gti 1.8 engine noise
MJGTI
Drives: 6c GTI
Post by MJGTI »
get a weird tapping/rattling type noise from the engine which is quite loud it’s only when idling any clues??
l3rady
Drives: Polo GTI+ 2019
Re: gti 1.8 engine noise
Post by l3rady »
Does the noise increase if you bring up the revs?
Could be a number of issues such as a worn part, or could be that your oil pressure is low. Check your oil levels as if there isn't enough oil then the upper part of the valve train might not be getting enough oil.
MJGTI
Drives: 6c GTI
Post by MJGTI »
cheers for the reply! it’s only when it’s idling it’s fine when i rev or drive normally
JDMordicant
Drives: GTI 6c 1.8 TSI DSG 2016
Post by JDMordicant »
Loose exhaust or heat guard perhaps?
MJGTI
Drives: 6c GTI
Post by MJGTI »
it’s not the exhaust it’s been swapped out it’s definitely engine noise
Dink
Drives: 2015 GTI
Post by Dink »
HPFP? that can make a tapping noise
Jay-Jay
Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
Post by Jay-Jay »
If you could post a video, it would be easier for everybody to better understand and help you.
