sshakthi123
Posts: 147 Joined: Sat Oct 27, 2018 5:55 am
Drives: Vento 1.5 TDI MT and Polo 6R 1.2 Tsi Dsg
Post
by sshakthi123 » Thu Feb 21, 2019 1:59 pm
ciclo wrote: Thu Feb 21, 2019 1:47 pm
Since your new BCM Max 7E0937090
D (last model 7E0) is manufactured for LED headlights (8IT), it is new for all of us.
It is not the first time that a BCM PQ25 is parameterized differently to the previous ones.
Clarified. Thank you
3A904BFF48A10000013806507CEB96904D80600F608C2141220000030000
I will try this in next 2 hours and revert back.
I understand you are helping me in your crunch time, but I really wanted a help to fix rain closing of windows. Help may be in terms of sourcing the right part / right coding, etc. This is one of the primary reason for me to update the BCM.
Posts: 8838 Joined: Sun Feb 24, 2013 10:20 am
Post
by ciclo » Thu Feb 21, 2019 2:51 pm
Clear like the water:
Subsystem 2 - Part No SW: 6R0 959 802 BH HW: 6R0 959 802 BH Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU021021440523980
Coding: 1400B3
Subsystem 3 - Part No SW: 6R0 959 801 BC HW: 6R0 959 801 BC Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 8611
Serial number: KU0KU004101300011381
Coding: 0400B3
... and all the functions will work like a charm!... auto folding mirror function too.
sshakthi123
Post
by sshakthi123 » Thu Feb 21, 2019 6:14 pm
ciclo wrote: Thu Feb 21, 2019 2:51 pm
Coding:
1400B3
Coding:
0400B3
Nope. Changing the RLS coding to
0728DD made
rain closing windows are working now .
Tried the following,
1. keep windows down ->
locked the car -> pour water immediately -> and it
rolled up the windows
2. keep windows down ->
DIDN't LOCK the car -> pour water immediately -> and it
3. followed same procedure of #1 and #2 but
pour the water after 5 to 10 mins ->
THIS DIDN'T ROLL THE WINDOWS
4. car running(on) -> windows down -> pour water ->
this also didn't roll up the windows
Please confirm this is the right behavior.
This made no changes. Still the back-up light error continues.
here is the latest scan,
Thursday,21,February,2019,22:18:25:00006
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: MEXJ1760XJT075118 License Plate: 8854
Mileage: 18080km-11234mi Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 56
VIN: MEXJ1760XJT075118 Mileage: 18080km-11234miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CWXC) Labels: None
Part No SW: 03L 906 023 RS HW: 03L 907 425 B
Component: R4 1.5l TDI H33 9977
Revision: --H33--- Serial number:
Coding: 00110116032500080000
Shop #: WSC 00000 000 08192
ASAM Dataset: EV_ECM15TDI02103L906023RS 001002
ROD: EV_ECM15TDI02103L906023QT.rod
VCID: 081F2E22B3333D0450-805C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 CA HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0004
Serial number: --------------
Coding: 60DD2F63212A04C50615F46A845920020000
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH_VW25.rod
VCID: 7F0DB5FEE6FD7ABC61-802A
Serial number: 03111813470922
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF348FAE1F773B46A-802A
1 Fault Found:
1140738 - Steering angle sensor
B1168 54 [009] - Missing Calibration / Basic Setting
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 3
Mileage: 18081 km
Date: 2015.06.02
Time: 10:12:59
Voltage terminal 15: 13.70 V
Voltage terminal 30: 13.95 V
Terminal 15 status: On
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 4189F306D889CC4C57-8014
Part No SW: 7E0 937 090 D HW: 7E0 937 090 D
Component: BCM PQ25 Max4 H82 0762
Revision: B9082001 Serial number: 8601 222180856
Coding: 3A904BFF48A10000013806507CEB96904D80600F608C2141220000030000
Shop #: WSC 12345 123 12345
VCID: 2C57B2B24F0B312494-8078
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 290617 04 42 0106
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 023 2521
Serial number: 13202848170704050535
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 023 2521
Serial number: 13102849170705002249
Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Serial number: 1811713320101504AB1B
Coding: 240000
Subsystem 5 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 022 1522
Serial number: 13102728170704212031
Subsystem 6 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 022 1522
Serial number: 13102729170630002341
3 Faults Found:
00901 - Back-Up Lamps
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 18063 km
Time Indication: 0
Date: 2015.05.30
Time: 14:21:31
02745 - Bulb for Daytime Running Light; Left
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 18063 km
Time Indication: 0
Date: 2015.05.30
Time: 14:12:53
02746 - Bulb for Daytime Running Light; Right
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 18063 km
Time Indication: 0
Date: 2015.05.30
Time: 14:12:53
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 K HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28231325304021
Coding: 308002
ASAM Dataset: EV_VW75XParkAssis4K 001004
ROD: EV_VW75XParkAssis4K_001.rod
VCID: 3A7B84EABD5F9F9416-806E
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW01BGFS-
Coding: 003036
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4999EB26E8B9040C8F-801C
Part No SW: 6RF 920 862 B HW: 6RF 920 862 B
Component: KOMBI H01 0217
Coding: 1208000000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
VCID: 4B95D12EE2C5161CBD-801E
Part No SW: 7E0 909 901 HW: 7E0 937 090 D
Component: GW-K-CAN TP20 H82 0762
Revision: B9082001
Coding: 002300
VCID: 68DF0EA29B73DD04B0-803C
Component: IMMO H01 0217
Serial number:
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB74AA8D7FEF14A6-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014.rod
VCID: 4189F306D089CC4C57-8014
Address 56: Radio (J503) Labels: None
Part No SW: 6RF 035 187 C HW: 6RF 035 187 C
Component: Radio 557 5515
Revision: -------- Serial number: VWZ7Z2R8103103
Coding: 0E000440000010
Shop #: WSC 12345 123 08192
VCID: 4999EB26E0B9040C8F-801C
End-------------------------(Elapsed Time: 02:27)--------------------------
sshakthi123 on Sat Apr 13, 2019 1:56 am, edited 1 time in total.
Post
by ciclo » Thu Feb 21, 2019 6:56 pm
I see that you have copied my RLHS coding. Congrats.
Actually no one knows what is the "Rain Closing" behavior on the PQ25. Maybe the one you describe is correct.
Your BCM 090D has an unusual behavior for lights diagnostic. It is currently coded so that it does not detect faults in DRLs or reverse light.
Well, let's start from 0, try the following coding:
3A904BFF48A10000013806007CEB96900980600F608C2141220000030000
Post
by ciclo » Fri Feb 22, 2019 1:35 am
Other way,
Reverse light
Play with the following combinations in BCM Byte11 Bit4 and Bit6.
00, 01, 10, 11
0 = disable
1 = enable
Remember, the previous stored faults always must be cleared before or during functional tests for new coding/condition .
DRLs
The same but in BCM Byte16 Bit2 and Bit6
sshakthi123
Post
by sshakthi123 » Fri Feb 22, 2019 1:53 am
ciclo wrote: Fri Feb 22, 2019 1:35 am
Other way,
Reverse light
00, 01, 10, 11
0 = disable
1 = enable
DRLs
The same but in BCM
Tried both the ways. It didn't help.
The errors continuing ,
Friday,22,February,2019,08:26:20:00006
www.Ross-Tech.com
Readiness: 0 0 0 0 1
Coding: 01
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 18081 km
Date: 2015.06.02
Time: 20:06:02
Voltage terminal 15: 12.50 V
Voltage terminal 30: 12.70 V
Revision: V0000000
Coding: 3A904BFF48A10000013806007CEB96900980600F608C2141220000030000
Coding: 0714DD
Coding: 350000
Coding: 040000
Coding: 240000
3 Faults Found:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 18081 km
Time Indication: 0
Date: 2015.06.02
Time: 20:06:03
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 18081 km
Time Indication: 0
Date: 2015.06.02
Time: 20:06:03
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 18081 km
Time Indication: 0
Date: 2015.06.02
Time: 20:06:03
Coding: 308002
Coding: 003036
Coding: 1208000000
Revision: B9082001
Coding: 002300
Serial number:
End-------------------------(Elapsed Time: 02:34)--------------------------
sshakthi123 on Fri Feb 22, 2019 3:05 am, edited 1 time in total.
sshakthi123
Post
by sshakthi123 » Fri Feb 22, 2019 1:57 am
ciclo wrote: Thu Feb 21, 2019 6:56 pm
sshakthi123 wrote: Thu Feb 21, 2019 6:14 pm
1. ignition on -> windows down ->
2. ignition on -> windows down ->
Please clarify on the rain closing behavior? does it not close if we try pouring the water after sometime OR if rain comes an hour after the car parked with windows down?
Post
by ciclo » Fri Feb 22, 2019 3:29 am
Clarifications about the behavior of the "Rain closing"
In your country there are the ideal climatic conditions (rain and heat) for someone to leave or forget a baby or small child inside the car and dies. Unfortunately it happens in many countries of the world.
A car closed under the sun can reach extreme temperatures for human life.
