Franciswat's Polo 6R 1.6 Bifuel
Franciswat
Drives: 6R 1.6 Bifuel
Re: Upgrading my Polo 6R bifuel
Post by Franciswat »
Hello everybody,
sorry for the late reply but I was waiting to get some news to update the thread.
Ok, please, be patient, now I'm with other projects. :wink:
No problem ciclo, please take all time you need.
Anyway I spotted an offer and purchased CBI because they look the best compromise - as you said - and I am waiting for the shipment; I just want to have all lamps ready when I'll mount the bi-xenon headlights.
There are three ways to make an Auto scan:
- Auto detect (CAN only)
- selecting chassis
- customized
Ciclo I tried all the possile ways you explained me to get an autoscan of the engine and I finally had success with the last one (after few tries) so thank you so much for that! 8)
Thursday,09,May,2019,23:42:59:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 17.1.3.0
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY54xxxx   License Plate:
Chassis Type: 6R (01 - Italian Job)
Scan: 01
Address 01: Engine (J623-CNKA)       Labels: None
   Part No SW: 03C 906 014 BD    HW: 03C 906 014 BD
   Component: CNKA-MM7GV-G  H02 CNKA-MM7GV-G  H02 05610561
   Revision: --H02---    Serial number:
   Coding: 00110014002400080000
   Shop #: WSC 62297 001 1048576
   VCID: 60C87BC270D8E34189-5178
Readiness: 0110 0001
End-------------------------(Elapsed Time: 00:29)--------------------------
Honestly I have never seen "The italian job" ciclo :lol: is that a good movie? :mrgreen:
Well, in the last period I have sometime a MIL active on my instrument cluster. That's the error:
Address 01: Engine       Labels: None
Control Module Part Number: 03C 906 014 BD    HW: 03C 906 014 BD
  Component and/or Version: CNKA-MM7GV-G  H02 0561
           Software Coding: 00110014002400080000
            Work Shop Code: WSC 62297 001 1048576
1 Fault Found:
013147 - System too Rich during Nat.Gas Operation
               P335B - 000 -  - MIL ON
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 178
                    Mileage: 88947 km
                    Time Indication: 0
                    Date: 2017.14.16
                    Time: 16:45:45
                    Bin. Bits: 00000010
                    Load: 63.0 %
                    Lambda: -7.0 %
                    Speed: 101.0 km/h
                    Temperature: 84.0°C
                    Absolute Pres.: 688.2 mbar
                    RPM: 2460 /min
Readiness: 0010 00
I made a search on Ross Tech wiki and even If I could not find the exact error code I found a page that could be related to this error so I'll post it below:
:arrow: http://wiki.ross-tech.com/wiki/index.ph ... m_too_Rich
And finally guys I am preparing for some major painting work :!: I got used rear r-line bumper and side skirts but their color is wrong and they have some scratches to repair.
After some meditation I decided to handle it by myself to save some moneys (and have some fun :mrgreen: ) so I got some products from paint factory which supplies body shops.
I will update you in the next week with the progress of these works including the retrofitting of bi-xenon headlights and front PDC.
In the meantime the precious AFS sensor bracket is arrived (20 € :shock: ) and I am waiting to receive the skoda's parking sensor hole cutter suggested by ciclo in his thread (pictures and infos below).
You will have to speak with experts in Magneti Marelli ECUs to tell you which tool can read and write your ECU, and most importantly, which is the Byte that must be modified to show the Gra_high in your MFD+.
There must be other VW models with similar ECUs (same family) that already have Gra_High activated so that experts :?: with their wonderful tools (2000-15000€) can tell you the exact Byte (in case it is possible for your ECU).
I think the hardest thing of this job is to find an expert of my ECUs model (VW gpl cars are not so common here) but anyway I will try to dedicate on It as soon as I'll finish the looooong list of works I've already planned, thanks mate! :roll:
Franciswat
Good morning guys,
new (front) brakes today for my Polo since 2012 and 89.000 km.
In the meantime I asked mechanic to mount new bracket for AFS.
About the problem I have on engine starting he suggested to replace the lambda sensor (the one on the front of the car) due to the fact he thinks the error "System too Rich during Nat.Gas Operation" could be related.
Do you think lambda could be a possible suspect for that problem?
Good improvements ... Brakes 😎, front PDC 😎, AFS sensor bracket 8)
As for the IC warning light, sporadic fault in the engine reflected in Autoscan, there are several possible causes as you already know. As you do not have obvious symptoms of engine fault you will have to continue investigating little by little until you get the solution.
If the leaks in the fuel/gas supply system, spark plugs, and other sensors have already been checked, it's the turn of the lambda sensor...
Franciswat
Hello guys,
thanks to the help of ciclo and of other members of the forum I retrofitted bi-xenon headlights and AFS!
I have some big problems with the long coding; I copied a LC i found on forum tryng to adapt it to my car but with bad results. DRL and cornering lights do not work correctly (ie corner light does not work when I turn the steering wheel and DRL does not switch off when I use turning lights or handbrake). In addition to this autoscan shows a lot of errors. I am not confident with BCM coding so I post an autoscan looking for some help. :wink: Thanks in advance and have a good holidays :!:
Wednesday,07,August,2019,01:17:27:39744
www.Ross-Tech.com
VIN: WVWZZZ6RZCY540000   License Plate:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 55 56 0B
55-Headlight Range -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BC    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0002
   Revision: --------
   Coding: 210224E3217100B5842524E484D700401300
   Shop #: WSC 00788 648 00255
   VCID: 00085B4297984341E9-8054
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
   Component: Man AC        H02 0202
   Revision: 0003SH02
   VCID: 397EF6A6B0C2D289EE-806C
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Revision: B9080001    Serial number: 0771 060161479
   Coding: 3CB02BB808210000203809D17E6B1DD9FAC067FF602D10D1A00000030000
   Shop #: WSC 02737 534 00190
   VCID: 68D863E29BE89B0141-803C
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU004011200011991
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU005011200017885
   Coding: 08BC30
   Subsystem 3 - Part No: 1K8 951 171 A
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H03 1301
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H04 0103
   Serial number: 29170002240760027504
   Coding: A40000
   Subsystem 7 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU010011200012406
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU009011200013136
   Coding: 08BC32
3 Faults Found:
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 93600 km
                    Time Indication: 0
                    Date: 2020.14.05
                    Time: 02:23:35
03906 - Control Circuit for High Beam Relay
            010 - Open or Short to Plus
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 93600 km
                    Time Indication: 0
                    Date: 2020.14.05
                    Time: 02:23:35
01229 - A/C Humidity Sensor (G260)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 117
                    Mileage: 93600 km
                    Time Indication: 0
                    Date: 2020.14.05
                    Time: 02:23:38
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 K    HW: 56D 919 475
   Component: PARKHILFE 8K  H02 0106
   Revision: --------    Serial number: 20251528901029
   Coding: 100001
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_VW75XParkSasis4K 001004
   ROD: N/A
   VCID: 3A7CE9AABDC4D991E7-806E
No ASAM data for: "EV_VW75XParkSasis4K" (VW25)
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX011W0JJ
   Coding: 003232
   ASAM Dataset: EV_AirbaV1W0BPAVW250 A01001
   ROD: N/A
   VCID: 4A9CB96AED24491177-801E
   Subsystem 1 - Serial number: 3575HRB4059124B2F99H
   Subsystem 2 - Serial number: 3585HRB4061131GQCOUS
   Subsystem 3 - Serial number: 3515RRB405P0VC0I5P0W
   Subsystem 4 - Serial number: 3525RRB40510VC0IA9B9
No ASAM data for: "EV_AirbaV1W0BPAVW250" (VW25)
   Part No SW: 6R0 920 871 A    HW: 6R0 920 871 A
   Component: KOMBI         H03 0505
   Coding: 140E01
   ASAM Dataset: EV_Kombi_UDSV_DD_RM09 A04113
   ROD: N/A
   VCID: 3460C7929FA02FE13D-8060
No ASAM data for: "EV_Kombi_UDSV_DD_RM09" (VW36 *)
   Revision: B9080001
   Coding: 002200
1 Fault Found:
01771 - Control Module for Headlight Range (J431)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 117
                    Mileage: 93600 km
                    Time Indication: 0
                    Date: 2020.14.05
                    Time: 02:23:35
   Component: IMMO          H03 0505
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6ADC19EA8DE4A91157-803E
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F6AC8FEEA860C3940-807A
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 020A000001000000
   Shop #: WSC 02748 790 50316
   ASAM Dataset: EV_HeadlRgeulVWLWRPt 001004
   ROD: N/A
   VCID: 77FA309ECE5604F9D8-8022
No ASAM data for: "EV_HeadlRgeulVWLWRPt" (VW25)
4 Faults Found:
5256213 - ROD - Unknown Error Code
          - 00 [137]
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 117
                    Mileage: 93600 km
                    Date: 2084.14.05
                    Time: 02:23:33
13705472 - ROD - Unknown Error Code
          - 00 [137]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 117
                    Mileage: 93600 km
                    Date: 2084.14.05
                    Time: 02:23:33
13705474 - ROD - Unknown Error Code
          - 00 [137]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 117
                    Mileage: 93600 km
                    Date: 2084.14.05
                    Time: 02:23:33
13705480 - ROD - Unknown Error Code
          - 00 [137]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 117
                    Mileage: 93600 km
                    Date: 2084.14.05
                    Time: 02:23:33
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 6RD 035 187     HW: 6RD 035 187
   Component: Radio         517 5124
   Revision: RB101000    Serial number: VWZZZ4Q5034465
   Coding: 00000400040000
   VCID: 0400575287805F61CD-8050
End-------------------------(Elapsed Time: 03:21)--------------------------
Franciswat wrote: Tue Aug 06, 2019 11:10 pm I have some big problems with the long coding; I copied a LC i found on forum tryng to adapt it to my car ...
