Vcds security access code
redpolo6r
Drives: @redpolo6r
Post by redpolo6r »
Hello, can sameone tell me vcds security access code? I want to enable stagging on my vw polo 6r 2010 1.6TDI 66kw.
Dink
Drives: 2015 GTI
Re: Vcds security access code
Post by Dink »
If you go to security access first then hover over the box to enter the number with your mouse it should pop up with the code you need.
peter_dk25
Drives: Blue GT
Post by peter_dk25 »
Dink wrote: Tue Jun 26, 2018 9:00 pm If you go to security access first then hover over the box to enter the number with your mouse it should pop up with the code you need.
Not in all locations
redpolo6r
Drives: @redpolo6r
Post by redpolo6r »
like peter_dk25 said. Not in my case :(
peter_dk25
Drives: Blue GT
As far as I remember Staging is done in 17 Instruments, 10 Adaption. No code is needed for this in the 6R. It's called "Indicator Celebration" in the Menu. You find it near the end of the Adaptions. Search YouTube
redpolo6r
Drives: @redpolo6r
Post by redpolo6r »
yes i found it but i can turn it OFF/ON. I need this security access code :(
peter_dk25
Drives: Blue GT
Strange? I have a Blue GT 6R and it did not ask for any security code in order to activate Staging in the Adaption channel.
maklan wrote: Wed Jun 27, 2018 5:02 pm yes i found it but i can turn it OFF/ON. I need this security access code :(
NO.
It's highly probable that due to the old software (2010) of your Instrument cluster (IC) it is not possible to activate the "indicator celebration" function through VCDS.
This has already happened to others.
In the forum there are experts who could edit the eeprom of your IC to make it possible. (search)
redpolo6r
Drives: @redpolo6r
Post by redpolo6r »
i think you are right because i can see Indicator_celebration but i can turn it on.
That is bad news for me :(
i really like stagging :cry:
