Hallo to all Car-enthusiast's.
Did someone already took a look into retrofitting the EPB from a different VW Platform into Polo PQ25 or T5/T6 ?
From my point of View the mechanical Part will be solvable.
But how is the possibility of getting the Control Module EPB integrated and coded into PQ25.
Which Control Modules are involved here ?
Shurly ABS/ESP is involved, and ECU, too.
In the past there was an additional Control Module for EPB, the J540, today this is integrated in the newest ABS/ESP Control Modules.
Thanks and Greetings
Dennis
ADD Electronic Parking Brake EPB to PQ25
Re: ADD Electronic Parking Brake EPB to PQ25
Mostly the ABS and the CAN gateway I'd say.
dnoermann
- Drives: T5.2 and Polo 9N3
I got a EPB Controller from PQ35 Sharan/Alhambra/Tiguan EPB4 3AA 907 801 H
Connected to EngineCan it can be reached by manual connecting to Address 53.
Communication to ECU and ACC is working. Looks promising. More testing needed.
dnoermann
I did make some more progress: https://www.t6forum.com/threads/epb-ret ... ost-323431
No question Dennis I will definitely follow you with this retrofit.
spacewalker
- Drives: Just a VW
only one EPB for PQ is from Passat NMS china passat
because is not use Duosensor inside, but all EPB from passat , Sharan working with TRW ABS pump not ATE
TRW pump have no duso sensor inside, that is why while calibrate that , you calibrate it in EPB
i know one guy who scuesfully add EPB from China passat NMS into Touran 1T3 and is working as should