This is the worst thing that can be done.
I will try to make a new BCM coding for your new Bixenon headlights, etc...
As I did not manufacture any wiring installed in your 6R, any result is possible. :lol:
New BCM coding (09)
3CB02BBF08E1260092380EC16C6B0DD15AC0672F608D30D0200000020000
New AFS coding (55)
0110000001000000
1) Make a new autoscan with these new codings to know what wiring you have installed and what is the health status of your 6R.
2) Report about the results accurately.
Franciswat
Thank you very much ciclo and please apologize me for my noobish mistakes. :roll:
This is the autoscan made with the LC you gave me for 09 - Cent. Elect.
I was not able to change LC in 55 - Headlight Range due to a "Coding rejected. Error 31; Request out of range".
I made several attempts (ie typing the security code) but without success.
Thursday,08,August,2019,20:49:14:39744
www.Ross-Tech.com
Address 01: Engine
Cannot be reached
   Revision: --------
   Revision: 0003SH02
   Coding: 3CB02BBF08E1260092380EC16C6B0DD15AC0672F608D30D0200000020000
   Coding: 18BC30
   Coding: 08BC30
   Coding: A40000
   Coding: 08BC32
   Coding: 08BC32
2 Faults Found:
01134 - Alarm Horn (H12)
            000 -  -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 120
                    Mileage: 94216 km
                    Time Indication: 0
                    Date: 2020.14.06
                    Time: 20:44:28
01504 - Bulb for License-Plate Light (X)
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 120
                    Mileage: 94216 km
                    Time Indication: 0
                    Date: 2020.14.06
                    Time: 20:44:28
   Coding: 100001
   ASAM Dataset: EV_VW7X5ParkAssis4K 001004
   ROD: N/A
No ASAM data for: "EV_VW7X5ParkAssis4K" (VW25)
   Coding: 003232
   ROD: N/A
   Coding: 140E01
   ASAM Dataset: EV_Kmobi_UDS_VDD_RM09 A04113
   ROD: N/A
No ASAM data for: "EV_Kmobi_UDS_VDD_RM09" (VW36 *)
   Revision: B9080001
   Coding: 002200
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 120
                    Mileage: 94216 km
                    Time Indication: 0
                    Date: 2020.14.06
                    Time: 20:44:26
   Serial number:
   ASAM Dataset: EV_Immo_UDS_VDDR_M09 A03009
   ROD: N/A
No ASAM data for: "EV_Immo_UDS_VDDR_M09" (VW36 *)
   Coding: 11250
   Shop #: WSC 00788
   Coding: 0208000001000000
   ASAM Dataset: EV_HeadlRegulVLWWRPt 001004
   ROD: N/A
No ASAM data for: "EV_HeadlRegulVLWWRPt" (VW25)
4 Faults Found:
5275220 - ROD - Unknown Error Code
          - 00 [137]
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 120
                    Mileage: 94216 km
                    Date: 2084.14.06
                    Time: 20:44:23
          - 00 [137]
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 120
                    Mileage: 94216 km
                    Date: 2084.14.06
                    Time: 20:44:23
          - 00 [137]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 120
                    Mileage: 94216 km
                    Date: 2084.14.06
                    Time: 20:44:23
          - 00 [137]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 120
                    Mileage: 94216 km
                    Date: 2084.14.06
                    Time: 20:44:23
End-------------------------(Elapsed Time: 03:16)--------------------------
AFS unit
- My coding is correct for your 6R.
- The AFS unit has the correct reference number and software.
- According to the current coding (0208000001000000) it comes from a Transporter, which means that it is not parameterized for 6R, which in turn means that the second-hand unit installed is not correct. You will have to buy one from a 6R.
BCM 7E0 + Bixenon
- Try this new coding and post a new autoscan:
3CB02BBF08E1240092380E916C6B0DD15AC0672F608D30D0200000030000
Franciswat
Thank you ciclo!
I tried to code again the Headlight Range unit getting "code accepted" message but the LC did not change so I will definitely follow your suggestion and buy a new unit from a 6R.
