ciclo wrote: ↑Sat Feb 23, 2019 8:45 am
Sakthi, I'll send it on Monday (absolutely free) and only the masters of the universe will know when it'll arrive to your address. (15-30 days, SP-IND)
Ciclo, installed the wire and the
backup lamp error has gone. Many thanks.
living with the following errors,
1.
DRL bulb errors - I have ordered different bulbs and will be changing in a month time
2.
Steering angle calibration error - I am hearing this will not go up unless we install ESP. Also I couldn't find original VCDS (I feel it is costly to spend $200 purchasing original vcds to clear this error if at all possible). So for now leaving as is.
With this
my installation gets completed ![Very Happy :D](./images/smilies/icon_biggrin.gif)
and I would like to thank you (Ciclo) for all the help you provided and other friends who patiently answered all my silly questions that gave me a confidence doing these. I'm really thankful for all of you.
Ciclo - I will knock the door if I had to install bi-xenon / LED lights in future.
Attaching the latest scan for reference,
Wednesday,20,March,2019,08:40:49:00006
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: MEXJ1760XJT075118 License Plate: MAR20-2
Mileage: 18620km-11569mi Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 56
VIN: MEXJ1760XJT075118 Mileage: 18620km-11569miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CWXC) Labels: None
Part No SW: 03L 906 023 RS HW: 03L 907 425 B
Component: R4 1.5l TDI H33 9977
Revision: --H33--- Serial number:
Coding: 00110116032500080000
Shop #: WSC 00000 000 08192
ASAM Dataset: EV_ECM15TDI02103L906023RS 001002
ROD: EV_ECM15TDI02103L906023QT.rod
VCID: 081F2E22B3333D0450-805C
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 CA HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0004
Serial number: --------------
Coding: 60DD2F63212A04C50615F46A845920020000
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH_VW25.rod
VCID: 7F0DB5FEE6FD7ABC61-802A
Serial number: 03111813470922
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF348FAE1F773B46A-802A
1 Fault Found:
1140738 - Steering angle sensor
B1168 54 [009] - Missing Calibration / Basic Setting
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Mileage: 18629 km
Date: 2015.06.28
Time: 08:37:48
Voltage terminal 15: 12.50 V
Voltage terminal 30: 12.70 V
Terminal 15 status: On
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 4189F306D889CC4C57-8014
Part No SW: 7E0 937 090 D HW: 7E0 937 090 D
Component: BCM PQ25 Max4 H82 0762
Revision: B9082001 Serial number: 8601 222180856
Coding: 3A904BFF48A10000013806C07CEB9690F9C063FF608C2141220000030000
Shop #: WSC 12345 123 12345
VCID: 2C57B2B24F0B312494-8078
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 290617 04 42 0106
Coding: 0714DD
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 023 2521
Serial number: 13202848170704050535
Coding: 350000
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 023 2521
Serial number: 13102849170705002249
Coding: 040000
Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Serial number: 1811713320101504AB1B
Coding: 240000
Subsystem 5 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 022 1522
Serial number: 13102728170704212031
Subsystem 6 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 022 1522
Serial number: 13102729170630002341
2 Faults Found:
02745 - Bulb for Daytime Running Light; Left
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 36
Mileage: 18629 km
Time Indication: 0
Date: 2015.06.28
Time: 08:37:48
02746 - Bulb for Daytime Running Light; Right
Fault Priority: 3
Fault Frequency: 1
Reset counter: 36
Mileage: 18629 km
Time Indication: 0
Date: 2015.06.28
Time: 08:37:48
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 6RU 919 475 A HW: 7N0 919 475
Component: PARKHILFE 8K H06 0018
Revision: -------- Serial number: 28231836203031
Coding: 108002
ASAM Dataset: EV_EPHVA18VW250GP00 001002
ROD: EV_EPHVA18VW250GP00.rod
VCID: 61C913867049AC4C77-8034
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW01BGFS-
Coding: 003036
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4999EB26E8B9040C8F-801C
Part No SW: 6RF 920 862 B HW: 6RF 920 862 B
Component: KOMBI H01 0217
Coding: 1208000000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
VCID: 4B95D12EE2C5161CBD-801E
Part No SW: 7E0 909 901 HW: 7E0 937 090 D
Component: GW-K-CAN TP20 H82 0762
Revision: B9082001
Coding: 002300
VCID: 68DF0EA29B73DD04B0-803C
Component: IMMO H01 0217
Serial number:
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB74AA8D7FEF14A6-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014.rod
VCID: 4189F306D089CC4C57-8014
Address 56: Radio (J503) Labels: None
Part No SW: 6RF 035 187 C HW: 6RF 035 187 C
Component: Radio 557 5515
Revision: -------- Serial number: VWZ7Z2R8103103
Coding: 0E000440000010
Shop #: WSC 12345 123 08192
VCID: 4999EB26E0B9040C8F-801C
End-------------------------(Elapsed Time: 02:28)--------------------------
