Wheel Specs and arch modding
ukeuropolo
Post by ukeuropolo »
i think of ordering my rims soon. 7x14 (front) 8x14 (rear) et 25, what does the ET 25 stand for and how does this effect the wheel? do u lot think i'll be able to fit these rims without arch modds? and also how low i was tinkin 80-90mm?
bstardchild
Moderator
Re: Wheel Specs and arch modding
Post by bstardchild »
ukeuropolo wrote:i think of ordering my rims soon. 7x14 (front) 8x14 (rear) et 25, what does the ET 25 stand for and how does this effect the wheel? do u lot think i'll be able to fit these rims without arch modds? and also how low i was tinkin 80-90mm?
ET is the distance in mm from the centre line of the rim to the hub mounting face
so the higher the ET the further in the wheels will appear if you keep the same rim width - obviously if you increase the rim width the effect will be reduced but you run the risk of fouling the strut.....
The lower the ET the further out the wheels will stick out if you keep the same rim width - obviously if you increase the rim width the effect will be even greater but you run the risk of falling foul with the boys in blue.....
I've a web site link somewhere that helps you compare all the wheel dimensions and specifies the clearance reductions v std wheel - this way you can measure up your std clearances and then know what you have to play with...... its a bit rough and ready but it works for me
Lowering just makes it all worse - 70-80mm is slammed :lol:
Rough and ready one - I had on this PC but it's better than nothing
http://toy4two.home.mindspring.com/offset.html
For Tyre sizing and profile changes when you go up on wheel size
http://www.mr2.com/FORMS/tire.html
When you know what your clearances are
http://members.aol.com/agspeed/tiresize.htm
Can't find the best link yet - the one that does it all :lol: Its on my home PC Somewhere :oops:
LJ_87
Post by LJ_87 »
just curious, what is the pcd and offset for a mk4, im guessing pcd is 4x 100?
bstardchild
Moderator
LJ_87 wrote:just curious, what is the pcd and offset for a mk4, im guessing pcd is 4x 100?
ET 45 for a GTi with 6.5 by 15's
ET 43 for a 1.4 CL on steelies 5.5 by 13's (cooking version)
mk4ads
Post by mk4ads »
And theres me thinking ET35 was the safest ET to go for on a mk4?
I have 7"x15" and they are ET24, feel the arches quite nicely. Im lowered about 120mm but ofcourse thats with flared arches but before that i could lower it about 80mm tops before it scrubed and that was with rolled arches.
I think with that ET you will struggle to go 80-90mm without any arch mods
david burton
Post by david burton »
I agree - I'm on ET35 with 7x15's too. I have a bf goodrich tyre on the back and it rubs (I'm lowered 80mm), so that tyre is slightly wider than the rest - it's going to be moved to the front!
bstardchild
Moderator
ukeuropolo wrote:what does the ET 25 stand for and how does this effect the wheel?
Specific answer to specific question - Speedlaw's info
http://www.tigerstyle.co.uk/poloforum/v ... php?t=1967
Proving once again of teh value of a good trawl thro old posts!!!!
bstardchild
Moderator
Update
Finally found it - best web link I've found for comparing wheels tyres ET's and gives the resultant effect on speedo accuracy and gearing if you complete all the details
http://gs.tolan-hoechst.com/tirecalc.htm
Worth bookmarking IMHO - I did just couldn't find it!!!
