Polo GT TDI Racer – Technical Specification
dxg
Moderator
Post by dxg »
This is the car that's running in the "VW Racing" series, at the moment. You might be interested:
Engine: Front, transversely mounted 1896cc diesel. Four cylinder 8 valve, turbocharged, direct injection. Volkswagen Racing ‘Cup’ Turbo
Engine management: Bosch EMS with Superchips mapping
Max power (PS @ rpm): 210 / 4000
Max torque (lbs ft @ rpm): 280 / 1750
Drive: Front wheel drive
Gearbox: 5 Speed, limited slip differential
Clutch: Sachs sintered metal plate
Exhaust: Bespoke high flow system
Bodyshell: Full competition shell with welded in multi-point roll cage, Volkswagen Racing aero kit
Safety: Sabelt seat, built in fire extinguisher system, 6-point safety harness
Steering: Power assisted (hydraulic) rack and pinion
Brakes: Volkswagen Racing drilled front discs and callipers. Standard Volkswagen solid rear discs. Adjustable bias. Mintex racing pads front & rear
Front suspension: KW Fully Adjustable struts with lower wishbone and anti-roll bar. Solid top mounts with camber adjustment. Uprated bushes.
Rear suspension: Rear semi-trailing arm with uprated bushes, Adjustable KW dampers
Wheels: 7x17" light alloy race wheels
Tyres: 215/40 ZR 17
Weight (kg): 1003
Joy
Post by Joy »
Nice.
This car has got some serious anti-roll bars :-)
No wheel movement whatsoever.
Damn I would like the Polo to have a bigger engine.
bstardchild
Moderator
Post by bstardchild »
Now I'm absolutely positive - I'm satin blacking my newly aquired BBS Split rim GTi Alloys :lol:
bstardchild
Moderator
Joy wrote:Nice.
I think the springs are coilbound :roll:
