Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
Re: Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
There is no wiring prepared. You'll need to run a wire from the fuse box to the relay holder and from the fuse holder to the headlight washer pump. And a BCM and GND wire to the relay.
benzinkopf
- Drives: 1.2TSI 105HP DSG7
thanks iichel. on that note, is it a special relay or just standard one like i bought for my CAN isolation side assist? 4H0951253C?
benzinkopf
out of boredom... 6R”M” 807 833 [emoji38]
trim wheel cover
trim wheel cover
ORiOn
- Drives: Polo BlueGT / Audi S5
From what model is that?
I was looking to buy the ones from a Golf 6R for a while now
benzinkopf
custom 3dprint. i havent check the 5k0 model whether its fit or not. Since its not even there for Polo, i made one.
https://www.shapeways.com/product/QKJAF ... lo-6r-left
ORiOn
Can you share the 3d file?
benzinkopf
normally i wont mind. but for this i need to ask my friend who technically own the data since he asked me to make that for him as he paid for the design cost. will let u know[emoji1362].
benzinkopf
Hi guys,
been busy lately and no progress so far. Btw, I’ve been reading on Flexible Service Interval system. Since my car was produced with PR Code QG1, I plan to switch to FSI from fixed interval of 15k km. But one of the support system of the FSI is the Brakepad Wear Indicator(from what I read). So the question now,is it an issue for the car to switch to FSI without having the Brakepad Wear Indicator? Is it a compulsory prerequisite for the FSI?
benzinkopf
thanks to those who spent their good time and knowledge and never feel annoying with questions and never tired sharing the information!!!!!!!
- ag69
- Drives: 1.2TSi 77Kw 7DSG
Trip shows 2,68,062 KM
This is amazing. DSG as smooth as butter?
benzinkopf
Yurp. surprisingly. i havent change the clutch. dsg all good. only one time, 4years ago (124,000km) i got dsg mechatronic oil leaking. so the mechatronic was replaced.
benzinkopf
Test changed the Side Assist code to use the switch inside MFD instead of external physical button since this menu is accessible while driving.
Then Just checking the measure blocks and wondering what the index 8 means. Btw, I checked the adaptation channel, it seems like MKE is 0 value and i cant put 1 to test. VCDS will crash.