I will not give you any more explanations or evasive for the "Rain closing".
I hope your understanding and reasoning about it, strongly recommend that you deactivate the "Rain closing" function.
Post
by ciclo » Fri Feb 22, 2019 3:44 am
Show me an image of the tail light connector for the reverse light.
I want to see how many cables reach it and the colors of them.
You haven't yet done the steering ring calibration... what are you waiting for?
sshakthi123
Post
by sshakthi123 » Fri Feb 22, 2019 1:08 pm
ciclo wrote: Fri Feb 22, 2019 3:29 am
forgetting and leaving a baby/child in a car is not an ideal thing. We cannot complain the features of a car for this
Anyway, leaving the car in Polo/sedan will not harm them as it will NOT work as per
3. followed same procedure of #1 and #2 but pour the water after 5 to 10 mins -> THIS DIDN'T ROLL THE WINDOWS I shared above.
Post
by ciclo » Sat Feb 23, 2019 1:12 am
sshakthi123 wrote: Fri Feb 22, 2019 1:08 pm
... with the right software/hardware it works p-e-r-f-e-c-t-l-y.
I'll not provide free help/support/info to others retrofits not related to the BCM adaptation or automatic lights.
Let's go to solve your 'problem' with the reverse light. (7E0937090D 8IT)
I understand that your reverse light works and that you don't have any warning light on the IC ... and yet the fault is detected on the vcds scan.
Please, try this BCM coding and tell me the result:
3A904BFF48A10000013806407CEB96904980630F608C2141220000030000
I'll send you a new wire depending on the result, everything will be solved regardless BCM coding for reverse light.
Please post the resquested image as soon as possible. Thanks...
viewtopic.php?f=56&t=72122&p=550674#p550588
sshakthi123
Post
by sshakthi123 » Sat Feb 23, 2019 4:32 am
ciclo wrote: Sat Feb 23, 2019 1:12 am
Let me know how you can help with this including the cost. I would like to get this set up.
This coding didn't help, the error continues.
Saturday,23,February,2019,09:17:33:00006
www.Ross-Tech.com
Coding: 01
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 18085 km
Date: 2015.06.03
Time: 21:03:42
Voltage terminal 15: 13.30 V
Voltage terminal 30: 13.85 V
Revision: V0000000
Coding: 3A904BFF48A10000013806407CEB96904980630F608C2141220000030000
Coding: 0714DD
Coding: 350000
Coding: 040000
Coding: 240000
3 Faults Found:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 18081 km
Time Indication: 0
Date: 2015.06.03
Time: 20:13:11
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 18081 km
Time Indication: 0
Date: 2015.06.02
Time: 20:26:19
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 18081 km
Time Indication: 0
Date: 2015.06.02
Time: 20:26:19
Coding: 308002
Coding: 003036
Coding: 1208000000
Revision: B9082001
Coding: 002300
Serial number:
End-------------------------(Elapsed Time: 02:26)--------------------------
here are the images,
Nikhil
Posts: 20 Joined: Sun Sep 10, 2017 6:38 am
Drives: 1.6 tdi
Post
by Nikhil » Sat Feb 23, 2019 5:35 am
As per my experience in manual transmission polo sedans in India, Backup lamp is controlled by the gear shifter not by the BCM, although BCM get input signal of reverse lamp from gear shifter.
So T73b/12 to Backup Lamp connection need to be done. Old wire you can cut and insulate. I hope this will solve Backup lamp error.
I had done mentioned procedure in one other car as per ciclos instructions in installation guide.
Best way to see if backup light is now connected to BCM or not is to take output test in BCM for backup light. If it dosent get on in output test means it is Not connected to Bcm. So BCM gives the error of Backup Light.
Post
by ciclo » Sat Feb 23, 2019 5:53 am
Nikhil wrote: Sat Feb 23, 2019 5:35 am
It's the way but it is not absolutely necessary.
Best way to see if backup light is now connected to BCM or not ...
The best way ... is to check the wiring diagrams or have extensive experience and know that in this case it is not connected to terminal T73b/12 , but is connected to terminal T73b/48.
...this doesn't necessarily have to show the fault, depends on the BCM coding.
In this new BCM 7E0 ... D and according to the reports, remove the diagnosis by coding does not work.
Nikhil
Drives: 1.6 tdi
Post
by Nikhil » Sat Feb 23, 2019 6:03 am
ciclo wrote: Sat Feb 23, 2019 5:53 am
T73b/48 is input signal to Bcm for Backup light from gear selector. It dosent give any output to reverse light.
T73b/12 is output of Backup lamp.
Is BCM able to do backup lamp diagnostics from input terminal?
