I had the head refaced and new valve stem seals. Refitted using the timing tools, but as soon as I started the car it was running roughly. Stripped head off and asked the head refurb company to look and they said one exhaust and one inlet valve were bent.
I am sure I checked the timing after it wouldn't start and it hadn't jumped.
So I am miffed and have the head ready to refit, but I'm worried as I can't understand how I could have bent the valves first time.
Anyone have any possible causes?
Bent valves after refitting head. Can't think how?
Re: Bent valves after refitting head. Can't think how?
Possibly one or both of the cams were rotated with the head sitting on a hard bench surface causing a valve strike into the bench? I was told to find cyl 1 TDC then take it back down from there to get the pistons at a safe clearance from any protruding valves during the head fit up - maybe that??
flanagaj
- Drives: MK6 1.2 (VAG BMD 3 Cylinder)
Maybe. If anything I'd have expected cylinder 1 to be bent as when at TDC 2 and 3 are well down in the block if it had happened when fitted.
