6n2 1.4tdi intermittent misfire to full misfire lumpy running
train050
Drives: 1.4tdi 6n2
Post by train050 »
hi all, i have had a search but cant seem to find anything that is the same as this issue.
1.4tdi 2001 polo 6n2
What i have done
- clear fault codes
- change fuel filter
the car starts up no problem then when driven will feel like a misfire. it will do this maybe once every 30 seconds. within a few minutes it'll eventually get worse to the point its fully lost power and continuously judder and feel like its only running on 2 cylinders.
if i turn the engine off, then on again sometimes it'll do the same again. other times it will cure the problem completely.
there are no new fault codes and no dash lights.
does anyone have any idea what this may be and what the best order of parts to maybe replace are?
thanks in advance!
John24
Drives: Polo 1.2 twist
Re: 6n2 1.4tdi intermittent misfire to full misfire lumpy running
Post by John24 »
The first thing I would check is compression on all cylinders. Remove all spark plugs and take out fuses for the fuel pump and ignition systems. Put the compression test kit into each cylinder and crank for 8 turns at minimum. Report back with results.
alexperkins
Site Admin
Post by alexperkins »
Could be a faulty/blocked injector, or a fault on the injector loom. I would test that and go from there
WilliamButcher
Post by WilliamButcher »
Same thing happens with mine,
First there was a full on broken spark plug after 93k or so miles
Got the spark plugs replaced but garage installed them wrong so still was not fixed, got them fixed the next day and engine was fine
After around 3k miles on brand new spark plugs it was misfiring again, so took it to the garage where they replaced the spark plugs
After 400 miles it started again but wasn't an actual missifre, just a judder at anything under 1200 revs.
On colder days it was horrible, with me needing to put my foot on the accelerator at idle just so it didn't stall itself, but then later on in the day it is fine
Now at around 98k miles it only judders at idle stopped at a light every 20 seconds or so, taking the revs back up to 1000 then back down to 850 or so (EMS kicking in I think)
Going to take it to a different mechanic to see what they say and failing that taking it to a VW garage as they will sort out the issue but understandably at a large premium.
Should be sorted in the next two weeks hopefully
Crofty
Post by Crofty »
TDi..... I doubt spark plugs are responsible for poor running.
Injector loom is a possibility. It's located under the cam cover, and you can see the end of it as a big circular connecter on the gearbox end of the cylinder head, it's easy to change if it needs to be replaced.
viorelt
Drives: 6n2 1.4 TDI
Post by viorelt »
Hello to all! I have a polo 6n2 1.4 TDI, year 2001, AMF 3 cylinder motor.
I have a missfire on cylinder 2 and code "P1667 35-10 electrical malfunction PD Unit injector ; Cylinder 2 (N241)" with VAGCOM .
My question is what is the order number of cylinders? How do I find cylinder 2?
Thank you for your time!
alexperkins
Site Admin
Cylinders are left to right from the timing belt so when looking at the engine with it in front of you
