VW Polo 2010 6R 1.6tdi ABS lost code help
polo101967
Drives: vw 2010 1.6tdi
Post by polo101967 »
Hi Guys
Would any person on the forum know how to decode a longcode on vw 2010 polo 1.6tdi RHD.
The unit had code lost when I got the car. Any help would be great, I can post autoscan if their are any genious that can work it out for me.
Re: VW Polo 2010 6R 1.6tdi ABS lost code help
Yes please post An autoscan
polo101967
I posted but i think admin have to allow. Scan
polo101967
VIN :: WVWZZZ6RZAU034427
VCDS Open Controller ABS window Display>
VAG Number: 6R0 907379 R Component: ESP 8.2i front H04 0002
Soft Coding: Long Coding Shop#: Imp 790 WSC 31414
Extra: Geraet 31414
Address 03: ABS Brakes
Control Module Part Number: 6R0 907 379 R
Component and/or Version: ESP8.2i front H04 0002
Software Coding: 000000000000000000000000000000000000
Work Shop Code: WSC 31414
VCID: 4D96B276104A5E2C9F-8018
Advanced Identification
Flash Status
Misc.
Hardware number: 6R0 907 379 R
VCDS Info:
Labels: 6R0-907-37X-ESP82.CLB
AUTOSCAN INFO BELOW:
VIN: WVWZZZ6RZAU034427 License Plate: 34E323
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 2E 44 56
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 BC HW: 03L 906 023 D
Component: 1,6l R4 CR td H13 8876
Revision: --H13--- Serial number:
Coding: 00114014000500080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM16TID02103L906023BC 003007
ROD: N/A
VCID: 68D863E293E89B048C-803C
No ASAM data for: "EV_ECM16TID02103L906023BC" (VW36 *)
1 Fault Found
10162 - ROD - Unknown Error Code
- 00 [109]
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 115727 km
Date: 2095.14.16
Time: 14:37:35
Readiness: 0100 0000
Cannot be reached
Address 08: Auto HVAC (J301) Labels: Redir Fail!
Part No SW: 6R0 820 045 J HW: 6R0 820 045 J
Component: Climatic 24 0660
Revision: 00 10 24
VCID: 3566FA969CDA36ECC7-8060
Part No SW: 6R0 937 087 H HW: 6R0 937 087 D
Component: BCM PQ25 H+4 H46 0230
Revision: BF046001 Serial number: 0147 016102506
Coding: 25B02BBF08E12400923000003D2B0CD00000410F60060000200000000000
Shop #: WSC 00525 210 97013
VCID: 428C914ADD14915472-8016
Subsystem 1 - Part No SW: 6R0 959 802 R HW: 6R0 959 802 R Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 006 0903
Serial number: KU0-KU022.01.1010459
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 801 T HW: 6R0 959 801 T Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 006 0902
Serial number: KU0-KU021.01.1014688
Coding: 08BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 4 - Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
Component: J388__TSG_HL 006 0902
Serial number: KU0-KU014.01.1010507
Coding: 08BC32
Subsystem 7 - Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
Component: J389__TSG_HR 006 0902
Serial number: KU0-KU005.01.1016297
Coding: 08BC32
Address 15: Airbags (J234) Labels:. 5K0-959-655.clb
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10Airbag00B H09 0018
Revision: -------- Serial number: 003DW00BJTS6
Coding: 003042
Shop #: WSC 31414 790 31414
ASAM Dataset: EV_AirbvAW10BPAVW250 A01001
ROD: N/A
VCID: 428C914AD514915472-8016
Subsystem 1 - Serial number: 3572SRB40000A71CC93C
Subsystem 2 - Serial number: 3582SRB40000A88D1199
Subsystem 3 - Serial number: 3516GRB402H9M2G71REI
Subsystem 4 - Serial number: 3526GRB401NAE7GP5S2X
No ASAM data for: "EV_AirbvAW10BPAVW250" (VW25)
Address 17: Instruments (J285) Labels:. 5K0-920-xxx-17.clb
Part No SW: 6R0 920 961 D HW: 6R0 920 961 D
Component: KOMBI H03 0205
Coding: 440A00
ASAM Dataset: EV_KombiU_DS_VDD_RM09 A04052
ROD: N/A
VCID: 377AF09E8ED6C4FCD5-8062
No ASAM data for: "EV_KombiU_DS_VDD_RM09" (VW36 *)
Address 19: CAN Gateway
Cannot be reached
Address 25: Immobilizer
Cannot be reached
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7667763636
Coding: 010000
Shop #: WSC 00000 000 00000
VCID: 26442DDA517C4D747E-8072
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10130
Shop #: WSC 31414
VCID: 2E54D5FAED8C053486-807A
Part No SW: 5M0 035 186 AA HW: 5M0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 01000000 Serial number: VWZ1Z2K7008460
Coding: 0100040002
VCID: 6BD21CEE8A1EB01CE1-803E
End-------------------------(Elapsed Time: 03:13)--------------------------
allowed, sorry for the delay.
Give this coding a try please: 230224E3437000B6C42924E4C2D800920700
polo101967
Thanks I will try it tonight when finished work and update you, thanks for the fast reply
polo101967
Hi tried the code but it was rejected, I accessed ABS module and pasted code"do It" and got reject.
From looking at web I sort of worked out below code but it is also rejected.
210228C2217000B6842914E482D800421000
no the code you found is LHD.
230228E3417000B3C42A14E482D300920700
230228E3417000B3C42A14E482D300420700
230228E3417000B3C42A14E482D300820700
try these please
polo101967
Sorry, no luck with these. Really appriciate the time
Car is polo hatchback 2010 1.6tdi rhd.
Maybe it needs to go to vw, would that be normal for this model ?
yes, you could take it to VW and ask them to retrieve the factory coding of your module.
I would appreciate if you could tell me the new coding of the ABS module, if you decide to retrieve it.
polo101967
Thanks for your help, I will post them when I get it sorted.
