Seat Ibiza 6j Upgrading BCM and Auto light with CH/LH
Hey guys,
I own a Seat ibiza 6j 1.2TSI from 2013, with :
-H7 Halogen lights
-Heated Seats
-fog lights
-Headlight washers
-automatic air conditioning
ect.
Unfortunately without Auto Light with CH/LH and rain sensor.
My plan was to retrofit the rain / light sensor on the glass and then to activate the automatic light.
I already mounted the rain / light sensor on the glass and wired it.
On the way there I found out that my BCM (6R0937087P)only supports the rain function, so i bought the 7H0937090B.
After switching and coding the BCM i noticed that there is no turning Signal, no light in the instrument cluster and the windows, radio key are not working.
I read a lot in this forum, especially from ciclo and figured out that i have maybe to connect Pin 28 and 29 from the Instrument cluster with the BCM 54/57 Pins is this correct ?
Furthermore, I need help to get the Auto light with CH/LH wiring.
would be nice if someone could help me.
Thanks in advance and I'm sorry for any mistakes.
-H7 Halogen lights
-Heated Seats
-fog lights
-Headlight washers
ect.
Re: Seat Ibiza 6j Upgrading BCM and Auto light with CH/LH
Update:
BCM is working wiring from T73b/57 to T32/29 and T73b54 to T32/28 was necessary.
Furthermore, I have connected the following cable :
Dimmed headlights :
T73a/2 to T101/6
T73b/2 to T10a/6
SC57 to T73a/63
SC58 to T73b68
and bridged the J331 Relay T10d/3B to T10d/5B.
Following wiring need to be done :
T73a/37 to T17/12
T73a/45 to T17/13 (isolate original)
T73a/6 to T17/9 (Pinout and connect)
T73b/43 to T17/9
T73b/4 to E20 T6f/3 (isolate original)
T73b/7 to T17/16 (Pinout and connect)
bridge from T17/16 to T17/5
is this correct ?
Now I do not understand why I need the Relai J828 although after the removal of the J331 headlight flasher still work.
Picture of Relay Carrier :
https://ibb.co/2jg7kf1
Dimmed headlights :
T73a/2 to T101/6
T73b/2 to T10a/6
SC57 to T73a/63
SC58 to T73b68
T73a/37 to T17/12
T73b/43 to T17/9
is this correct ?
Update 2:
Right now i understand why i need the Relai J828, its for the High Beam in Auto Light position.
I did the wiring above and have currently the following Problems :
-The front fog lamps do not light when activated at the switch. However, on the Corning
Light function. Also the rear fog lights do not work.
-Error 00457 Tried to solve this by setting adaption channel 1 to value 1. Did not work
The fan of the Climatronic does not work when the ignition is on. However, when the engine is on.
-Rainsensor does not work. (wrong coding i guess)
-Error 02195 something is wrong with the Light Dimmer Switch
-Coming Home is not working
So the good news are :
- Leaving Home is working.
- Auto-Light also
- Auto-Light also
Yes. Verified.Skyscript wrote: Wed Jun 05, 2019 2:05 pm Update:
Dimmed headlights :
T73a/2 to T101/6
T73b/2 to T10a/6
SC57 to T73a/63
SC58 to T73b68
T73a/37 to T17/12
T73b/43 to T17/9
is this correct ?
Full Autoscan, please.
Hey ciclo,
thanks for your time and work i appreciate it.
Every time i try to post my Scan i get the message "Forbidden. Contains contacts. Message seems to be spam."
I don't now what i have to change to post it.
greeting
Skyscript
greeting
Skyscript
http://wiki.ross-tech.com/wiki/index.ph ... rol_Module
1
http://wiki.ross-tech.com/wiki/index.ph ... ctory_Mode (check, 0 value)
2
http://wiki.ross-tech.com/wiki/index.ph ... l_Clearing (clear)
3
Channel 001: Remote Control Matching
1st key
Start Matching new/additional Remote Controls by entering 0 for the New Value, then [Test] and [Save] the New Value.
Press and hold the Unlock button for at least one second on the Remote Control you want to add, the Blinkers will light up to confirm the Adaptation Process of each Remote Control.
2nd key
and so on... 3,4,5,X keys...
