How to fix the 6N2 ABS Signal Outside Specifications Fault
Post Instructions on DIY modifications here - use all information with caution!
alexperkins
Site Admin
Re: How to fix the 6N2 ABS Signal Outside Specifications Fault
Post by alexperkins »
Hi Vas
Could be damaged wiring in the ABS loom. Any faults showing now?
vas.bak
Post by vas.bak »
Alex actually me mekanic was check the abs wiring loom also the wiring from and modul to the left sensor.
Have any idea what it happens,
Thank you very much for your answer also your very important help mate
vas.bak
Post by vas.bak »
The wiring it's ok
vas.bak
Post by vas.bak »
I connect vcds and the fault I read is left front sensor problem. We delete the fault but comes again.
2 brand new sensors we change but the problem stay.
alexperkins
Site Admin
I’d say you more than likely have an internal break in the ABS wiring that feeds that sensor so you won’t see it. I’d replace the loom that goes through the wing to rule it out
vas.bak
Post by vas.bak »
Alex thank you for your fast answering mate.
that is, you are so sure that it is not the ABS unit and it is wiring loom?
I ask because my mekanic was check ohmmeter the wiring loom that feed the sensor from the unit and it's OK.
You think Something other?
Thank you very much.
vas.bak
Post by vas.bak »
Alex good morning.
Please answer.
Thank you very much
alexperkins
Site Admin
I would pick up a replacement ABS module and see if the problem goes away. If you are confident the loom is ok, then you may have a faulty controller.
vas.bak
Post by vas.bak »
Thank you very much mate.
Marko106
Drives: 6R 1.6
Post by Marko106 »
What type of glue did you use for close the ecu after repair?
alexperkins
Site Admin
Non acetoxy curing silicone
Sump gasket sealant for example or similar
Chemical cure silicones release vapour which can damage the circuitry
Myhaitza15
Drives: 9n
Post by Myhaitza15 »
Thanks friend! Good Info!
MrMarkP
Drives: 6N2 GTI 1.4 16v
Post by MrMarkP »
Not so easy on the GTi 1.4 6N2
there`s not enough clearance to get the module on and off because of the master brake cylinder, i managed to get it off though had to heat up a knife to get into the case
and then levered it off i could feel a crack in the solder so i used flux and 50/50 solder did a good joint on both better than factory put the lid back on with silicone
now im struggling to get the module back on i might have to drain the system and take all the brake pipes off to get it back on, ive undone the servo on the front of the cylinder still dosnt make the clearance i need, ive took the coolant tank off to one side to make room as well think its in a awkward location probably take me another day to sort it out but glad i got this far thanks for the info
alexperkins
Site Admin
Is this LHD? On the RHD the master cylinder is the other side which makes it a very simple task. LHD sadly isn’t as easy
zoid
Drives: Polo 6n2 GTI
Post by zoid »
I know this thread hasn't been active in some while but I have an intermittent ABS light on my 6n2 GTI (although now currently staying on), although haven't been able to read the fault codes to see if it's a sensor or pump
@alexperkins I've noticed you've offered help in the past and are based in Poole, as I'm in Bournemouth would you be willing to take a look?
Kind Regards
