Orange triangle exclamation mark means what?
JohnF
- Drives: 2018 Polo SE 95
Had a drive into some wintery weather yesterday. Temp -1c, snowing and starting to lay on the road and strong wing.
The warning sign comes on and then after 20 mins or so goes off meaning what?
I ignored it as the only other time I've had a warning was for the tyre pressure dropping (which wasn't the case) but this threw up a message in addition to the symbol. That wasn't the case yesterday
Any ideas?
Any ideas?
Andy Beats
Re: Orange triangle exclamation mark means what?
Which one is it here?
https://www.volkswagen.co.uk/owners/warning-lights
Check in your owner’s manual - should be under ‘Instrument cluster -> warning and indicator lamps’.
In the manual for my previous generation Polo, when the triangle symbol with an exclamation mark is displayed, it’s to warn you that there should be additional information displayed on the instrument cluster - presumably some form of ‘be aware’ or warning message or information.
Could be the front assist not working? Happened to me yesterday driving through a blizzard. Too much ice over the sensor caused it to have a fit.
Andy Beats
You would think (hope...) the driver is noticing the great big message that comes with the warning light.broberty wrote: Fri Jan 18, 2019 12:52 pm Could be the front assist not working? Happened to me yesterday driving through a blizzard. Too much ice over the sensor caused it to have a fit.
Mine did it two nights ago and the main display had "vision impaired" on it.
I'm hoping this is a warning light only.
The car should tell you what the symbol denotes.
Yellow for advisory, red for obligatory.
Yellow oil sign = please top up at next opportunity.
Red oil sign = stop now don't drive any further, get your car repaired.
JohnF
Ok it was yellow not orange! My manual page 14 says "Central Warning Lamp. Observe additional information on instrument cluster display"
Should this additional information show continually in the centre of the display (like my previous tyre warning) If so it didn't as far as I recall.
Andy Beats
Ok, so next time you see the orange warning you need to look at the central display to see what it's warning you of.
Going by the description of the weather at the time, I'm willing to bet the radar was "impaired", just like mine the other night.
Welcome to the wonderful world of VW front assist.
JohnF
That's what I wondered it was. Never had a modern car as baffling as this one.
For me it was driving rain that stopped the radar from working. its the only time I have had a yellow warning triangle.
I think the little wizard or whatever lives under the bonnet that can see the car in front must have an issue in heavy rain or snow. I think its telling you the Adaptive part of cruise control is not working. Same with front assist. Obviously be careful do not rely on adaptive cruise or front assist if that warning triangle shows in heavy rain or snow .
JohnF
Thanks but I don't have adaptive cruise control. Is front assist the emergency radar braking?
Yes and I think all SE and up Polos have front assist emergency braking.JohnF wrote: Sat Jan 19, 2019 9:31 am Thanks but I don't have adaptive cruise control. Is front assist the emergency radar braking?
vc-10
- Drives: 2019 Seat Ibiza 1.0 TSI Xcellence Lux
All Polos have Front Assist. It's becoming a standard thing across most new models now, as it's needed to get a decent score on the EuroNCAP tests. Same as with the speed limiter.
My Fabia has also given a similar warning in really bad rain. Water gives quite a good return on radars, and too much water falling down infront of the sensor will confuse it, just like lots of water falling in front of your eyes mean you can't see that far either!
