Metal Wire Under Rear Passenger Seat - SOLVED
Lester
Drives: 2008 Polo 9N3 1.4 BUD
Post by Lester »
Hi All,
I noticed two metal wires under the rear seat (passenger side). This is the single seat in the back that you can fold. Please see the picture below.
They run from the back to the front and you can already see them protruding on the front side. If I don't do anything, I think those wires will tear through the seat cover over time. The other seats are fine. It seems like they have torn through the foam/cushion.
Is this something that I can fix or I need to buy a new seat? Need some advice. Thank you.
Lester
Re: Metal Wire Under Rear Passenger Seat
Post by Lester »
This has been fixed.
It was just the padding wire that came unhooked from the padding. :D
Re: Metal Wire Under Rear Passenger Seat - SOLVED
Good Result!
Lester
Post by Lester »
RUM4MO wrote: Sat Dec 22, 2018 8:44 amGood Result!
Thanks, RUM4MO. I just realized that I should have placed the padding wire not from the top but under the other wire making it deeper in the groove.
Well, I can just do it next time I remove the seat cover. :)
