Access to Reverse Light Switch - SOLVED
Lester
Drives: 2008 Polo 9N3 1.4 BUD
Post by Lester »
Hello Everyone,
I need to check the wires coming out of of the reverse light switch because only the left reverse lamp is working. I have confirmed that the right side bulb is not busted and that there is no electricity coming out of the wire/connector. My first question is: do I access the reverse light switch from the top when I open the bonnet or I have to go under the car? My transmission is automatic. Thanks.
Lester
Re: Access to Reverse Light Switch
Post by Lester »
I am still trying to find the reverse light switch. My transmission code JUF. How is the reverse light switch connected to the circuit, in series or parallel? If I still have one of the reverse lights working am I looking at the wrong component?
alexperkins
Site Admin
Post by alexperkins »
The 9N3 only has one reverse light. The drivers side is the fog light and has a red filter
Lester
Post by Lester »
alexperkins wrote: Sun Jun 03, 2018 11:10 am The 9N3 only has one reverse light. The drivers side is the fog light and has a red filter
You are the best, alexperkins! Thank you so much.
I have never seen a car with only one reverse lamp so I thought the driver side was broken.
I was able to activate the rear fog lamp by putting the knob in headlight position and pulling it, then the driver side lamp that I thought was a reverse lamp magically glowed! :)
alexperkins
Site Admin
Re: Access to Reverse Light Switch - SOLVED
My pleasure. Most VWs only have one :)
