from cruise control to adaptive cruies control...is possible?
massimo23
- Drives: Polo Beats 2017
Hi. I am happy with the cruise control in my polo beats 2017 but would love if it could slow down or accelerate without intervening all the time. I have the j428 acc radar installed hw 5Q0907572F which is used for front assist. i have bcm pq26 Hi4R J519 hw 6C0937089. My dashboard is KOMBI hw 6C0920740E and gateway is GW MQB A0 hw 6C0937089 version H10. I know that my steering wheel is missing the acc button in the middle but i saw the steering model 6C0419091G which seem compatible and same as mine only with the extra acc distance button. is it possible to get acc? I know that settings are necessary in obd. Thanks
Re: from cruise control to adaptive cruies control...is possible?
I'm afraid the ACC function will very likely be limited to a car that has it enabled from factory. You could inform at your dealer about so called 'SWAP' or 'FEC', respectively SoftWare As a Product or Function Enabling Codes. This is almost certainly something that we cannot do ourselves. If possible, you need to do it the legal and expensive way through the dealer. CCS on MQB is a paid function, it's not an easy retrofit.
massimo23
Thanks iichel. Just for information do you know if acc needs the a5 front camera used for lane assist.
It is not necessary for polo 6c
