Hi there.
New to the forum and just after some input on the above problem.
I drive a 2013 VW Polo 1.2 Match Edition.
Last weekend my engine management light came on in my car. While driving home I then noticed my tyre pressure light comes on and 10 minutes later the ESP light comes on.
When I got home I checked all tyre pressures, and pressed the reset button in the glovebox leaving just the Engine Management light on. My brother popped round and plugged in a ODB2 reader (think that's what they are called) and it came up with:
P0341 - Camshaft Position Sensor A Circuit Range/Performance Bank 1 or Single Sensor.
We cleared it and then I drove it and after about 20 minutes it came back on. Following morning I went to work and the ESP light came back on followed by the Tyre Pressure light again.
Tyre pressures all checked and all seem fine.
Any ideas what it could be and whether I am in for a hefty bill?
Car is on 62k and apart from new disks and new exhaust back in July, has rarely been a problem. Booked into garage on the 3rd of January (using works van for now) but trying to budget for repair and after some horror stories I have read relating to these warning lights....the potential for a new car!
Engine Management, ESP and Tyre Pressure lights all on.
StevenGibbs86
- Drives: 2013 VW Polo 1.2 Match Edition
Re: Engine Management, ESP and Tyre Pressure lights all on.
Check the fuses i'd say..
Dink
- Platinum Member
- Drives: 2015 GTI
I'd say faulty abs sensor.
MalcolmHutcheon
Just for info, had exactly the same symptoms - came across this thread while look for a solution. Booked it in to VW and had to have a new cam chain and all the extras fitted. Not a cheap fix, but at 67k miles it was probably close to being due for changing anyway.
Car is a 1.2 3-cylinder on a 2012 plate.
It would be helpful if the OP came back and detailed what that issue was due to!
Edit:- surely he was not another "one post wonder"?
