Lowering springs
Dionbutton1892
Drives: GTI+
Lowering springs
Post by Dionbutton1892 »
Anyone fitted lowering springs to their GTI
MattHGR
Drives: GTI+
Re: Lowering springs
Post by MattHGR »
Seen someone else with H&R 28711-2
User was peter007
Can find his posts in the photo gallery page, mid February
Just a little too low for my liking - prefer to just about see all the wheel in the arches.
MattHGR
Drives: GTI+
Post by MattHGR »
Be careful when lowering too.
I'm sure there's a sensor attached to back wheels that is used for headlight alignment.
Very common for this to be broken OR people forget to reset the headlight alignment after
Polovivo
Drives: TSi AW / GTi AW
Post by Polovivo »
How do you reset the headlight alignment?
Polovivo
Post by Polovivo »
MattHGR wrote: Thu Mar 28, 2019 12:45 pm Seen someone else with H&R 28711-2
User was peter007
I fitted the same spring kit kit on my GTi.
Sits well.
Will post some pics shortly.
Polovivo
Post by Polovivo »
Polo GTi
Polovivo
Post by Polovivo »
Polo TSi RLine with spacers
phillos
Drives: '19 Polo (AW)
Post by phillos »
Unsure if the H&R 28711-2 fit on GTI's with the Sport Select suspension ("adaptive" dampers).
H&R seems to think so, but all retailers I've inquired at, disagree and claim they will not.
Who do I believe, the half dozen of retailers. Or the manufacturer. :D
Polovivo
Post by Polovivo »
phillos wrote: Fri Mar 29, 2019 7:21 am Unsure if the H&R 28711-2 fit on GTI's with the Sport Select suspension ("adaptive" dampers).
My car has the sport select, my rline has it too.
No problems experienced.
Andy Beats
Post by Andy Beats »
Lowered springs on standard dampers shouldn't be a problem on cars.
It's a different story on bikes as they often use a rising rate linkage and lowering the spring (usually for short people to get a lowered seat height) means the damper is suddenly working in a different part of its range from standard.
So the ride can be ruined because the shock is sitting past it's softest part of the curve and can't cope with bumps any more.
silverhairs
Drives: 2018 Polo SEL
Post by silverhairs »
On a lot of the big BMW bikes, you can alter the height of the seat, so no need to alter the springs.
Dube
Drives: 2018 GTI
Post by Dube »
Folks, I just fitted my POLO GTI 2018 model with H&R lowering springs and H&R Wheel spacers (15 on the back and 12mm on the front). After the fitment now I hav a error on my car damper sensor/ error appears on my car. None of the VW technician can help me.
Jay-Jay
Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
Post by Jay-Jay »
Check if the sensor on the top of the two front struts is connected.
Maybe it's not.
green justin
Drives: 2019 Polo GTI
Post by green justin »
Dube wrote: Fri Jul 05, 2019 8:41 am Folks, I just fitted my POLO GTI 2018 model with H&R lowering springs and H&R Wheel spacers (15 on the back and 12mm on the front). After the fitment now I hav a error on my car damper sensor/ error appears on my car. None of the VW technician can help me.
You should have it fitted at H&R South Africa in Boksburg.They the importers for H&R. They race in the Polo CUP on the weekends
I am two mind about H&R and Eibach, I would love to get a feel on how firm the springs are.
