Polo 6C GTI brake pads
amcl
Drives: 6C GTi
Post by amcl »
Hi, I recently replaced my brake pads with some brembo pads (P85 148), but I don't like the feel of the pedal.
my gti has the 312mm discs (Original pads 8X0698151), i'm having difficulty finding brake pads
https://ecat.ferodoracing.com/car-racin ... ds/FCP1641
http://www.pagidracing.com/en/product-s ... -8001.html
these are the options i found (a bit expencive)
I wanted to try some EBC pads ( redstuff) but I can't find the compatible ones
I would like to hear your opinions, and which ones you are using
thanks in advance for your feadback
JaegerStriker
Drives: 6C GTI
Re: Polo 6C GTI brake pads
Post by JaegerStriker »
ive just replaced mine with the ebc yellowstuff
https://www.carparts4less.co.uk/p/ebc-y ... -93044025Y
amcl
Drives: 6C GTi
Post by amcl »
JaegerStriker wrote: Tue Sep 10, 2019 7:24 pm ive just replaced mine with the ebc yellowstuff
and how about the brake pads? good braking? good inicial bite?
that set have wear indicator?
JaegerStriker
Drives: 6C GTI
amcl wrote: Wed Sep 11, 2019 9:11 pm
they have the wear indicator but the gti's dont use them so i just cut it off. havent had a chance to fully test them out as im still in the brake in period but they feel great already.
Jay-Jay
Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
Post by Jay-Jay »
I'm experiencing the same feelings with those Brembo pads on the same brake system.
Now I'm almost at 30% remaining pad's material, so I'm searching online for info about better pads.
Once again, the results of my search bring me to the EBC YellowStuff.
I'm pretty sure I'll go for them!
amcl
Drives: 6C GTi
Post by amcl »
I find it very strange is that EBC only manufacture these brake pads with the wear warning
Jay-Jay
Post by Jay-Jay »
Ferodo and Brembo build brake pads with the wear sensor too.
amcl wrote: Fri Sep 13, 2019 9:56 pm I find it very strange is that EBC only manufacture these brake pads with the wear warning
It could be that because EBC are not a very large scale manufacturer, just making all of certain pads with built in wear warning system is cheaper for them than manufacturing 2 different versions, as said already, all you need to do is to cut the cable off if your car does not have that warning system built into it.
