BlueGT Front Brake Disc
MarkoPolo
Drives: 6R Polo Blue GT
Post by MarkoPolo »
Looking to replace the front discs and pads on my 6R BlueGT.
Does anyone know what size disc I need? There seems to be 3 options, 256mm, 288mm and 312mm.
I've recently changed the back pair to some Brembos and now that GSF have another 60% sale, I thought I'd treat the front too :P
Thanks,
Re: BlueGT Front Brake Disc
Well 256mm not possible, 288mm probably, 312mm normally only for GTI.
You really do need to check proper brake manufacturer's websites to find out which brakes your car has.
Polo GT 140hp/150hp indeed takes 288mm discs a the front
MarkoPolo
Post by MarkoPolo »
iichel wrote: Sat Jan 26, 2019 10:52 pm Polo GT 140hp/150hp indeed takes 288mm discs a the front
Thank you!
Peter N
Drives: 2017 VW Polo Blue GT 1,4 TSI DSG7
Post by Peter N »
standard is 288mm
Chloe1x2x3
Drives: 2015 Blue GT
Post by Chloe1x2x3 »
Hi Marko
Did you have any issues with the 288mm front brake discs fitting? I’ve ordered myself some and the garage I took it to fit them said they were too small?
Thanks in advance
DKPOLOGT
Drives: Blue GT
Post by DKPOLOGT »
Go for mtec brakes.
Chloe1x2x3 wrote: Tue Mar 12, 2019 3:02 pm Hi Marko
Thanks in advance
Did you get anywhere with this job? Where did you buy the 288mm diameter vented discs from?
MarkoPolo
Post by MarkoPolo »
Thanks in advance
Haven't done this yet but have ordered some from GSF Car Parts.
Should arrive tomorrow and going to be fitting them on Saturday.
Will update you after(if) they are fitted
Sent from my ONEPLUS A5000 using Tapatalk
MarkoPolo
Post by MarkoPolo »
288mm is the correct size for the Front on the BlueGT
Fitted mine today, looks mint
Part I ordered : https://www.gsfcarparts.com/601vg0101
