Main light plug
Andy1273
- Drives: 1.2 tsi polo
Main light plug
Hi.
Has anyone got a wiring diagram of the main light plug wiring harness for a 6C .
Or tell me which pin number or coloured wire the side lights are?
Thanks in advance.
Thanks in advance.
Andy1273
Re: Main light plug
I'm wanting to put in a small resistor into the side light wiring so need to know which is the side light wire from which pin and the earth ?
Re: Main light plug
Hi Andy1273
PM. Check your inbox.
Please, don't reply to my private message. Thank you.
Halogen headlights:
Basic equipment , (L0R)
No 31/8 , 31/9
T10/10 (58l/58r signals)
Halogen headlights:
No 31/8 , 31/9
Andy1273
Re: Main light plug
I've sorted it out by wiring in a resistor to pin 10 the side light and earth pin 5. Used a 10w resistor.
They get warm too touch is this normal?
Could I indeed actually wire in a side light bulb holder instead in place of a resistor?
Re: Main light plug
Yes, it's normal.
What's the reason for attach resistors to the side lights wires? LEDs bulbs? Front, Rear?
Re: Main light plug
With the introduction of the Polo 6C (MQB-A0 platform), it should be possible to set dimming values to the lights with VCDS. I'm not completely sure how, though.
Some more information on the subject: https://drive.google.com/open?id=0BxYPV ... GdKYVJ3eEE
Re: Main light plug
It's an excellent job!
DV52 is admirable, I've read many of his works and support/help to others.
Re: Main light plug
hi.. i saw from your previous posts.. i wonder if you could help me i need main light plug wiring diagram for polo 6r halogen h7 Thanks in advance.ciclo wrote: Thu Feb 07, 2019 4:21 am Hi Andy1273
Halogen headlights:
No 31/8 , 31/9
Re: Main light plug
Hi, check your inbox.
Re: Main light plug
Hi, would you be so kind to send me the 10-pin diagram for the Polo 6C headlight harness to me?ciclo wrote: Mon Oct 11, 2021 11:44 am Hi, check your inbox.
Please, don't reply to my private message. Thank you.![]()
Re: Main light plug
https://drive.google.com/file/d/0B2nv91 ... Fo9JXQYHxw
I don't know if any permission is required to download the PDF file. Do it and it will be granted.
Re: Main light plug
Thank you very much!ciclo wrote: Thu Oct 13, 2022 9:34 pm https://drive.google.com/file/d/0B2nv91 ... Fo9JXQYHxw
I don't know if any permission is required to download the PDF file. Do it and it will be granted.![]()
