ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙‍♂️
Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP
Cheap front LED fog lights with drive unit.
EDIT (08/11/2019 - DD/MM/YY)
Explanations: (email request)
Well, once I installed the LED Replica headlights, the front fog lamp function stops making sense, however, the static cornering lights function, integrated from factory in the fog lamps in our Golf mk 7.5, takes on an important relevance.
Installing the new cheap LED lights with driver units in the fog lights is quite simple, the cover/cap on the wheel arch is removed and the lamp is changed.
No special adaptation or coding is necessary, static cornering lights/fog lights will work correctly (I mean without VCDS faults) as it was factory set.
However, I preferred to configure/adapt in the BCM adaptation channels this new type of LED light as follows:
VCDS. LED fog lights with drive unit---> In blue the new values!
Address 09:
SECURITY ACCESS--> 31347
Adaptation
LEFT
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16 ...(LED Lichtmodul)
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100 ,16 ...(127)
RIGHT
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16 ...(LED Lichtmodul)
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100 ,16 ...(127)
-Static cornering lights (through fog lights, Adapt: search for static AFS)
Address 09:
Adaptation
static AFS light-Oberer Lenkradwinkel,120 °,16 (upper steering wheel angle,60º)
static AFS light-Unterer Lenkradwinkel,80 °,16 (lower steering wheel angle,30º)
static AFS light-Upper speed threshold,40.0 km/h,16 (60km/h)
At night work perfectly as static cornering lights (roundabouts, intersections, corners).
The light is super white, it is the same color as the DRLs of my Replica LED headlights.
Note:
Do not use these LED lights as powerful fog lights, although they could fulfill their function ...
There are better LED lights (morimoto) to be powerful fog lights, logically they are more expensive.
01/2024
Double rear LED fog lights.
1st
New parts:
5G0945094AH ... Interior LED taillight from RHD models.
1K8972928A ... Brown connector.
* I did several attempts to use the original interior right taillight (discovering some secrets, connector type) but none worked.
The LEDs for rear fog light are built there but not the necessary wire, etc...
2nd
Install the new interior LED taillight.
Transfer the wires from original Black connector to new Brown connector with the same correspondence.
3rd
Install a new 0.5mm2 wire as indicated in the following scheme, from left T8/6 to right T8/6.
01/2024
BCM
From Basic 5Q0 937 084 DA to High 5Q0 937 084 DD.
To do after the summer or who knows ...
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
somehow this thread was not viewed/read/followed.
But I am sure in some finite time, this would be competing with Ciclo's 6R
waiting for all the information and knowledge (though not sure how i can cope and understand it)
Thanks for your comments ag69.
Well, this thread is how it is intentionally, this forum section does not have many visits or comments, which is perfect to me. I thought about it before opening this thread. :lol:
My wife's golf is in perfect condition right now, I mean, is a real pleasure to drive it with the mods I did it.
It already was a perfect car from factory, I do not mention it because we are the typical proud owners of the purchase, I mention it because it would satisfy the needs of 70% of the drivers worldwide. Its little engine is a marvel, one of the best I've driven (with a perfect electronics that puts a smile on the face when checking its power/performance and consumption).
I am pleasantly surprised.😊
Some current notes:
- The Replica LED headlights that I installed two months ago work 100% perfect. The lighting is extraordinary, the Light Assist (HBA) helps a lot to make it so.
- The LED bulbs I installed on the fog lamps are perfect as Cornering Lights (roundabouts, corners, intersections). Super whites. 8)
My POLO AW1, sorry for this confusion :lol: , I meant that our GOLF MK7.5 Ready2Go works like a charm.
Info/checking that everything works perfectly, factory and mods. 8)
VCDS Autoscan only.
Sunday,11,August,2019,09:56:26:32438
VCDS Version: 19.6.1.0 (x64)  HEX-V2 CB: 0.4508.4
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: .... WLAC!
Mileage: 22217km-13805mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 20 42 44 52 5F 65
VIN: WVWZZZAUZKPCICLOW   Mileage: 22217km-13805miles
Address 01: Engine (J623-DKRF)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 L    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6198
   Revision: D7H20000
   Coding: 01190032232415082000
   Shop #: WSC 00028 028 00070
   ASAM Dataset: EV_ECM10TFS01104C906025L 002003
   ROD: EV_ECM10TFS01104C906025L_002.rod
   VCID: 290F00D8897EC92FBD7-807C
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 DD    HW: 5Q0 614 517 AC
   Component: ESC           H25 0424
   Revision: 00000000    Serial number: 51998000000173
   Coding: 01FA6AA114202170477B060560CA2580562884E26006A4733020F0084002430B00000012121212B835351919323200
   Shop #: WSC 00028 028 00068
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 76B51BA40840D6D7E05-8022
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5G0 907 044 CE    HW: 5G0 907 044 CE
   Component: Climatronic   H04 1801
   Revision: 00001K08
   Coding: 00020003200110011005004000101022
   ASAM Dataset: EV_ACClimaBHBVW37X 006145
   ROD: EV_ACClimaBHBVW37X_006.rod
   VCID: 6C8139CC460C1C07061-8038
   Fresh Air Blower Front:
   Geber für Kältemitteldruck/Kältemitteltemperatur:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 DA    HW: 5Q0 937 084 CD
   Component: BCM MQBAB B   H38 0273
   Serial number: 00001820800697
   ASAM Dataset: EV_BCMMQB 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7AAD0F943C58B2B784D-802E
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    180621  043 0551
   Serial number:         180705074106
   Coding: 0E4DDD
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  052 0107
   Serial number: SBY18M08D06H04M32S34
   Coding: 00A8DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 507     HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000002081804401346
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418018193
   Coding: 0471151001
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   ROD: EV_EPHVA18AU3700000_009_VW37.rod
   VCID: 4CC1994C264CFC07661-8018
Address 13: Auto Dist. Reg (J428)       Labels:| 3Q0-907-572.clb
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0682
   Coding: 2B00600111FFC728949C810500400600000000000000000004
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   ROD: EV_ACCBOSCHVW416_002_VW37.rod
   VCID: 44D1B16C0E1C3447AE1-8010
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR4F1CUQ
   Coding: 98CCC000000000005C0000CF000800000065
   Shop #: WSC 00028 028 00064
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 094F605869BEA92F9D7-805C
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169667E30071820325
   Coding: 333135
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169668E31071830145
   Coding: 333135
   Side Sensor Driver Front:
   Subsystem 3 - Part No SW: -----------    HW: 480 002 307 18
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000F8745C23S
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 4 - Part No SW: -----------    HW: 480 002 807 18
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000000EC18233G
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 5 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A729FD154210-
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 6 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001A929FD1515577
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 306 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001A326704A3C63.
