HW: 5J0 920 810 E
Component: KOMBI H15 0206And I want to change to a maxidot White one. So I bought the following USED IC
HW: 5J0 920 841 E
Component: KOMBI H04 0305I bring the instrument in "vergin mode" - zero km and zero attached keys and try to adapt on my car.
I transfer the VIN/ID, CS and PIN (Power class is not available on the old green cluster) from the old cluster to the "new" one .
I add my existing keys to the new cluster, but the instrument show a message "no key in range".
I do the process all over again but this time I try with a new blank TP24 ID48 Megamos Chip Glass. The TP24 chip is added, but I get the same message on from the IC "no key in range". I scan the chip again and it shows that now is TP23 (I have done the process twice and both times the same result)
Old cluster eeprom is 24C32 but the "new" one is 24C64. Menu functionality with trip button looks 100% functioning. Indication lamps and gages look functioning (oc I can't test Rev and speedo).
I am on a dead end and out of ideas at the moment.
Is there something that someone can propose or the project is a lost cause ?
Thank you for your time
My cars auto scan
VIN: TMBJN25J5Bxxxxxx License Plate:
Mileage: 86190km-53555mi Repair Order:
Chassis Type: 5J-SK25 (6N0)
Scan: 01 03 08 09 15 17 19 25 44 56
VIN: TMBJN25J5Bxxxxxx Mileage: 86190km-53555miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 N HW: 03F 906 070 N
Component: SIMOS10.20H02 9854
Revision: -------- Serial number:
Coding: 001100D6200400080000
Shop #: WSC 13765 031 00052
ASAM Dataset: EV_ECM12TFS02103F906070N 003009
ROD: EV_ECM12TFS_003_VW25.rod
VCID: 2D5130447C88F4224E-8078
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ABS82.clb
Part No SW: 6R0 907 379 S HW: 6R0 907 379 AB
Component: ABS8.2 front H03 0001
Revision: --------
Coding: 400100DB007500BB022C00E200D200000000
Shop #: WSC 39901 003 1048576
VCID: 4E9357C81D4EEF3A17-801A
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AP.clb
Part No SW: 5J0 820 045 B HW: 5J0 820 045 B
Component: Climatic 12 0670
Revision: 0003S 12
VCID: 2447D5602742356A91-8070
Part No SW: 6R7 937 086 F HW: 6R7 937 086 B
Component: PQ25 BCM H10 0017
Revision: -3------ Serial number: 1002430401
Coding: 64980B3808010000003000003E0A08C00040400F600000000000
VCID: 46836FE8F13E277AAF-8012
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3210
Coding: 020000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3210
Coding: 020000
Subsystem 3 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3210
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3210
Coding: 020000
Component: VW10AirbagT20 H09 0020
Revision: -------- Serial number: 003GX0076M12
Coding: 003230
Shop #: WSC 13765 790 00052
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9B5BD8ED26C31A4B-801E
Serial number: 3495RRB405N6THNCD8IT
Serial number: 3505RRB405L6THNCNHEY
Part No SW: 5J0 920 810 E HW: 5J0 920 810 E
Coding: 110A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
VCID: 285FC150536AD10ABD-807C
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R7 937 086 B
Component: GW-K-CAN TP20 0017
Revision: -3------
Coding: 232200
VCID: 70EFE930A33AD9CA25-8024
Component: IMMO H15 0206
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADBFB588DE6231A6B-803E
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 10140
Shop #: WSC 13765
VCID: 2F6D2A4CEA8486327C-807A
Part No SW: 5J0 035 152 A HW: 5J0 035 152 A
Component: Radio H08 0006
Revision: R0000000 Serial number: SKZAZ6K0423616
Coding: 050002000006
VCID: 204FD970335A294AF5-8074
No fault code found.Code: Select all
Parameter Value
Brand SKODA
Model FABIA AMBIENTE ESTATE
VIN TMBJN25J5Bxxxxxx
Check digit Ok
Sales id 5452J4
Production date 2010-09-23
Model year 2011
Engine code CBZB (TSI)
Engine number 000
Engine volume, L 1.20
Number of cylinders 4
Power, KW 77
Power, PS 105
Colour of body 8E (SILVER: reflexsilver metallic)
Trim BB
Gearbox code LMG (5S)
Country of sale 000 ()Code: Select all
Brand SKODA
Model FABIA ELEGANCE COMBI
VIN TMBJM65J8Cxxxxxx
Check digit Ok
Sales id 5454F4
Production date 2011-11-14
Model year 2012
Engine code CBZA (TSI)
Engine number 000
Power, KW 63
Power, PS 86
Colour of body 9P (CANDYWEISS: candy white)
Trim EG
Gearbox code MFX (5S)
