Reversing camera alignment / question
PoloGIT+
Drives: 2019 Polo GTI+
Post by PoloGIT+ »
Hi folks,
Recently I had just reversed into a parking spot using the reversing camera when my uncle walked around the back of the car and thought that I’d left the rear catch open so he tried to force it closed - while the camera was still in operation - I quickly corrected him but I’m a little paranoid that it’s possibly out of alignment, however having not taken much attention to it before I can’t tell for sure! Anyway, can I ask does the image look correct to others with reversing cameras? Should there be that black band across the top, or should the image fill the screen? It’s a 2019 GTI. Thanks in advance!
OomStu_ZA
Drives: 2019 VW Polo GTi
Re: Reversing camera alignment / question
Post by OomStu_ZA »
I dont recall seeing the black band on my screen but will confirm later today.
by the way the volume button is at 2 o' clock... that would drive my ocd nuts! :P
stevereeves
Post by stevereeves »
Don't have a reverse cam so can't comment on alignment, but that volume control defo needs to be at 12 o'clock :D ....
Scotty_boy vw
Post by Scotty_boy vw »
Here is my camera!!!
Scott
proalves
Drives: Polo GTI AW1 2019
Post by proalves »
I don't consider myself as an OCD person but the fact is that my volume control is always at 12 o'clock.
Regarding the camera mine presents a different image I would say that in your case is out of alignment, notice the bumper on my ...
OomStu_ZA
Post by OomStu_ZA »
So I checked and yes I also have the black line across top of the screen so don't think there is a problem.
OomStu_ZA
Post by OomStu_ZA »
proalves wrote: Tue Sep 10, 2019 4:22 pm I don't consider myself as an OCD person but the fact is that my volume control is always at 12 o'clock.
imho this camera is out of alignment, look closely at the black band across the top of the screen, it goes narrow (right) to wide (left) across the top. I also cant see my bumper either when in reverse gear using the camera.
proalves
Post by proalves »
OomStu_ZA wrote: Tue Sep 10, 2019 4:51 pm imho this camera is out of alignment, look closely at the black band across the top of the screen, it goes narrow (right) to wide (left) across the top. I also cant see my bumper either when in reverse gear using the camera.
You're correct I had never noticed this difference.
I think this bar should not even appear.
In my previous VW Golf the rear camera didn't have this bar or a lens so angular if I remember correctly ...
PoloGIT+
Post by PoloGIT+ »
Thanks all, that helps a lot! Whenever it next goes in I’ll ask the service centre to take a quick look anyway.
And yes, I’ll get that radio dial to the 12 o’clock position ASAP! :D
Like Scottyboy, my camera has about 6mm black banding across the top and I can see the 2 corners of my bumper. My black band is totally straight.
OomStu_ZA
Post by OomStu_ZA »
I also checked again today and confirm I can indeed see both corners of the rear bumpers and also have the black band across the top of the screen.
Scotty_boy vw
It may well be there are 2 different types of camera..the badge one and the other one that goes in between the rear number plate lights!!!
Scott
PoloGIT+
Post by PoloGIT+ »
monkeyhanger wrote: Wed Sep 11, 2019 8:04 am Like Scottyboy, my camera has about 6mm black banding across the top and I can see the 2 corners of my bumper. My black band is totally straight.
Thanks MH, in that case nothing wrong with mine :)
PoloGIT+
Post by PoloGIT+ »
OomStu_ZA wrote: Wed Sep 11, 2019 2:28 pm I also checked again today and confirm I can indeed see both corners of the rear bumpers and also have the black band across the top of the screen.
Brilliant, thanks very much :)