Here's the last autoscan with the LC you provided above. :wink:
Friday,09,August,2019,09:47:25:39744
www.Ross-Tech.com
VIN: WVWZZZ6RZCY540000   Mileage: 94210km-58539miles
Address 01: Engine
Cannot be reached
   Revision: --------
   Revision: 0003SH02
   Coding: 3CB02BBF08E1240092380E916C6B0DD15AC0672F608D30D0200000030000
   Coding: 18BC30
   Coding: 08BC30
   Coding: A40000
   Coding: 08BC32
   Coding: 08BC32
1 Fault Found:
            000 -  -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 120
                    Mileage: 94219 km
                    Time Indication: 0
                    Date: 2013.12.30
                    Time: 09:42:35
   Coding: 100001
   ASAM Dataset: EV_VW75XParaKssis4K 001004
   ROD: N/A
No ASAM data for: "EV_VW75XParaKssis4K" (VW25)
   Coding: 003232
   ASAM Dataset: EV_AirbaVW10BAPVW250 A01001
   ROD: N/A
No ASAM data for: "EV_AirbaVW10BAPVW250" (VW25)
   Coding: 140E01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   Revision: B9080001
   Coding: 002200
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 120
                    Mileage: 94219 km
                    Time Indication: 0
                    Date: 2013.12.30
                    Time: 09:42:31
   Serial number:
   Coding: 11250
   Shop #: WSC 00788
   ASAM Dataset: EV_HeadlRegluVWLWRPt 001004
   ROD: N/A
No ASAM data for: "EV_HeadlRegluVWLWRPt" (VW25)
4 Faults Found:
          - 00 [137]
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 120
                    Mileage: 94219 km
                    Date: 2019.08.09
                    Time: 09:42:29
          - 00 [137]
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 120
                    Mileage: 94219 km
                    Date: 2019.08.09
                    Time: 09:42:29
          - 00 [137]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 120
                    Mileage: 94219 km
                    Date: 2019.08.09
                    Time: 09:42:29
          - 00 [137]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 120
                    Mileage: 94219 km
                    Date: 2019.08.09
                    Time: 09:42:29
End-------------------------(Elapsed Time: 03:19)--------------------------
Perfect :wink: , all OK, except the faults we already know and their causes.
- Alarm horn and Headlight range control unit.
Franciswat
Thanks ciclo for your help.
:wink: I noticed a problem: when I make the highlight bulb error light appear on the instrument cluster even if both lights works correctly.
It is not a coding problem, the warning in IC is probably a problem with the headlight shutters.
The bixenon headlights you installed were brand new?
Franciswat
No they are used parts but they look to work correctly and I did not encurred this issue in the last few days. :?
Wait to change the headlight range control unit to solve the IC warning lamp.
Franciswat
Hi ciclo, today I received a headlight range unit dismatled from a Polo 6R 1.390cc.
Comparing the 2 headlight range units they look almost the same.
I have replaced the old unit with the new one and cleaned the old recorded faults but I get several errors which I still don't know how to solve after several searches on the web. :cry:
Monday,19,August,2019,15:18:22:39744
www.Ross-Tech.com
VIN: WVWZZZ6RZCY540000   Mileage: 94980km-59017miles
Address 01: Engine
Cannot be reached
   Revision: --------
   Revision: 0003SH02
   Coding: 18BC30
   Coding: 08BC30
   Coding: A40000
   Coding: 08BC32
   Coding: 08BC32
1 Fault Found:
            000 -  -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 140
                    Mileage: 94985 km
                    Time Indication: 0
                    Date: 2014.01.09
                    Time: 01:06:28
   Coding: 100001
   ASAM Dataset: EV_VW57XParkAssis4K 001004
   ROD: N/A
No ASAM data for: "EV_VW57XParkAssis4K" (VW25)
   Coding: 003232
   ASAM Dataset: EV_AirbvAW10BPAVW250 A01001
   ROD: N/A
No ASAM data for: "EV_AirbvAW10BPAVW250" (VW25)
   Coding: 140E01
   Revision: B9080001
   Coding: 002200
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 140
                    Mileage: 94985 km
                    Time Indication: 0
                    Date: 2014.01.09
                    Time: 01:07:08
   Serial number:
   ASAM Dataset: EV_ImmoU_DS_VDD_RM09 A03009
   ROD: N/A
No ASAM data for: "EV_ImmoU_DS_VDD_RM09" (VW36 *)
   Coding: 11250
   Shop #: WSC 00788
   Coding: 0110000001000000
2 Faults Found:
13705472 - Databus
          U1121 00 [137] - Missing Message
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 140
                    Mileage: 94985 km
                    Date: 2019.08.19
                    Time: 01:06:22
13705474 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 140
                    Mileage: 94985 km
                    Date: 2019.08.19
                    Time: 01:06:22
Address 56: Radio (J503)       Labels: None
   Component: Radio         541 5314
   Revision: --------    Serial number: VWZZZ4K6200530
   Coding: 16000400040005
   Shop #: WSC 127395 840 08317
   VCID: 46848D5AF13CAD7193-8012
End-------------------------(Elapsed Time: 03:18)--------------------------
