Alloy wheels upgrade ?
Andy1273
- Drives: 1.2 tsi polo
Re: Alloy wheels upgrade ?
Just another quick question guys, do I need to change the tyre pressure sensors when upgrading ?
Dink
- Platinum Member
- Drives: 2015 GTI
No it's a passive system on the polo.Andy1273 wrote: Sat Nov 17, 2018 9:09 am Just another quick question guys, do I need to change the tyre pressure sensors when upgrading ?
Will just need to reset the tpms when you change wheels.
Andy1273
Thanks,
May I ask also what's the opinion on fitting wheel spacers?
Good , bad?
Dink
- Platinum Member
- Drives: 2015 GTI
I'm running 15mm on the rear of my gti and then 12mm on the front to clear the brakes.
Once I can afford the wheels the I want they will be coming off lol
Andy1273
To clear the brakes? Why?Dink wrote: Sat Nov 17, 2018 1:54 pm I'm running 15mm on the rear of my gti and then 12mm on the front to clear the brakes.
Are the wheels you want wider so no need for the spacers?
Any particular ones, brand to look at getting? I've had a quick look on eBay, but choice is vast on there and if I were too buy some sets I'd like decent ones.
Dink
- Platinum Member
- Drives: 2015 GTI
The ones I have are h&r but they were second hand but had a good deal as it included bolts and locking bolts.Andy1273 wrote: Sat Nov 17, 2018 3:08 pmTo clear the brakes? Why?Dink wrote: Sat Nov 17, 2018 1:54 pm I'm running 15mm on the rear of my gti and then 12mm on the front to clear the brakes.
These brakes