1
2
3
1st key
2nd key
So another try to post my Scan:
Dienstag,18,Juni,2019,12:29:35:56266
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 7 x86
VCDS Version: DRV 18.9.0.2 HEX-V2 CB: 0.4437.4
Datenstand: 20181017 DS296.0
Betriebsnummer: 123 12345 123456
Fahrzeug-Ident.-Nr.: VSSZZZ6JZER007887 KFZ-Kennzeichen:
Kilometerstand: 114830km Reparaturauftrag: Michael AKTUELL
Fahrzeugtyp: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
Fahrzeug-Ident.-Nr.: VSSZZZ6JZER007887 Kilometerstand: 114830km
01-Motorelektronik -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
04-Lenkwinkelsensor -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: Fehler 0010
09-Zentralelektrik -- Status: Fehler 0010
15-Airbag -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
25-Wegfahrsperre -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
4B-Multifunktionsstg. -- Status: i.O. 0000
56-Radio -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-CBZB) Labeldatei:. DRV\03F-906-070-CBZ.clb
Teilenummer SW: 03F 906 070 GR HW: 03F 907 309 AE
Bauteil: SIMOS10.22AH10 5485
Revision: --H10--- Seriennummer:
Codierung: 001100D6200400080000
Betriebsnr.: WSC 00049 770 00143
ASAM Datensatz: EV_ECM12TFS02103F906070GR 004007
VCID: 78A81887725EF767A65-802C
Kein(e) Fehlercode(s) gefunden.
Readiness: 0110 0101
Adresse 03: Bremsenelektronik (J104) Labeldatei:. DRV\6R0-907-37x-ESP90.clb
Teilenummer SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Bauteil: ESP9.0i front H02 0002
Seriennummer: --------------
Codierung: 11DD287D212300C7881C1471845800480905
ASAM Datensatz: EV_Brake1ESP90iBOSCH 003020
VCID: 0F7A435B67D0D0DF17F-805A
Adresse 04: Lenkwinkelsensor (G085) Labeldatei:* DRV\6R0-959-654.clb
Teilenummer SW: 6R0 959 654 HW: 6R0 959 654
Bauteil: LENKW.SENSOR H07 0070
Seriennummer: 29051304651073
Codierung: 01
Betriebsnr.: WSC 00000 000 00000
ASAM Datensatz: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA40E9F507AC957EC9-802A
Adresse 08: Klima-/Heizungsel. (J255) Labeldatei: 6R0-907-044.clb
Teilenummer SW: 6J0 820 043 E HW: 6J0 820 043 E
Bauteil: Climatronic H03 0808
Revision: S0000000
VCID: 261406FFE8EAB197C49-8072
1 Fehler gefunden:
00457 - Steuergerät für Bordnetz (J519)
013 - bitte Fehlerspeicher auslesen
Umgebungsbedingungen:
Fehlerstatus: 01101101
Fehlerpriorität: 6
Fehlerhäufigkeit: 1
Verlernzähler: 233
Kilometerstand: 114838 km
Zeitangabe: 0
Datum: 2013.11.08
Zeit: 16:09:38
Adresse 09: Zentralelektrik (J519) Labeldatei:. DRV\7H0-937-08x-09.clb
Teilenummer SW: 7H0 937 090 B HW: 7H0 937 090
Bauteil: BCM PQ25 Max4 H74 0712
Revision: B9074001 Seriennummer: 0571 341130505
Codierung: 7A882BE88861010001200EC07ECB9FD800404220008C6041200000000000
Betriebsnr.: WSC 12345 123 123456
VCID: 2D06F9D3CD1C82CF053-8078
Subsystem 1 - Teilenummer: 1K0 955 559 AH Labeldatei: DRV\1K0-955-559-AG.CLB
Bauteil: RLS 210311 05 54 0403
Codierung: 33242D
Subsystem 2 - Teilenummer SW: 6R0 959 801 AJ HW: 6R0 959 801 AJ Labeldatei: 6R0-959-801.CLB
Bauteil: J386__TSG_FT 006 5110
Seriennummer: 12202557130528011642
Codierung: 020000
Subsystem 3 - Teilenummer SW: 6R0 959 802 AQ HW: 6R0 959 802 AQ Labeldatei: 6R0-959-802.CLB
Bauteil: J387__TSG_BT 006 5110
Seriennummer: 12202560130528060752
Codierung: 020000
1 Fehler gefunden:
02195 - Regler für Beleuchtung - Schalter und Instrumente (E20)
008 - unplausibles Signal
Fehlerstatus: 01101000
Fehlerpriorität: 3
Fehlerhäufigkeit: 1
Verlernzähler: 233
Zeitangabe: 0
Datum: 2013.11.08
Zeit: 16:09:40
Adresse 15: Airbag (J234) Labeldatei:| DRV\5K0-959-655.clb
Teilenummer SW: 6R0 959 655 K HW: 6R0 959 655 K
Bauteil: VW10AirbagA09 H10 0020
Revision: -------- Seriennummer: 003GX01R7U4Z
Codierung: 003039
Betriebsnr.: WSC 00049 770 00111
ASAM Datensatz: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACC924F5C32B5F7001-801E
Crashsensor für Seitenairbag Fahrerseite:
Seriennummer: 3495RRB400250GJ2OPQ.
