VCDS error scan on month old car (15 plate)
spartacus68
Post by spartacus68 »
15 plate Polo 1.4 TDI SEL purchased via Das WeltAuto from main dealer.
A month old, so thought I'd scan it as I was scanning my other car anyway. 3 errors. :shock:
Thought these things had 130 point checks? Before I get onto local Volkswagen main dealer to take a look, which all takes time, interested to what others think.? Looks like Air Conditioning and Central Locking?
Log here: Sunday,30,June,2019,16:45:07:49227
VIN: N/A License Plate: N/A
Mileage: 48983km-30436mi Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 10 15 17 19 44 55 5F
VIN: N/A Mileage: 48983km-30436miles
2 Faults Found:
25109 - Databus
U1123 00 [032] - Received Error Message
Intermittent - Not Confirmed - Tested Since Memory Clear
25126 - Databus
Readiness: N/A
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6C0 820 045 A HW: 6C0 820 045 A
Component: AC Manuell H03 0108
Serial number: 1501161B-0813
Coding: 201000001000000200
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26.rod
VCID: 1D64D0F7DD3DCA5F95B-8048
2 Faults Found:
262914 - Refrigerant Pressure
B10AB F0 [012] - Too Low
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 140
Mileage: 48740 km
Date: 2019.06.26
Time: 08:31:31
590081 - Control Circuit for A/C Compressor
B10A9 11 [012] - Short to Ground
Fault Priority: 2
Fault Frequency: 11
Reset counter: 144
Mileage: 47963 km
Date: 2019.06.18
Time: 19:04:47
Compressor shut-off requirement: Compressor activation: malfunction in activation path
Compressor current: actual value: 1.275 mA
Compressor current: specified value: 0.000 mA
Voltage terminal 30: 12.6 V
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 B HW: 6C0 937 089
Component: BCM PQ26 Hi4R H07 0065
Serial number: 001098109077
Coding: 03000A404253005B0BA44080B10F07C800005B0257010000000000000000
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_BCMA0 004008
ROD: EV_MQBA0.rod
VCID: 2F381A3FA79148CF377-807A
3 Faults Found:
197904 - Central Locking
B140A 4B [008] - Over temperature
Fault Priority: 6
Fault Frequency: 9
Reset counter: 106
Mileage: 46843 km
Date: 2019.03.27
Time: 15:06:00
262936 - Sensor for anti-theft alarm system
B1330 29 [008] - Signal Implausible
Fault Priority: 4
Fault Frequency: 1
Reset counter: 65
Mileage: 46844 km
Date: 2019.05.19
Time: 13:35:11
526606 - Internal Control Module Memory Check Sum Error
B2000 09 [009] - Component Failure
[Bauteilschutz Sicherheitsabschaltung aktiv]
Fault Priority: 1
Fault Frequency: 1
Mileage: 46835 km
Date: 2019.03.26
Time: 12:44:57
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 820 HW: 3Q0 035 820
Component: MU-S-D-ER H11 0137
Serial number: VWZAZ2R0056544
Coding: 02620000BE00000011111201000808001F0100C60120010000
ASAM Dataset: EV_MUStd4CTSAT 001018
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 6696BF1B48EBC987041-8032
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 6C0 919 603 HW: 6C0 919 603
Component: ABTm_Std2 H43 1017
Serial number: VWZ8Z9RH0022TG
1 Fault Found:
1637 - Interface for External Media
U11B8 00 [008] - No Communications
[USB - communication error]
Fault Priority: 4
Fault Frequency: 6
Reset counter: 133
Mileage: 46844 km
Date: 2019.05.26
Time: 11:00:48
Voltage terminal 30: 14.5 V
Interface for external media: status-Status: Open circuit
End----------(Elapsed Time: 00:54, VBatt start/end: 12.0V/12.1V)-----------
Re: VCDS error scan on month old car (15 plate)
Pre sale checks? More like use it until its low on fuel, give it a wash and away you go, any serious issues will get taken care of using the warranty!
AC compressor control issues, normally just a software issue, my wife's August 2015 Polo had that, I reported it but it at first service, but as I checked it the morning of the service, it had auto cleared, same for a fault with the infotainment system ON/OFF switch - nothing reported, and as some of these "low urgency" logged faults get cleared automatically if they don't re-appear, I think that you are lucky that your scan timing caught that one.
Edit:- I'm not sure exactly what the situation is with respect to AC refrigerant load weight, I think that they probably just think that it does leak out across flexi pipes and O-ring seals, so when you buy a used car, some of it will have already leaked out - the other way to look at this is, it is part of the car, so why not check top up AC charge if it needs it if selling with an approved warranty - maybe back to my initial description of what a used car preparation really is! Why they can't just do that and check and clear/fix all logged faults beggars belief - cons!
spartacus68
Thanks for the reply RUM4MO.
I did an online survey after I'd bought the car and it was pretty damning. This will be the third car I've bought off-spec based on description, usual video walk-around and dealer description, plus MOT investigation via .GOV site. I thought the car was poorly prepared and told the salesman that. He keep reminding me it was a 15 plate car.
I showed him my 12 plate A4 Allroad that we'd travelled down in. Apparently he doesn't know about cars... says it all really.
I'm sure the air con is a straight forward fix. I sometimes hear what sounds like the refrigerant gurgling after I come to a standstill after a journey. Difficult to know if that's just the system condensing, or it's leaking.
I will get them to check in the next week or so.
My wife got the usual online survey to fill in from VW - or on behalf of VW after she bought her Polo back 2015, I filled it in for her, and at the question "why did you choose a Polo?" I gave the answer on her behalf which was "because my husband has VCDS" - probably a waste of time, but it felt good at the time!
spartacus68
RUM4MO wrote: Mon Jul 01, 2019 9:34 am My wife got the usual online survey to fill in from VW - or on behalf of VW after she bought her Polo back 2015, I filled it in for her, and at the question "why did you choose a Polo?" I gave the answer on her behalf which was "because my husband has VCDS" - probably a waste of time, but it felt good at the time!
As good a reason as any. :wink:
It was a deciding factor for me having come from a Škoda for my daily driver.
