUK »
With a little help from my dad! :)
It just needs some gentle persuasion!
moynas
Post by moynas »
Dude you didnt need to buy the adapter!
when you look at the wires comein out on the sony unit there is to main wires one yellow and one red! (ignition and power) they both have joiners in them and the yellow has a two way connecter in the middle!
split the two the two wires and link the yellow to red then the red to yellow! this gives the ignition wire a pos feed which saves your memory!
Do car fits at weekends you see Bros colchesters ripspeed specalist!! only german cars needs these wires changed!
GaryUK
Post by GaryUK »
Cheers for the info :)
It's all working now so can't be bothered take it all out again!