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 740 D    HW: 5G1 920 740 D
   Component: KOMBI         211 2500
   Coding: 07A52A802280000801883A051401000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009065
   ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
   VCID: 270B06E09F6AFF5FAB3-8072
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5344
   Serial number: 14071810801894
   Coding: 030100047F085700FA000248080F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013023
   ROD: EV_GatewNF.rod
   VCID: 3D27C4886DF6458FE1F-8068
   Alternator:
   Component: 1-01-02-01-04
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 5G0 959 442 AA    HW: 5G0 959 442 AA  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0052
   Serial number: 39180001255750088264
   Coding: 28FFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 9353818504
   Part No SW: 3G0 857 511 BD    HW: 3G0 857 511 BD
   Component: FLA           H01 0010
   Revision: AA001001
   Coding: 0202000000000000000000
   ASAM Dataset: EV_HighBeamAssisAU33X 001019
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: 6B833AD043021B3F0FB-803E
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
   Component: TSG FS        006 0246
   Serial number: 0000305474246
   Coding: 00150320D000048000001000
   Shop #: WSC 00020 999 12345
   ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
   VCID: 48C9A55C32341027429-801C
   Drivers Door Rear Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000009798407
   Coding: 010000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: 011F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B322B01B32C3FFC7B-8026
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0246
   Serial number: 0000336638884
   Coding: 00150320DE00048000001000
   ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
   VCID: 47CBA6603F2A1F5F4B3-8012
   Passengers Rear Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000009846262
   Coding: 090000
   Part No SW: 3Q0 035 824 C    HW: 3Q0 035 824 C
   Component: MU-S--ER      724 0890
   Serial number:
   Coding: 02731000FF0000005111000100080A001F0500D40120010003
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2D07F4C8BD96D50F51F-8078
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H52 8130
   Serial number: VWZ6ZJV2140047
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 30000000250801
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3431E1AC5EBC84C71E1-8060
End----------(Elapsed Time: 01:17, VBatt start/end: 13.0V/13.0V)-----------
Finally without information of the rear doors modules in the gateway installation list, which is logical because the rear window regulator motors (not control units) are controlled by the front door modules (control units).
You can compare this autoscan with the original of the first page to know what I'm saying if you are interested in these little details.
Sport steering wheel. GT.
Thursday,05,September,2019,18:57:16:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: MFSW 'AD'... OGT
Mileage: 22573km-14026mi   Repair Order:
VIN: WVWZZZAUZKPCICLOW   Mileage: 22573km-14026miles
   Revision: D7H20000
Readiness: 0010 0001
   Revision: 00001K08
   Air quality sensor:
   Coding: 0E4DDD
   Coding: 00A8DD
   Coding: 0471151001
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   ROD: EV_GatewNF.rod
   Alternator:
   Subsystem 2 - Part No SW: 5G0 959 442 AD    HW: 5G0 959 442 AD  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0052
   Serial number: 29180003012070018513
   Coding: 28FFFF
   Revision: AA001001
   Coding: 010000
   Coding: 011F0000
   Coding: 090000
   Serial number:
End----------(Elapsed Time: 01:17, VBatt start/end: 13.3V/13.4V)-----------
Works like a charm!
Golf GT (UK) :arrow: https://www.youtube.com/watch?v=98Ed8dXM5hg
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
lovely. lovely. [emoji7]. one question, why not changing the cluster to the screen one? its easily available and retrofitted right?
Thanks Amir.👍
I still have several modifications to make (slowly), maybe I will install another IC within a couple of years. :lol:
benzinkopf
heard if you buy that, you re going to be boring Ciclo. All you need is to call and pay the dealer to activate anything you want. No need wiring. No need retrofitting exercises. [emoji12]
Then it will be perfect for my busy life ...(these things already happen with Golf 7/7.5 via VW dealer)
Mods/updates with One-click, via VW-ONLINE connection with SIM card or via Smartphone. Fantastic!
What is true?
https://www.youtube.com/watch?v=ygPiFvCth3U[/youtube] 8)
Legal conditions? :wink:
Locked
