Tuesday,25,February,2020,15:31:13:35439
VCDS Version: 17.1.3.0
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: WVWZZZ6RZBY004889 License Plate: M2016
Mileage: 154440km-95964mi Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 56 0B
VIN: WVWZZZ6RZBY004889 Mileage: 154440km-95964miles
25-Immobilizer -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
Address 01: Engine (J623-CAYB) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 AH HW: 03L 906 023 D
Component: R4 1.6l TDI H13 9979
Revision: --H13--- Serial number:
Coding: 00254016002400080000
Shop #: WSC 124697 483 00190
ASAM Dataset: EV_ECM16TDI02103L906023AH 003014
ROD: EV_ECM16TDI02103L906023AH_003.rod
VCID: 6C257124FF5950E9FD-8038
Readiness: 0 0 0 0 1
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3416D00B6842D14EA82DA00421300
Shop #: WSC 02069 123 12345
VCID: 06BB3D165B5FB4A30D-8052
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H12 0812
Revision: V0000000
VCID: 38E9D9800745687D9D-806C
4 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 86
Mileage: 154430 km
Time Indication: 0
Date: 2014.07.18
Time: 15:25:32
01272 - Positioning Motor for Central Flap (V70)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 86
Mileage: 154430 km
Time Indication: 0
Date: 2014.07.18
Time: 15:25:40
01271 - Positioning Motor for Temperature Flap (V68)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 86
Mileage: 154430 km
Time Indication: 0
Date: 2014.07.18
Time: 15:25:40
00710 - Defroster Flap Positioning Motor (V107)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 86
Mileage: 154430 km
Time Indication: 0
Date: 2014.07.18
Time: 15:25:42
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Revision: B9080001 Serial number: 0771 138160111
Coding: 3CB82BBF48A10000013806B03CEB9ED95F80612F60842041200000020000
Shop #: WSC 18752 008 00032
VCID: 68197930C73548CD1D-803C
Subsystem 1 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 0903
Serial number: KU0-KU011.05.1015140
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 0902
Serial number: KU0-KU017.05.1012733
Coding: 08BC30
Subsystem 3 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-MD9 H04 0103
Serial number: 29190000858580089166
Coding: A40000
Subsystem 4 - Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
Component: J388__TSG_HL 006 0902
Serial number: KU0-KU010.05.1012823
Coding: 08BC32
Subsystem 5 - Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
Component: J389__TSG_HR 006 0902
Serial number: KU0-KU007.05.1017524
Coding: 08BC32
3 Faults Found:
01520 - Rain and Light Recognition Sensor (G397)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 44
Mileage: 154399 km
Time Indication: 0
Date: 2014.07.17
Time: 21:51:33
02745 - Bulb for Daytime Running Light; Left
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 44
Mileage: 154399 km
Time Indication: 0
Date: 2014.07.17
Time: 21:51:29
02746 - Bulb for Daytime Running Light; Right
Fault Priority: 3
Fault Frequency: 1
Reset counter: 44
Mileage: 154399 km
Time Indication: 0
Date: 2014.07.17
Time: 21:51:29
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10Airbag008 H09 0018
Revision: -------- Serial number: 003DW00FP4EK
Coding: 003038
VCID: 42FFC5A2278B2CC72D-8016
Serial number: 3572SRB40000B7ACC10B
Serial number: 3582SRB40000B7C92178
Serial number: 3516GRB401P9OICCMBQI
Serial number: 3526GRB401N9OICD7JTE
Part No SW: 6JA 920 840 A HW: 6JA 920 840 A
Component: KOMBI H16 0607
Coding: 140801
Shop #: WSC 73430 031 00217
VCID: 39EEDF850B466A7C9D-806C
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Revision: B9080001
Coding: 002200
1 Fault Found:
01304 - Radio
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 26
Reset counter: 88
Mileage: 154399 km
Time Indication: 0
Date: 2014.07.17
Time: 21:52:25
Component: IMMO H16 0607
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6A27752AC7435CDFED-803E
1 Fault Found:
9456681 - Key
B104C 29 [008] - Implausible Signal
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 3
Mileage: 154399 km
Date: 2020.02.24
Time: 22:10:39
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 00000
VCID: 2FE0EB9B7728BE42C5-807A
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:48)--------------------------
For Immobilizer fault: one of my key is broken. Already got 2 new (just have to learn them)
For CAN Gateway fault: my radio is aftermarket.
For Bulb for Daytime Running Light fault: I remove original bulb, because my new aftermarket r-line body kit, don't have holes in the fog lights for the DRL...
For Rain and Light Recognition Sensor fault: That's why it didn't appear in drop box menu..I buy wiring kit from kufatec -
https://www.kufatec.com/en/volkswagen/v ... mber=38994, connect as on the diagram, rear view mirror is working. The sensor is: 5Q0955559B.
For Auto HVAC faults: i really don't have any idea what is going on.
Also don't know why cant reach Auto Trans
