Anyone any clue where the main beam adjustment screw is?
I've got the dip to a nice level, can't for the life of me see where the main adjuster screw is.
Main is terrible, far too low in relation to dip now.
As good as useless.
Main beam adjustment
Andy Beats
barrywi
Re: Main beam adjustment
Hi Andy , please find attached a plan of where the adjusters are. I have not tried doing it yet but it will presumably alter both dipped and main beam
barrywi
Pictures are of gti plus with leds so not sure if yours is the same
green justin
- Drives: 2019 Polo GTI
Just take it too the dealership, let them adjust it on the computer. 20mins done
barrywi
Got my dealer to raise the beams when I first bought it but they set them too high. Asked them to drop the beams a little and was told , by the same garage that led lamps are not adjustable!! Useless.
green justin
My led lamps were also too high, once the car was plugged into the computer and adjusted to the right level measured by the computer with angles and degrees.
The tech informed me it was not done at the factory.
Andy Beats
Not a Gti/LED