Crashsensor für Seitenairbag Beifahrerseite:
Seriennummer: 3505RRB401650HHORH3R
Adresse 17: Schalttafeleinsatz (J285) Labeldatei:| DRV\5K0-920-xxx-17.clb-SRI1
Teilenummer SW: 6J0 920 806 K HW: 6J0 920 806 K
Bauteil: KOMBI H01 0709
Seriennummer: 00000000000000
Codierung: 110E01
ASAM Datensatz: EV_Kombi_UDS_VDD_RM09 A04723
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
VCID: 3430ECB72EB6D3074AD-8060
Adresse 19: Diagnoseinterface (J533) Labeldatei:. DRV\6N0-909-901-6R.clb
Teilenummer SW: 6N0 909 901 HW: 7H0 937 090
Bauteil: GW-K-CAN TP20 H74 0712
Revision: B9074001
Codierung: 022200
VCID: 70B820A71AAEAF276E5-8024
Adresse 25: Wegfahrsperre (J334) Labeldatei:| DRV\5K0-920-xxx-25.clb
Teilenummer SW: 5K0 953 234 HW: 5K0 953 234
Bauteil: IMMO H01 0709
Seriennummer:
Codierung: 000000
ASAM Datensatz: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8C32CF3CF255F7201-803E
Adresse 44: Lenkhilfe Labeldatei: DRV\6Q0-423-156.clb
Teilenummer: 6R0 423 156 C
Bauteil: LenkhilfeTRW V278
Codierung: 11211
VCID: 3038E0A7D36EEF272E5-8064
Adresse 4B: Multifunktionsstg. Labeldatei: DRV\6J0-959-441.clb
Teilenummer: 6J0 959 441 A
Bauteil: MF-Modul 0007 0001
Codierung: 0000002
Betriebsnr.: WSC 77005 000 00000
VCID: 313EE5A3DD24E62F21B-8064
Adresse 56: Radio (J503) Labeldatei:. DRV\5M0-035-1xx-56.clb
Teilenummer SW: 6J0 035 156 HW: 6J0 035 156
Bauteil: Radio H07 0012
Revision: R0000000 Seriennummer: SEZAZ1N6256030
Codierung: 010004080203
VCID: 64905CF7DE5603871AD-8030
Ende--------(Dauer: 01:04, Batt.-Spannung Start/Ende: 12.6V/12.4V)---------
I changed the BCM already and coded it. Everything works so far except the above described things.
If you need further pictures or more informations i will post them asap.
while I verify the RLS and BCM codings, please, post an old Autoscan with the old BCM 087, ... with all units OK, if possible. thanks.
RLS
new coding
07302D
new coding
07302D
There are some Bytes in your BCM Max coding that are not correct, ... it is better to wait to see the old Autoscan with your old BCM High 087. Tomorrow.
With the new RLS coding the rain sensor should work correctly.
BCM Max 7H0937090B
new coding
7A8829E88861010001200EF07ECB9FD80F4063A9608C2049200000020000
1
If with the new BCM coding the problem of the dimmer (E20) is not solved you'll have to change the terminal from T73b/4 to T73b/1 to feed the 58d signal. (same new coding)
2
It is possible that according to your personal tastes or installed bulbs (LEDs, etc) you want to change some behavior of the lights (DRLs, or others), so the new coding can be modified.
Post a new Autoscan with the new BCM and RLS codings (for future readers/users). With a little luck, all units will be OK.
new coding
1
2
Thanks for your coding.
Unfortunately I have no vcds and my friend who owns vcds is on holiday until the 29th.
He has all my scans. I will post the scan from the 87 BCM and try the new coding when he returns.
I want upgrade to full led headlights from Seat Leon or Ateca if possible soon.
Were the problems with the fog lights and climatronic caused by the wrong coding?
Is it possible to activate the interior light only when it is dark?
Thank you a lot
Thank you a lot
